Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
georgesattali
Target OS: Raspberry Pi
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by georgesattali » Sunday 17 December 2017 11:49
I have a question about Google Home and Dz, please : is it possible to have it speaking ?
That is to send recorded sound files from the raspberry to the Google Home ?
GD
jeroenvanpelt
Domoticz version: 3.8153
Post by jeroenvanpelt » Sunday 17 December 2017 11:54
georgesattali wrote:Hello,
GD
If you mean notification type plays, you cannot initiate that from Domoticz.
I have seen google-home-notifier, but you could also try a cli script that allows you to start a sound cast to the Google Home, as if you were chromecasting (chromecast-cli).
Sent from my Pixel 2 XL using Tapatalk
Domoticz latest stable - RaspberryPi 2 B - MySensors - Controlicz - Google Home - RFLink (w/MiLight)
HarryHase
Post by HarryHase » Sunday 17 December 2017 12:20
Hi, is there actual a problem on controlicz.com?
i can connect from outsite via http and https but contolicz sayed
Controlicz is unable to connect - please check your config
alanlsmith
Domoticz version: Latest β
Post by alanlsmith » Sunday 17 December 2017 13:39
You can use a switch in Domoticz to trigger a node-red flow which can in turn speak a notification based on the switch state via a Google Home.
Last edited by alanlsmith on Monday 18 December 2017 4:04, edited 1 time in total.
Domoticz Latest β, Ubuntu 18.04 on Intel NUC i3, 8Gb ram, 70Gb drive, RFXtrx433, z-wave and a bit of Broadlink/Android
HarryHase
Post by HarryHase » Sunday 17 December 2017 16:19
It comes back working ... spooky ..
sandervanpelt
Domoticz version: 3.0.8564
Post by sandervanpelt » Sunday 17 December 2017 16:26
Hi Madgeni,
I just registered. Can you please add me to your beta program?
My email is my forum username @gmail.com
Thanks,
Sander
vboulaye
Post by vboulaye » Sunday 17 December 2017 23:17
Hello Madgeni,
I registered on the controlicz website and would like to try the google home beta integration if possible.
My email is also my forum username at gmail.
Thanks,
Vincent
Vens
Post by Vens » Monday 18 December 2017 9:41
Hi Madgeni,
Can you add me to the beta program as well, my email address is arj**ven******@ gmail.com. And how can I add controlicz to google assistant?
Thnx!
Noka
Post by Noka » Monday 18 December 2017 16:37
Hi Madgeni!
Controlicz test say it unable to connect but it work for almost everythings except xiaomi smart plug. I don't understand why. Everythings are right on your side?
Madgeni
Post by Madgeni » Monday 18 December 2017 17:25
yes, the test is broken - going to remove it whilst i debug.
What's wrong with the xiaomi plugs? Not discovered at all?
Native Alexa skill and Google app - register at https://www.controlicz.com
Noka
Post by Noka » Monday 18 December 2017 18:37
It discovered but when I command it by google it work but not every time.. it's strange. I need to repeat several times the command.
Madgeni
Post by Madgeni » Monday 18 December 2017 18:38
ok that is strange!
Noka
Post by Noka » Monday 18 December 2017 18:56
Yep, and I don't know why. I search some technics, rename it etc.. on the google side it work but not in domoticz.
fergalom
Post by fergalom » Monday 18 December 2017 19:35
perhaps someone can help
S7 with 6.01 - home and assistant installed
Joined the controllicz beta
the controllicz "app" is not showing up on assistant when I ask it to "talk to controllicz" "talk to homecontrollicz" or "turn on my lights"
Any pointers? kinda driving me nuts now
jeroenvanpelt
Post by jeroenvanpelt » Monday 18 December 2017 19:36
fergalom wrote:perhaps someone can help
Have you signed up for the beta test?
fergalom
Post by fergalom » Monday 18 December 2017 19:37
thanks yes, signed up and enabled on the google actions page
jeroenvanpelt
Post by jeroenvanpelt » Monday 18 December 2017 19:39
fergalom wrote:thanks yes, signed up and enabled on the google actions page
Hmm, same Gmail account I assume?
tohn
Post by tohn » Monday 18 December 2017 19:48
Discovered that Google home can broadcast messages.
Would this function work with this integration to domoticz?
Madgeni
Post by Madgeni » Monday 18 December 2017 21:15
so it's not showing up under settings>Home Control?
demon1977
Post by demon1977 » Monday 18 December 2017 23:29
Hi Madgeni, I just registered on Controlicz, my email demon****@gmail.com
Can you add me?
Thanks a lot!
