Scene Timers Read in LUA
TimH
Domoticz version: 3.5877
Post by TimH » Monday 12 December 2016 13:10
it is possible to read out the Timers of a Scene in LUA and the Command(On/Off)?
TimH
jvdz
Target OS: Raspberry Pi
Domoticz version: Stable
Re: Scene Timers Read in LUA
Post by jvdz » Monday 12 December 2016 18:51
This is a way to do a JSON call and translate the returned data:
-- LUA to get GASMETER usage
-- Load necessary Lua libraries
http = require "socket.http";
socket = require "socket";
https = require "ssl.https";
JSON = require "JSON";
--~ --Get Scene Timers
local t, jresponse, status, decoded_response,idx
-- ### update the next 2 lines ##########################################
idx=9     -- IDX of the Scene
t = "http://192.168.xx.xx:8080/json.htm?type=scenetimers&idx="..tostring(idx)
jresponse, status = http.request(t)
decoded_response = JSON:decode(jresponse)
result = decoded_response["result"]
-- List all SceneTimers
if result == nil then
	print(os.date("%X").." No scene timers found for IDX "..idx)
	for i = 1, #result do
	record = result[i]
		if type(record) == "table" then
			day = record["d"]
			value = record["v"]
			print(os.date("%X").." "..i..
			"  Active="..record["Active"]..
			"  Cmd="..record["Cmd"]..
			"  Date="..record["Date"]..
			"  Hue="..record["Hue"]..
			"  Level="..record["Level"]..
			"  Randomness="..record["Randomness"]..
			"  Time="..record["Time"]..
			"  Type="..record["Type"]..
			"  idx="..record["idx"]
Jos
TimH
Post by TimH » Tuesday 13 December 2016 11:49
Thank you. I will try it the next days.
TimH
Post by TimH » Tuesday 13 December 2016 13:10
i have tried your Script but i got some failure with the libraries.
I use a Synology Diskstation to run Domoticz and this don't have the libraries.
Searching the Internet don't look good for Synology Lua Libraries.
Have anybody the right libraries or a idea where i can fount them?
jvdz
Post by jvdz » Tuesday 13 December 2016 13:39
The libraries can be found here: https://www.domoticz.com/wiki/Remote_Co ... _Libraries
This is a description for a Raspberry Pi so might need tweaking.
Jos
TimH
Post by TimH » Wednesday 14 December 2016 9:46
thank you for the Link.
I tried to translate it to Synology but i get failure.
Where are defined the Folder, where the location of the Libraries?
jvdz
Post by jvdz » Wednesday 14 December 2016 16:31
I think the error message, you get about not being able to find the require("LIB"), is telling you in which directories it was looking for these functions? at least that is what I seem to remember happening for me on a raspberry.
Jos
TimH
Post by TimH » Wednesday 14 December 2016 19:38
HI.
error Message in domoticz:
2016-12-14 08:14:03.753 Error: EventSystem: in READOUT: [string "-- LUA to get GASMETER usage..."]:3: module 'socket.http' not found:
no field package.preload['socket.http']
no file '/usr/local/share/lua/5.2/socket/http.lua'
no file '/usr/local/share/lua/5.2/socket/http/init.lua'
no file '/usr/local/lib/lua/5.2/socket/http.lua'
no file '/usr/local/lib/lua/5.2/socket/http/init.lua'
no file './socket/http.lua'
no file '/usr/local/lib/lua/5.2/socket/http.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './socket/http.so'
no file '/usr/local/lib/lua/5.2/socket.so'
no file './socket.so'
I have unpack the Files as indicated in the instructions and in the existing LUA-Folder from the Diskstation.
But i Think i must change the locating Folder for the Library.
wervisser
Post by wervisser » Tuesday 21 March 2017 0:47
Bump...
Did you by any chance got this fixed ?
niki_lauda
Post by niki_lauda » Tuesday 15 May 2018 21:24
HI.
Did you fix it?
niki_lauda
Post by niki_lauda » Tuesday 15 May 2018 21:29
Bump...
Did you fix it?
