Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Target OS: Raspberry Pi
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by Madgeni » Friday 09 February 2018 10:04
Thank you Lizard - I really appreciate the donation, they *really* help keep Controlicz running
Like Controlicz? Want to help keep the lights on?
https://paypal.me/madgeni
https://www.patreon.com/madgeni
Native Alexa skill and Google app - register at https://www.controlicz.com
michel30
Post by michel30 » Friday 09 February 2018 15:53
I was checking the site controlicz and I have a question for sign up:
Signup to Controlicz
Username or Email : Okay this clear I enter my email adress in.
Password : what password do you need? because is strange if you need my email adress password.
domoticz.host.net : For this I need to create an DNS server that will connect to my domoticz?
443 : okay, this is clear open the port to my domoticz.
controlicz_user : must I create the same user name on my domoticz?
controlicz_password : Enter the password from my domoticz with the user what I add above.
Regards,
Michel
Madgeni
Post by Madgeni » Friday 09 February 2018 16:56
Regards,
Michel
Hi -
Email;
Password for Controlicz account (NOT your actual email password!)
yep - domoticz DNS (or static IP)
port - whatever you've configured domoticz to use - i would suggest non-standard port number
controlicz_user/password - the domoticz username/password you've created for Controlicz ON your Domoticz instance.
sandervanpelt
Domoticz version: 3.0.8564
Post by sandervanpelt » Saturday 10 February 2018 12:46
mark.sellwood wrote:
Saturday 30 December 2017 20:54
Hi, My Google Home has stopped connecting to my Domoticz, when I ask Google to sync devices i get "Sorry an error occurred syncing Controlicz" When I look at my firewall logs I don't see any incoming connections. If I go to https://www.controlicz.com login and click "Test connection to your Domoticz" this passes and I see an incoming connection on my firewall from an Amazon IP address.
Is something broken?
Since a few days I am also no longer able to sync my devices, Google Home responds with 'An error occurred while syncing Controlicz'. I am still able to control my devices. Any suggestions?
Sander
Madgeni
Post by Madgeni » Saturday 10 February 2018 12:55
Can you disable and reenable the test in the simulation?
sandervanpelt
Post by sandervanpelt » Saturday 10 February 2018 13:17
Disabled and reenabled, but still not able to sync
Sander
Fred78
Post by Fred78 » Saturday 10 February 2018 15:37
getget wrote:
Thursday 08 February 2018 21:34
Fred78 wrote:
Wednesday 07 February 2018 16:27
getget wrote:
Wednesday 07 February 2018 15:18
Hello, today, no 404 :D
l have blinds defined in domoticz. What should I say to open them ?
When I say "ouvre le velux" (open the blind called velux in french) Google says "ok J'allume la lumière velux" (ok I turn on the light velux" ans the blind .... Closes.
Hmmm...funny. Because when I say "Ouvre le volet du salon", it works fine. I mean it says "ok j'allume la lumière volet du salon" and it opens the shutter.
What kind of device are you using for you're blinds? My shutter is managed by a Qubino Zwave module that is recognized by domoticz as a dimmer.
Thanks for the answer.
Hi. Well I guess that the difference between your configuration and mine is that I'm using a 'Dimmer' instead of a Blind.
My device is recognized as a dimmer and I never tried to switch the declaration to a 'Blind'.
I've just checked in Domoticz and there's a 'Blinds Inverted' type. Would switching to this type solve your problem?
EDIT :
I've just tried out the 'Blinds Percentage Inverted'. It works fine. If I say 'Ouvre le volet du salon' it opens the shutter. I a say 'Ferme le volet du salon', it closes the shutter. If I say 'Règle le volet du salon à 40%', it opens (or closes) the shutter up the 40%.
So try to switch from 'Blinds' to 'Blinds Inverted' in your domoticz configuration.
Madgeni
Post by Madgeni » Saturday 10 February 2018 16:06
Sander
so weirdly, I can see lots of control requests for you, but NO sync requests - like Controlicz isnt being called :(
sandervanpelt
Post by sandervanpelt » Saturday 10 February 2018 17:28
Sander
Even more weird is that after a few hours controlling devices also resulted in an error. Unlinking and linking in the Google home app resolved the issue
Madgeni
Post by Madgeni » Saturday 10 February 2018 17:41
i think (hope) some of these connectivity issues will be resolved when it's finally released into Live. Controlicz is up, and stable - but i'm definitely seeing issues in request/response between GA/GH and Controlicz
Smith
Post by Smith » Saturday 10 February 2018 19:57
excuse me to bother you again by asking me to login no login and password does not work there is opportunity to reconnect on Controlicz
Thanks you
maxtrash
Post by maxtrash » Sunday 11 February 2018 0:55
I'm struggling with the authorization to work. For a while I couldn't connect from controlicz to my domoticz instance. Today, suddenly the lights responded to my google home. I unlinked google home and had to unfortunately reboot my rpi. Now it doesn't work anymore. Testing the connection from the controlicz website fails. Domoticz is telling me this in the log:
Error: [web:443] Failed authentication attempt, ignoring client request (remote address: 35.176.67.167)
so the router seems to be correctly setup. I have addded an account in domoticz (setup / more options / edit users). The user is enabled, has user rights and sharing enabled).
What more can I do?
superustas
Post by superustas » Sunday 11 February 2018 10:16
Hi, Madgeni!
Controlicz, apparently, does not quite work correctly with thermometers / thermostats
I have simple temperature sensors in the system.
But apparently, Google Home takes them as thermostats (the thermostat is also there, but he is one).
If I say "set the thermostat to 24 degrees," then the answer is "9 thermostats set to 24 degrees."
If to ask "what temperature outside" there will be an answer something of type "-2 degrees and it is off"
Madgeni
Post by Madgeni » Sunday 11 February 2018 11:24
Hi -
You're right - kind of :)
Controlicz DOES understand the difference between thermostats/sensors - but Google DOES NOT.
https://developers.google.com/actions/s ... thermostat
I have to treat all heating as thermostats - so that's why it's setting all to 24 degrees. I would suggest naming your thermostat to something else (you can use the Controlicz override in your Domoticz description.
The 'and it is off' issue is with Google to fix - i pass state to Google, it just ignores it :)
Madgeni
Post by Madgeni » Sunday 11 February 2018 11:25
What more can I do?
Can you PM your email address, and i'll take a look. That error suggests it doesn't like the username/password you've specified in Controlicz.
if you try curl-ing this in a terminal: curl "https://yourusername:password@yourhost:port/json.htm?type=command&param=getSunRiseSet"
What happens?
maxtrash
Post by maxtrash » Sunday 11 February 2018 17:42
I agree it looks like I didn't put in the right password. Again, the curl-answer suggests so:
<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>
I have sent my email address.
Madgeni
Post by Madgeni » Sunday 11 February 2018 17:50
So in Domoticz, change the password, then update your Controlicz profile with that password, and try again?
Madgeni
Post by Madgeni » Monday 12 February 2018 14:36
Apart from opening/closing/up/down - what other things can you do with your blinds via Domoticz? can you set them to a certain height/width/percentage?
Madgeni
Post by Madgeni » Monday 12 February 2018 19:58
Had some interesting conversations today - Blinds/Notifications/SelectorSwitches and real-time status updates are coming - I think the last ones are tied to the CES announced Google Home displays that are being launched.
Lots of fun for you all, more work for me!
Update: Controlicz has been published !
alanlsmith
Domoticz version: 3.8153
Post by alanlsmith » Monday 12 February 2018 22:07
Very well done Nick! your perseverance and skills obviously finally got through to the big boys.
Domoticz v3.8153 stable, Ubuntu 18.04 on Intel NUC i3, 8Gb ram, 70Gb drive, RFXtrx433 & z-wave
