Import weather data other than Wunderground
Moderators: robgeerts, htilburgs
RTJC
Post by RTJC » Tuesday 03 July 2018 15:24
allthough Wunderground doesn't work with free API's anymore, I still like the functionality of showing a forecast on my dashboard.
I currently use Darksky in Domoticz as a Virtual Weatherstation but I don't know how to import this into Dashticz.
Can anyone help me out?
Lokonli
Target OS: Raspberry Pi
Re: Import weather data other than Wunderground
Post by Lokonli » Tuesday 03 July 2018 18:59
Alternatives:
Use forecast.io in a frame like:
var frames = {}
frames.weather = {refreshiframe:300000,height:230,frameurl:"//forecast.io/embed/#lat=49.2624&lon=-123.1155&name=Vancouver&color=#00aaff&font=Helvetica&fontColor=#ffffff&units=si&text-color=#fff&",width:12}
or use OpenWeatherMap. Support has been recently added to the beta of dashticz:
//weather new OWM
config['owm_api'] = 'xxx';
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = '';
config['owm_country'] = 'de';
config['static_weathericons'] = 1;
columns[2] = {}
columns[2]['width'] = 6;
columns[2]['blocks'] = ['currentweather_big_owm','weather_owm'];
You cannot use OWM and Wunderground simultaneously.
RTJC
Post by RTJC » Wednesday 04 July 2018 14:58
Hi, how can I make the forecast.io frame in the Dutch language?
It looks very good by the way!
EdwinK
Post by EdwinK » Wednesday 04 July 2018 16:48
Add this to the url you used
lang=[language] optional
Return summary properties in the desired language. (Note that units in the summary will be set according to the units parameter, so be sure to set both parameters appropriately.) language may be:
en: English (which is the default)
nl: Dutch
in your case add lang=[nl] You need to do some digging in the Dashticz-files though
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
Derik
Post by Derik » Monday 13 August 2018 21:15
is there someone that have a windchill sensor or data can make a windchill?
Post by waaren » Tuesday 14 August 2018 10:03
Derik wrote:is there someone that have a windchill sensor or data can make a windchill?
Windchill is just the result of a formula with temperature and windspeed as factors.
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
Derik
Post by Derik » Tuesday 21 August 2018 8:32
I now...
Only what i look is a device that give me the chill in a sensor..
I have multiple weather data sensors
Only no separate windchill device..
Looks great on my dashboard.
windchill -10: kids need warmer clothing's
Post by waaren » Tuesday 21 August 2018 9:28
I now...
I can build a dzVents script if you give me the names of your outside temperature device and the name of your windspeed device.
btw: did you reload the dzVents script for the months and got it working ?
Derik
Post by Derik » Tuesday 21 August 2018 23:18
I now...
Nope months scripts not working unfortunately..
How do you want my data?
pm or?
When you install the buienradar plugin you get a windchill perhaps you can split this data also?
Temp:
Wind:
Post by waaren » Tuesday 21 August 2018 23:29
I now...
Script to get windChill from temperature- and windSpeed device
-- setWindChill.lua
    on      =   {   timer  =   { "every 10 minutes" }}, -- the script will run every 10 minutes
--   logging =   {   level       =   domoticz.LOG_DEBUG,   -- this sets the loglevel. Options are LOG_INFO, LOG_DEBUG, LOG_ERROR or LOG_FORCE
--                   marker      =  "setWindchill" },    -- the marker will ensure you can see where information comes from
    execute = function(dz)  -- the parm dz (short for domoticz) will ensure all information from domoticz is available in this script
        -----  enter your settings below this line -------------------------------------------------------------------------------
        myTemperature   = dz.devices("Buiten: Terras")          -- Name of your windDevice within quotes or idx without quotes
        myWind          = dz.devices("D.M.: Buienradar - Wind") -- Name of your temperatureDevice within quotes or idx without quotes
        myWindChill     = dz.devices("new Windchill")          -- Name of your windchill Device within quotes or idx without quotes
        -----  enter your settings above this line -------------------------------------------------------------------------------
        function windChill(windSpeed, temperature)
           if temperature ==   nil then return -99     -- Should not happen
           elseif windSpeed == nil then return -99     -- Should not happen
            -- chill temperature cannot be calculated for these conditions
           elseif windSpeed < 1.3 or windSpeed > 49 or temperature < -46 or temperature > 17 then return temperature
           return dz.utils.round(13.12 + (0.6215 * temperature) - (13.96 * math.pow(windSpeed, 0.16)) + (0.4867 * temperature * math.pow(windSpeed, 0.16)), 1)
        myWindChill.updateTemperature(windChill(myWind.speed,myTemperature.temperature))
Derik
Post by Derik » Wednesday 22 August 2018 15:28
-- setWindChill.lua
Thanks...
Zou ergens iets met afronden kunnen zijn??
And how do you calculate this chill?Is this a formula that is normal used by more weather stations??
Works:
And is it perhaps possible that u send the calculate value to a text device
Something like:
The windchill is now -25 degrees [ where -25 the value is @ that moment ] [ Or in NL: De winchill is nu -25 graden ]
Post by waaren » Wednesday 22 August 2018 22:18
Thanks...
Yes. See new code below
Using the JAG/TI-method https://nl.wikipedia.org/wiki/Gevoelstemperatuur
Something like:
-- setWindChill.lua
        myTemperature   = dz.devices("Buiten: Terras")          -- Name of your temperatureDevice within quotes or idx without quotes
        myWind          = dz.devices("D.M.: Buienradar - Wind") -- Name of your windDevice within quotes or idx without quotes
        myWindChillTemp = dz.devices("new Windchill")           -- Name of your windchill temp Device within quotes or idx without quotes or remove line completely if no temp device
        myWindChillText = dz.devices("windChillText")           -- Name of your windchill text Device within quotes or idx without quotes or remove line completely if no text device
           return 13.12 + (0.6215 * temperature) - (13.96 * math.pow(windSpeed, 0.16)) + (0.4867 * temperature * math.pow(windSpeed, 0.16))
        local windChill = dz.utils.round(windChill(myWind.speed,myTemperature.temperature))
        if myWindChillTemp then
            if myWindChillTemp.temperature  ~= windChill then
                myWindChillTemp.updateTemperature(windChill)
        if myWindChillText then
             local windChillText = "De windchill is nu "  .. windChill .. " graden."
             if myWindChillText.text ~= windChillText then
                 myWindChillText.updateText(windChillText)
Derik
Post by Derik » Thursday 23 August 2018 6:25
Dear Waaren..
Realy nice to see how you fix this..
The text is running also...
Only one thing
Probably your formula is wrong??
The chill is the same like outside temp..
And my other sensors give a different chill then your code:
Yours:
So perhaps you can check?
edit:
The script is not running for more the a half hour.,,,
So where do i go wrong?
Post by waaren » Thursday 23 August 2018 9:11
Hi Derik,
In the edited script below, I switched on debug logging so if you can check again and look at the relevant loglines (the ones with the text "setWindchill" in it)
I doublechecked the formula and it should report the windchill temp calculated using the JAG/TI-method JAG/TI-method
Please note that according to this JAG/TI calculation the windchill temperature is equal to the standard temperature for temperatures > 17 Celsius and for windspeeds < 1.3 meter/second.
Also the script does not update the textdevice if the windChill temperature has not changed in the last 10 minutes.
-- setWindChill.lua
        local function windChill(windSpeed, temperature)
                return temperature
        dz.log("windspeed: " .. myWind.speed .. ", temperature: " .. myTemperature.temperature,dz.LOG_DEBUG)
        local calculatedWindChill = dz.utils.round(windChill(myWind.speed,myTemperature.temperature))
                myWindChillTemp.updateTemperature(calculatedWindChill)
             local windChillText = "De windchill is nu "  .. calculatedWindChill .. " graden."
Toulon7559
Domoticz version: latest
Post by Toulon7559 » Thursday 23 August 2018 12:33
Is Accuweather as Device an alternative, optional source for your info?
Set1 = RPI-B+RFXCom433+S0PCM+Linksprite-shield for BMP180/DS18B20/RS485+DDS238-1ZN
Set2 = RPI-3+RFLinkGTW+ESP8266s+PWS_WS7000
Common = 3*PVLogger+PWS_TFA_Nexus+KAKUs
=> Energy & Data Management based on Time and on PV&Consumption&Meteo
Derik
Post by Derik » Saturday 25 August 2018 22:17
Dear waaren
Thanks for the great script!!!
Works fine until now...
Hope i can do sometime something for you!!!
xxx
Users browsing this forum: Wheeling and 2 guests
