Dashticz - Module - Garbage collector
Moderators: robgeerts, htilburgs
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Module - Garbage collector
Post by robgeerts » Wednesday 08 November 2017 10:40
Good NEWS!
In latest Beta, the Rova-calendar should work, try these settings in config.js:
config['garbage_company'] = 'rova';
config['garbage_icalurl'] = '';
config['garbage_zipcode'] = '7731ZT';
config['garbage_street'] = '';
config['garbage_housenumber'] = '84';
config['garbage_maxitems'] = 5;
Creator of Dashticz
Do you appreciate my work and want to buy me a beer?
Send:
- XVG to D8fwNbyV6YxJk1aSiXftWTtdaPipsKn2Fa
- ANY ERC20-TOKEN to 0x9b8ee84329d77765a28bca188218c6c793875a8a
or donate via PayPal: https://www.paypal.me/robgeerts
EdwinK
Target OS: Raspberry Pi
Domoticz version: Stable
Post by EdwinK » Wednesday 08 November 2017 12:46
Yeah... there is a new beta :)
Running latest BETASTABLE on a Pi-3 | Toon Thermostat (rooted) | RFxcom | Dashticz V2 |
Back to stable for now, as beta ***** over my installation
marxkemp
Post by marxkemp » Wednesday 08 November 2017 17:47
Good NEWS!
I did a fresh beta clone into another folder
git clone https://github.com/robgeerts/dashticz_v2 --branch beta dashboard
The above config gives me a garbage block with "Loading"
New beta not released yet?
robgeerts
Post by robgeerts » Wednesday 08 November 2017 19:22
Weird, could you check console if it gives any error?
Or search in the network-tab to an url wich contains the string 'rova', click it and show me what you see ;)
Creator of Dashticz
Send:
marxkemp
Post by marxkemp » Wednesday 08 November 2017 22:08
I did another git pull, it updated garbage js and its working with my own zipcode. thank you
Gerald
Post by Gerald » Tuesday 14 November 2017 16:23
@Rob: You are truly a master sir!
It works like a charm!
pvm
Post by pvm » Wednesday 22 November 2017 23:27
Is it possible to mention the short names in the opening post like for 'Afval App' in the config you have to use 'deafvalapp'
Synology NAS, PI3, ZWave, Xiamo zigbee devices, BTLE plant sensor
pvm
Post by pvm » Wednesday 22 November 2017 23:32
I've found an issue with housenumbers with an additional letter, can you integrate the change below?
Code has been tested for Afval App and working correctly
I've fixed this by:
Adding an extra config parameter in config.js
config['garbage_housenumberadd'] = 'a';
Reading this new parameter in the top of garbage.js with (naming kept similar)
var homenumberadd = settings['garbage_housenumberadd'];
And adding this parameter to the services who can use this (like afvalapp in this example), in the old code the parameter was not filled
'&toevoeging=' + homenumberadd, function(data){
robgeerts
Post by robgeerts » Thursday 23 November 2017 10:09
Added in latest beta, could you test this?
If you get a blank page, please reply in the Bug report-topic.
Creator of Dashticz
Send:
pvm
Post by pvm » Thursday 23 November 2017 21:47
Hi Rob, tested latest beta, thnx, working fine
robgeerts
Post by robgeerts » Friday 24 November 2017 0:01
Nice :)
Creator of Dashticz
Send:
PeJeWe
Domoticz version: 3.5877
Post by PeJeWe » Monday 27 November 2017 22:08
I can't get it running the "HVC Groep" afval programma.
my settings in the CONFIG.js
config['garbage_company'] = 'HVC groep';
config['garbage_icalurl'] = 'http://inzamelkalender.hvcgroep.nl/maand';
config['garbage_zipcode'] = 'my zipcode';
config['garbage_street'] = 'my street';
config['garbage_housenumber'] = '17';
//Afval programma
var trashcan = {}
trashcan.hvc = { maxitems: 10, trashapp: 'hvc groep', width:12, zipcode:'******', housenumber:'17' }
var trashnames = {}
trashnames['Rest'] = 'Grijze bak';
trashnames['Gft'] = 'Groene bak';
trashnames['Pmd'] = 'Plastic';
trashnames['Papier'] = 'Blauwe bak';
var trashcolors = {}
trashcolors['Rest'] = 'Grey';
trashcolors['Gft'] = 'Green';
trashcolors['Pmd'] = 'Orange';
trashcolors['Papier'] = 'Blue';
when i push the button i get the "Domoticz offline" message
do i have to install something in domoticz?
I have done a git pull "beta" without succes.
robgeerts
Post by robgeerts » Tuesday 28 November 2017 0:16
When you push the button? Wich button?
Could you PM me your zipcode?
Creator of Dashticz
Send:
aiolos
Domoticz version: stable
Post by aiolos » Tuesday 28 November 2017 0:18
for hvc you can just use config['garbage_company'] = 'hvc';
With zipcode and housenumber you should get the calendar. The ical url is not necessary.
Contributor to Dashticz
More on my Github profile
aiolos
Post by aiolos » Tuesday 28 November 2017 18:07
A PR for changes in the garbage collection module has been created, so this will be merged soon. There are some changes related to the colouring and naming.
The following config options are new (and trashnames/trashcolors config is gone)
config['garbage'] = {
    gft: {kliko: 'green', code: '#375b23', name: 'GFT'},
    pmd: {kliko: 'orange', code: '#db5518', name: 'PMD'},
    rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval'},
    papier: {kliko: 'blue', code: '#153477', name: 'Papier'},
    kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval'},
    brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin'},
    black: {kliko: 'black', code: '#000000', name: 'Zwart'},
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
Within this config you can change the kliko color and color code of the lines in the block (color code only used if you enable the 'garbage_use_colors' config option). The name property is used if the 'garbage_use_names' option is enabled, otherwise the information from your garbage company will be used.
All various garbage company handling has slightly changed (but the outcome should not be different).
All garbage collection information that was fetched through an ical calender is now loaded directly through javascript (without the need of a php script, which was loaded externally).
A new option for google calendars is also added. The google calendar API can be used with a calendar id and api key (for creating an api key, see https://docs.simplecalendar.io/google-api-key/)
The new config options for google calendars:
config['garbage_company'] = 'googlecalendar';
config['google_api_key'] = 'YourOwnApiKey';
config['garbage_calendar_id'] = 'YourCalendarIdFoundInCalendarSettings@group.calendar.google.com';
If anyone experiences any weird behaviour after the update, let me know. (preferably with information like your garbage config settings)
EdwinK
Post by EdwinK » Tuesday 28 November 2017 20:26
Nice. Of course this means changing stuff again
aiolos
Post by aiolos » Tuesday 28 November 2017 20:45
Yeah, unfortunately. Especially if you have specific colouring. The garbage_company and address settings haven't changed, so for most people it should just work.
EdwinK
Post by EdwinK » Tuesday 28 November 2017 20:50
Trying to figure things out is not that bad. Already preparing :)
robgeerts
Post by robgeerts » Tuesday 28 November 2017 23:26
Merged and tested!
@aiolos, sent you a few beers via PayPal!
Creator of Dashticz
Send:
EdwinK
Post by EdwinK » Wednesday 29 November 2017 0:12
Thanks. Was just getting ready to go to bed, when I noticed the update. So, quickly pulled it, and running ;)
