Dashticz - Function - Trigger action on specific value
Moderators: robgeerts, htilburgs
EdwinK
Target OS: Raspberry Pi
Domoticz version: Stable
Re: Dashticz - Function - Trigger action on specific value
Post by EdwinK » Monday 26 June 2017 10:13
I use idx 'XX_1' for the first and 'XX_2' for the second
Running latest BETASTABLE on a Pi-3 | Toon® Thermostat (rooted) | RFxcom | Dashticz V2
htilburgs
Post by htilburgs » Monday 26 June 2017 10:44
Can you try changing Data into Temp (in your Config.js code)?
Hardware:
woody4165
Post by woody4165 » Thursday 14 September 2017 11:07
This is a very powerful feature, just discovering.
I would like to color the Netatmo Thermostat SetPoint when boiler is on, so when SetPoint Temp is higher than Temp measured by sensor.
The two values are a different.
From SetPoint I can use
"Data" : "18.0",
"SetPoint" : "18.0",
From Sensor I can use
"Data" : "23.2 C",
"Temp" : 23.199999999999999,
What kind of comparison I can use ?
I'm a little bit confused...
Wob76
Post by Wob76 » Monday 08 January 2018 6:36
Just wondering if it is possible to use getstatus to monitor a User Variable from Domoticz? I am using a few User Variables in scripts and would like to colour some tiles based on those variables status, if not I'll have look at incorporating some switches into the scripts.
Thanks,
Wob
robgeerts
Domoticz version: 3.7067
Post by robgeerts » Monday 08 January 2018 22:54
I think you need switches with the value of the user-variable.
BUT, I think you can hide these switches so you wont see them ;)
Something like (if the switch you want to check is 1 and block you want to colour is idx 2)
function getStatus_1(idx,value,device){
	$('div.block_1').hide();
		if(device['Data']=='somevalue'){
			$('div.block_2').addClass('warning');
		else {
			$('div.block_2').removeClass('warning');
Creator of Dashticz
Do you appreciate my work and want to buy me a beer?
Send:
- XVG to D8fwNbyV6YxJk1aSiXftWTtdaPipsKn2Fa
- ANY ERC20-TOKEN to 0x9b8ee84329d77765a28bca188218c6c793875a8a
or donate via PayPal: https://www.paypal.me/robgeerts
Wob76
Post by Wob76 » Tuesday 09 January 2018 3:47
Thanks, I thought that might be the case, I have plenty of other hidden switches :) and the user variable is just a 0/1 state, so easy enough to change it to use switches.
Wob76
Post by Wob76 » Tuesday 09 January 2018 7:18
Ok, my problem now is that I want to have the switch hidden in Domoticz, so prefix it with a $, but it seems these switches are filtered upstream somewhere and will not show in Dashticz, is there a way to have it hidden in both interfaces?
DewGew
Domoticz version: V4.9741
Post by DewGew » Tuesday 09 January 2018 12:16
I place my hidden devices in a hidden room also. Now you can only find theese device under settings/devices and room manager. You create hidden room with name starts with $ (eg. $roomtohide).
Raspberry Pi 2B - domoticz - Aeon Labs Z-Stick GEN5 - RFlink gateway
NanoPi NEO-air - domoticz - REGO6XX interface
Dashticz V2 - Homebridge
Wob76
Post by Wob76 » Tuesday 09 January 2018 12:33
Thanks for the tip, I have done that in past, but for some reason Domoticz is no longer hiding devices in hidden rooms from my All tab, I'll have to investigate.
Update:
Maybe a bug in the beta versions of Domoticz, and new room I create with a $ doesn't seem to work, devices in those rooms still show in the All Room, I have a few old ones that seem to work, but only for the devices already in there, if I add a new device to one it still shows in All. :(
I tried adding the devices into "$Hidden Devices" and removing the $ from the name, but again they are filtered from Dashticz,the above code works if I move it out of $Hidden Devices, But I do have to have the switch configured for a row and then hide it.
Users browsing this forum: moses123, RichardvdWeerd and 3 guests
