SNEAK PREVIEW - New default theme
sincze
Target OS: Raspberry Pi
Domoticz version: 3.8875
Re: SNEAK PREVIEW - New default theme
Post by sincze » Friday 11 August 2017 17:05
The new dashboard is ok.
Sub menus not so okay (even after shift f5).
Switches, not okay.
Scenes look okay.
Temperature looks okay
weather looks okay
Utility not so okay.
Setup looks okay.
Had to return back to stock, as lay-out was not really okay.
Currently running latest stabl eDomoticz release.
Using Pass2php since 2016-12
LAN: RFLink, P1-Port, OTGW, MySensors
USB: RFXCom, ZWave
WIFI: Mi-light Wifi-Bridge, Sonoff, ESP8266, Xiaomi Gateway
Solar: Omnik Inverter, PVOutput
Video: Kodi clients with Harmony HUB
Sensors: You name it I probably got 1.
sincze
Post by sincze » Friday 11 August 2017 17:15
Google might say... Refreshing Cache... it doesn't mean it really does....
Installed the chrome extension to force delete the cache and voila...
Much Better.
USB: RFXCom, ZWave
rhendriks
Domoticz version: Newest
Post by rhendriks » Friday 11 August 2017 19:55
I have add the new theme ,and now I want to change the background.
I place I new folder with a background image in de theme directory.
Than I have change this below
 body {
    background: transparent url(/home/pi/domoticz/www/styles/feynman/images/imgbg.jpg) center center fixed;
    background-size: cover;
What I'm doing wrong , the background is white?
blauwebuis
Domoticz version: current
Post by blauwebuis » Saturday 12 August 2017 19:52
@rhendriks and @joeygermeraad -You could try, but I'm not sure. It was developed on the beta.
blauwebuis
Post by blauwebuis » Saturday 12 August 2017 19:56
@rhendriks: that path is a local path. You have to use the public path to the image. Try "/styles/feynman/images/imgbg.jpg". Or just make the path relative to the CSS file.
joeygermeraad
Post by joeygermeraad » Monday 14 August 2017 19:34
Hi all just to confirm on my own question ;)
The merge feature does work On the latest stable version of Domoticz.
Although if i look at the JS code i see that it only works of sensors within the utilities type. So a combination of a sensor with lux and motion is not an possibility at the moment. @blauwebuis is this done for a specific reason?
sincze
Post by sincze » Tuesday 15 August 2017 17:22
mmm the kodi remote looks a bit strange with the new frontend :lol: in my Chrome.
Anything I can do to have it working correctly?
USB: RFXCom, ZWave
NiklasO
Post by NiklasO » Tuesday 15 August 2017 21:56
My stuff looks like this.
and this
I deleted the folder www and replaced it with the github version.
Running latest beta.
Tried Edge that I NEVER use and Chrome inkognito with cache cleared in all ways. ;)
What about every name in uppercase? Could I change that?
benotje
Domoticz version: V3,6146
Post by benotje » Wednesday 16 August 2017 17:32
what am I doing wrong
Luigi87
Post by Luigi87 » Friday 18 August 2017 20:01
Here the same problem. Cache is cleared. Some an idea what the problem can be.
I've noticed all my theme's are broken
Yesterday i've updated Domoticz on my RASpi trough.
cd domoticz
./updaterelease
After that i had some issues with the PID file, en my startup script (But seems no cause to the broken theme's i think, right?)
Schuko80
Post by Schuko80 » Sunday 20 August 2017 11:26
Same Problems - any idea?
roblom
Post by roblom » Sunday 20 August 2017 11:34
Do you use the default theme? If yes than clearing the cache should solve the problem. I had the same issue but after switching to the default theme and clearing the cache it was solved.
Schuko80
Post by Schuko80 » Sunday 20 August 2017 12:05
I switch from "elemental" to default and clean the cache - i give Firefox, IE and Opera a try, but it looks like the pic from "benotje"
roblom
Post by roblom » Sunday 20 August 2017 12:24
I'm at version 3.8337 and it shows normal.
The picture of benotje shows clearly still some elements of the elementry theme. So for some reason the cache isn't completely cleared.
Schuko80
Post by Schuko80 » Sunday 20 August 2017 12:33
ok, i have stabel Version: 3.8153 - is this the Problem?
I think this version has the new theme
roblom
Post by roblom » Sunday 20 August 2017 12:47
In no expert in this, I can only tell what I see.
Luigi87
Post by Luigi87 » Monday 21 August 2017 21:36
I have after again tried to clear the Cache. Again i get no background.
everything is now Grey/black.
I don't understand, all data seems to be in place.
Only my elemental Style is working. I also can from this style with the update, same as "Schuko80"
Edit:
Just tried the system in Internet Explorer and here the themes Change! But the default is still the "old" default theme.
So it seems to be a problem with Chrome. Schuko80 what browser do you use?
But also now some theme's are working. some seems not to work at all.
I am out of options, some here know's whats going on?
The default theme must be as seen in the first couple posts right?
Oke, Last Edit:
My default theme map is somehpow very empty as i compair this with the github.
https://github.com/domoticz/domoticz/tr ... es/default
and my map on the PI:
So what can i best do to update?? the whole WWW map from the Github??
Found someting else. The stable TGZ files on the download page do NOT Contain the update for the Default Theme! is this correct???
Abbadon
Post by Abbadon » Tuesday 22 August 2017 12:29
Download zip instead of doing git clone then unzip file and copy it to www
Luigi87
Post by Luigi87 » Tuesday 22 August 2017 15:35
i will try this when i have the time somewhere. thanks
Luigi87
Post by Luigi87 » Tuesday 22 August 2017 15:40
