Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Target OS: Raspberry Pi
Post by Madgeni » Saturday 26 May 2018 11:59
Venzent wrote:
Saturday 26 May 2018 11:22
Set the phone to US English
Open the Google Home app
Via the menu go to "Home Control"
Click the "+" sign, under "Add new" you should see "Controlicz"
Thanks Venzent :)
Native Alexa skill and Google app - register at https://www.controlicz.com
clubeddie
Post by clubeddie » Saturday 26 May 2018 12:23
Thank you! That did the trick!
Venzent
Domoticz version: 3.8153
Post by Venzent » Saturday 26 May 2018 12:32
Great, nice I could do something back after receiving so much support ;-)
clubeddie
Post by clubeddie » Saturday 26 May 2018 20:39
I got it working. I was wondering, in controlicz I see al my devices from my floorplan. This contains switches and other devices. The switches are read in within Google home. Devices of other types not. Is this correct and is there no support for (yet) inside Google home.
It would be awesome to connect to other devices as well. For example, I have solar panels and it would be great if I as Google "how are my solar panels doing" that's see tells me what the production is. The numbers are inside domoticz.
But this is not yet possible or have I configure something wrong? Or is there another way of doing this?
Madgeni
Post by Madgeni » Saturday 26 May 2018 20:42
Hi -
currently Controlicz can handle Switches/lights/Thermostats - vacuums to come shortly.
If Google add solar panels/electricity producing devices, i'll make sure it's in Controlicz
HarR
Post by HarR » Sunday 27 May 2018 9:34
Madgeni wrote:Hi -
You can also query temperature sensors. Although it will be seen as a thermostat in the off state, it will tell you the temperature.
Sent from my iPad using Tapatalk
clubeddie
Post by clubeddie » Sunday 27 May 2018 9:39
Hi -
Won't think it will be implemented at Google very soon :-)... It is only a value that the device must read and speech. Maybe a third party tool or something within ifttt? If I find something I will let you know.
Madgeni
Post by Madgeni » Sunday 27 May 2018 19:46
That's why it's likely to be added! If it's just a reading, then it's likely. Out of interest, in your Devices tab in Domoticz, what's it's Type/SubType?
clubeddie
Post by clubeddie » Sunday 27 May 2018 19:55
I make use of a custom sensor so i can calculate the cost of my energy consumption.
This is type General, subtype text.
For my solar panel i use a Youless device.
Type Youless meter, subtype Youless counter.
Madgeni
Post by Madgeni » Monday 28 May 2018 17:21
so it's the Custom sensor you want to query? What's the image you use out of interest?
Madgeni
Post by Madgeni » Monday 28 May 2018 17:22
Camposmansi wrote:
Tuesday 22 May 2018 7:58
Madgeni wrote:
Friday 11 May 2018 19:38
hi - launch Google Assistant/Home - Explore - search for Controlicz
https://assistant.google.com/services/a ... 7068b18ba2
No results found for Controlicz
Had it confirmed by Google, it's a general bug with the Italian Directory. They're looking into it, but no ETA
clubeddie
Post by clubeddie » Monday 28 May 2018 17:39
Lazyness :lol: , i think it kinda fun to ask google "How are my solar panels doing" she said, the production so far for today is 10.51 kWh.
Also, what are the cost of the gas consumption today... that kinda stuff.
If it can, i can use this. If not, i use my phone.
mraichura
Post by mraichura » Tuesday 29 May 2018 3:59
Hi Nick,
I want to use a Text sensor to get the status for my Water Tank Level sensor. The sensor is populated using Node-Red via MQTT based on values of 2 float switches (OHH & OHL). However, I've only shared access to my Water Tank Level sensor but I do not know if Google supports text sensors and how to query them. Any insights?
Thanks,
Mayank
1 x RASPBERRY PI 1 MODEL B+ running Domoticz since June 2016
1 x RASPBERRY PI 3 MODEL B running Domtoicz since August 2017
Madgeni
Post by Madgeni » Tuesday 29 May 2018 9:21
Hey Mayank :)
Currently the best I could do is treat it a as a temp sensor - so it would return the right value, but probably append it with "degrees" or similar.
nicky14
Post by nicky14 » Wednesday 30 May 2018 10:52
Hi Madgeni,
I've tried controlicz with Domoticz and Google Home Mini. All works fine but sometimes GH says that "controlicz is unreachable" a couple of time before understand the commands or else it says, for example, that it turn on/off a bulb but it doesn't. Any idea?
Madgeni
Post by Madgeni » Wednesday 30 May 2018 13:12
Hi there - that doesn't sound good! Can you email from your Controlicz profile, and i'll take a look - thanks
Madgeni
Post by Madgeni » Saturday 02 June 2018 18:11
Hi - if anyone experiences any issues, you may have to re-authenticate with Alexa/Google - I've been doing some Controlicz housework :)
HarR
Post by HarR » Saturday 02 June 2018 21:33
You mean remove and re-add Controlicz in the Google Home app?
NeoMod
Domoticz version: Latest β
Post by NeoMod » Sunday 03 June 2018 0:17
first of all than you very much for the hard work on Controlicz and Domoticz.
I’m a novice at this, so maybe I’m doing something wrong and hence I’d like to ask your advice.
I have a single device in Domoticz, a light switch, which works perfectly fine.
EDIT:
To clarify, it is a "virtual device" actually controlling a SonOff Tasmota via Mosquitto.
I can also access Domoticz via HTTPS and control my device, so no problems (as far as I can see) with communications.
I registered and account on Controlicz and successfully connected to my Domoticz: I can see the “Success” status message upon testing connection, and I have the incoming connection log on Domoticz.
The problem is – apparently – that Controlicz can’t see my device: I did all the required steps (created a Floorplan an added the device to it and named the device “controlicz:light”) but it won’t appear under My Devices on Controlicz.
Obviously – and I guess this is normal now – If I try to add Controlicz to my Google Assistant account It will not retrieve my device.
I hope you help me understand what I’m doing wrong.
Thank you in advance!
maxtrash
Post by maxtrash » Sunday 03 June 2018 0:43
good to get confirmation that it wasn't my setup failing.
that's what I did and it worked
Users browsing this forum: mark.sellwood and 1 guest
