Dashticz - Module - Garbage collector
Moderators: robgeerts, htilburgs
aiolos
Target OS: Raspberry Pi
Domoticz version: stable
Re: Dashticz - Module - Garbage collector
Post by aiolos » Wednesday 10 January 2018 18:12
Moosjes wrote:
Wednesday 10 January 2018 17:59
Moosjes wrote:
Wednesday 10 January 2018 15:32
I have added the Garbage calander of Veldhoven to my Dashticz but all I get in the dashboard is 'Laden...'
I found the sollution to my own problem. I had selected the company 'Veldhoven' instead of 'veldhoven' (mind the capital V). After changing this it still did not work.
After I changed the company to 'ical' it worked :D
But then you're using config['garbage_icalurl'] and not config['garbage_zipcode'] and config['garbage_housenumber']? Zipcode and housenumber are used by the veldhoven parser.
Contributor to Dashticz
More on my Github profile
AndreFR
Post by AndreFR » Wednesday 10 January 2018 20:07
robgeerts wrote:
Monday 08 January 2018 22:30
Hmm indeed, we cannot use the afvalkalender.container-beheer.nl website.
But I've read on the website of Rotterdam that you should be able to use mijnafvalwijzer.
Try choosing this in dashticz-settings and enter your zipcode and house number.
Hi Rob/aiolos,
I’ve requested to have our city to be included to the ‘mijnafvalwijzer.nl’ website, it works if I use another ‘postcode’....
jake
Post by jake » Thursday 11 January 2018 23:25
htilburgs wrote:When using config['garbage_icon_use_colors'] = false; in your config.js, no icon is showed.
When checking I think the problem is:
<img class="trashcan" src="img/kliko.png" style="opacity: 1;">
While it should be img/trashcan/kliko.png
garbage.js needs an update. Indeed kliko.png has moved, but not yet in the code.
instead of "img/kliko.png", it should be "img/garbage/kliko.png"
EdwinK
Post by EdwinK » Thursday 11 January 2018 23:32
Was just going to post about this :)
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
aiolos
Post by aiolos » Friday 12 January 2018 14:53
Thanks for noticing. I made a PR to fix it.
geertvercamer
Post by geertvercamer » Friday 12 January 2018 16:39
There is a problem with the 'ophaalkalender' method for Belgium.
In the function mapGarbageType() a mapping is done from 'blue' to 'papier', however that should be 'PMD (line 350)'. 'brown' should map to 'papier'
In my region we only have 'pmd', 'restafval' and 'p-k', but there are more in ie. Gent:
- GFT: green
- Glas: yellow
- Grof huisvuil afroep: purple
- Kerstboom: lightgreen
- P-K: brown
- PMD: blue
- Restafval: grey
and it may be nice to have a config/setting variable for the date format.
Thanks.
EdwinK
Post by EdwinK » Friday 12 January 2018 16:47
I still miss a 'thank you' button :)
So, thank you
robgeerts
Domoticz version: 3.7067
Post by robgeerts » Saturday 13 January 2018 18:35
It's merged :)
Creator of Dashticz
Do you appreciate my work and want to buy me a beer?
Send:
- XVG to D8fwNbyV6YxJk1aSiXftWTtdaPipsKn2Fa
- ANY ERC20-TOKEN to 0x9b8ee84329d77765a28bca188218c6c793875a8a
or donate via PayPal: https://www.paypal.me/robgeerts
EdwinK
Post by EdwinK » Saturday 13 January 2018 21:12
Thanks again
maceddy
Domoticz version: 3.8153
Post by maceddy » Saturday 13 January 2018 22:16
Any chance you will implement 'Area Reiniging'?
http://www.areareiniging.nl/home/bewone ... -digitaal/
It shows a Calendar in some sort of frame and there is a possibility to download iCal, but I can not get it to work..
You may use my ZIP and house number (request per DM please :-) ) if you plan on testing it.
Regdul
Post by Regdul » Monday 15 January 2018 0:36
is there any change to add "de friese meren' garbage calendar? same as maceddy, i cant get it to work. there is an option for Ical
https://dfm.afvalalert.nl/#
thanks!
pkrabben
Domoticz version: 3.5877
Post by pkrabben » Monday 15 January 2018 12:57
Hi All,
De Garbage collector is not working anymore in Almere
can you add http://afvalportaal2.2go-mobile.com/mod ... /calendar/
Thanks In advance
aiolos
Post by aiolos » Tuesday 16 January 2018 1:44
Hi All,
Thanks In advance
Both these garbage collection calendars are added. See this PR
The garbage company configuration is:
config['garbage_company'] = 'area';
and
config['garbage_company'] = 'almere';
Please note that for Almere the GFT & Rest are combined, they show up as a green bin, this can of course be changed with selecting another bin for this type of garbage.
Both calendars use the same (or a very alike) API as 'Twente Milieu'. I expect more calendars are based on this API, which makes it very easy to add them.
I tested this with a random address in Emmen and Almere, please let me know if you experience any difficulties (after a merge of course, it is not in there yet)
I saw the 'De Friese Meren' request. Looks do-able, but I could not implement it in the short time I had available right now. I will look into it later.
pkrabben
Post by pkrabben » Tuesday 16 January 2018 12:09
Thanks Almere is working
EdwinK
Post by EdwinK » Tuesday 16 January 2018 19:25
Is it right that the colors of the trashbin's dont change anymore?
aiolos
Post by aiolos » Wednesday 17 January 2018 0:58
thanks!
In this PR the support for this garbage calendar is added.
Configuration:
config['garbage_company'] = 'afvalalert';
It is very likely this company also works for other regions than 'De Friese Meren'
It does with my config (which is pretty standard for development) For various garbage companies and addresses I saw different colours of bins.
robgeerts
Post by robgeerts » Wednesday 17 January 2018 10:20
PR is merged! :)
Creator of Dashticz
Send:
EdwinK
Post by EdwinK » Wednesday 17 January 2018 11:01
Then I've to look through all the settings (again).
EdwinK
Post by EdwinK » Wednesday 17 January 2018 11:29
Looks there is something more happening.
As seen on https://www.mijnafvalwijzer.nl/nl/3161LH/27/ today is 'grof vuil' and on Friday we have 'rest'. But on dashticz it shows all the dates as 'rest'. Only 'gft' is changing colors in the text.
Part of config.js
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_icalurl'] = '0';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '3161LH';
config['garbage_street'] = 'Jonkerhof';
config['garbage_housenumber'] = '27';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = 2;
config['garbage_width'] = '6';
config['garbage_hideicon'] = '0';
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 1;
config['garbage_use_names'] = 1;
config['garbage_use_cors_prefix'] = '0';
//Afval
config['garbage'] = {
    gft: 	{kliko: 'green', 	code: '#375b23', name: 'GFT'},
//  pmd: 	{kliko: 'orange', 	code: '#db5518', name: 'PMD'},
    rest: 	{kliko: 'grey', 	code: '#5e5d5c', name: 'Restafval'},
    papier: {kliko: 'blue', 	code: '#153477', name: 'Papier'},
//  kca: 	{kliko: 'red', 		code: '#b21807', name: 'Chemisch afval'},
    brown: 	{kliko: 'brown', 	code: '#7c3607', name: 'Grof Vuil'},
//  black: 	{kliko: 'black', 	code: '#000000', name: 'Zwart'},
geertvercamer
Post by geertvercamer » Wednesday 17 January 2018 14:48
Maybe this has also something to do with this function mapGarbageType()?
Users browsing this forum: aiolos and 5 guests
