Dashticz - Function - RGB-support
Moderators: robgeerts, htilburgs
robgeerts
Domoticz version: 3.7067
Re: Dashticz - [BETA]Function - RGB-support
Post by robgeerts » Thursday 13 July 2017 16:32
Ok, didnt test with multiple lights (bought one for testing purposes, not 2 :P)
Hold on, will try to fix it!
Creator of Dashticz
Do you appreciate my work and want to buy me a beer?
Send:
- XVG to D8fwNbyV6YxJk1aSiXftWTtdaPipsKn2Fa
- ANY ERC20-TOKEN to 0x9b8ee84329d77765a28bca188218c6c793875a8a
or donate via PayPal: https://www.paypal.me/robgeerts
EdwinK
Target OS: Raspberry Pi
Post by EdwinK » Thursday 13 July 2017 16:57
I only have two because of Eneco's offer last year.
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
ztorm
Domoticz version: 3.8153
Re: Dashticz - Function - RGB-support
Post by ztorm » Wednesday 02 August 2017 21:34
Is is possible to remove the color selector? I have white HUE lamps so I don't need the selector.
robgeerts
Post by robgeerts » Wednesday 02 August 2017 21:43
The color selector should only appear if you configurated it as a RGBW-bulb in Domoticz?
Creator of Dashticz
Send:
ztorm
Post by ztorm » Thursday 03 August 2017 8:21
The problem is, I have two Hue lamps (white) above my kitchen table that I want to control (dim, on/off) together with one dimmer switch. I made a group of the two lamps in a Hue-app and apparently Domoticz imports the group as a RGBW-type. I'm tying to figure out if it's possible to change that or to make a dimmer switch in Domoticz which controls both lamps.
freakshock
Post by freakshock » Sunday 06 August 2017 16:28
I noticed RGB support only seems to work for Milight bulbs with type RGBW in Domoticz.
Type RGBWW (v6 of the protocol) does not give me a color selector switch in Dashticz.
'Hal licht' is the only RGBW bulb I have, the others are a RGBWW (v6) type.
EDIT: Fixed by Rob now! :)
robgeerts
Post by robgeerts » Sunday 06 August 2017 16:32
Could you send me the json-output of domoticz?
Creator of Dashticz
Send:
freakshock
Post by freakshock » Sunday 06 August 2017 17:06
Sent via PM!
perkonix
Post by perkonix » Saturday 12 August 2017 14:19
I also experience the issue of having a RGB selector for a Hue group containing only ambiance (RGBWW) lights. I guess there is an issue with Domoticz not choosing the correct type as domoticz says the group is RGBW instead of RGBWW. A single light from the group doesn't get the RGB selector.
The slider is functional in dashticz. But the color selector is not useful and I'd like to get rid of it.
I also added commented on this issue here: https://github.com/domoticz/domoticz/issues/1202 I hope it can be in Domoticz itself. But for now, is there a workaround to hide it from dashticz?
Screen Shot 2017-08-12 at 13.58.27.png (98.19 KiB) Viewed 2011 times
Screen Shot 2017-08-12 at 14.15.23.png (49.45 KiB) Viewed 2011 times
freakshock
Post by freakshock » Monday 14 August 2017 20:11
Rob temporarily removed the RGB colorpicker in the latest beta, so that's a solution until a better solution is found!
dutchdevil83
Domoticz version: latest
Post by dutchdevil83 » Wednesday 16 August 2017 21:10
mmm that`s why my color selector isn`t showing :lol:
hope this function is back soon...
maybe idea to make a changelog when putting beta`s online?
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
Frankieg60
Post by Frankieg60 » Wednesday 25 October 2017 14:28
Any news of the color selector? i would love to use it.
Swifty
Post by Swifty » Wednesday 15 November 2017 15:17
Is the RGB selector still absent in Dashticz? - I've had a look through the github commits and can't see anything relevant, but wanted to check..
I will be rebuilding my dashboard later, so interested to know if this is working yet! :)
robgeerts
Post by robgeerts » Wednesday 15 November 2017 21:58
I disabled it because there were some complaints, but you can test it when opening main.js en search for (twice):
removeRGBW
AND
removeRGBWW
You have to remove 'remove' ;)
Creator of Dashticz
Send:
Swifty
Post by Swifty » Friday 17 November 2017 17:34
Thanks Rob, I will manually enable it for now and see how it performs :)
Are there any plans to re-add a new version at any point?
htilburgs
Post by htilburgs » Friday 17 November 2017 17:52
I've tested this option also in combination with Yeelight RGB LED (Wifi).
Works fabulous!!
Hardware:
robgeerts
Post by robgeerts » Friday 17 November 2017 23:17
Well, I'm not sure what the real complaints were..
If some people could test this too and share their results, please!
Creator of Dashticz
Send:
gijsje
Domoticz version: Stable
Post by gijsje » Friday 17 November 2017 23:25
Works good for me with mylight
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
robgeerts
Post by robgeerts » Friday 17 November 2017 23:42
Ok, please wait a day too see if it causes any loading problems (slowing things down)
I'll turn it on tomorrow of it seems ok :)
Creator of Dashticz
Send:
htilburgs
Post by htilburgs » Saturday 18 November 2017 12:16
Until now no loading / slowing things down issues. Still working ok.
Maybe you can use a parameter, like config['use_rgb']=0 / 1 for showing or not??
Hardware:
Users browsing this forum: No registered users and 4 guests
