Nest Protect
rednas
Target OS: Raspberry Pi
Nest Protect
Post by rednas » Friday 04 November 2016 13:59
Does Domoticz support the Nest Protect?
I am unable to find the answer on this forum.
Thanks in advance!
Sappien
Re: Nest Protect
Post by Sappien » Friday 04 November 2016 16:12
rednas
Re: Nest Protect
Post by rednas » Friday 04 November 2016 16:32
Oh nice! I already knew the Nest Thermostat was compatible.
So, what is the current functionality of the Nest Protect in Domoticz?
Derik
Re: Nest Protect
Post by Derik » Friday 04 November 2016 17:30
When it is in the list Yes..
Do you have a protect??
How is this hardware acting??
rednas
Re: Nest Protect
Post by rednas » Friday 04 November 2016 18:16
No, that's exactly what I'm trying to figure out.
Hopefully someone who has one in Domoticz answers :)
Sappien
Re: Nest Protect
Post by Sappien » Friday 04 November 2016 19:11
No fancy stuff :(
The Nest Protect API is very Limited.. I was hoping that I clould use the Motion sensors... No root hack at this moment (as far as I know)
mvveelen
Re: Nest Protect
Post by mvveelen » Wednesday 08 March 2017 20:47
I can only SEE the Nest Protect in Domoticz after adding them, but it can't be switched from Domoticz, there is no possibility to read the status (home / away) or use the motion detector. Bottom line: you can't do anything with them in Domoticz :|
RPi3 + RFXCOM rfxtrx433E + Xiaomi Gateway + Philips HUE Lights + Nefit Easy + Dashticz v2 + Domoticz latest Beta
gerard76
Domoticz version: 3.8153
Re: Nest Protect
Post by gerard76 » Thursday 13 April 2017 10:14
It gives an On/Off signal as smoke alarm.
I turn on all the lights for example so people can find their way out.
mvveelen
Re: Nest Protect
Post by mvveelen » Thursday 13 April 2017 10:19
Yes, but that's a signal the smoke detector SENDS. Wouldn't it be possible to send a signal to the smoke detector to test it, or to use it as an alarm signal or something.
By the way, when the smoke detector sends an alarm signal or when I use the test, no signal is received in Domoticz. So how do you use this on/off signal in your setup?
corederoma82
Re: Nest Protect
Post by corederoma82 » Thursday 14 December 2017 13:36
So? It's fully compatible with Domoticz?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826
