Moderators: robgeerts, htilburgs
FrankDutch
Target OS: Raspberry Pi
Re: connection problem
Post by FrankDutch » Tuesday 14 November 2017 18:26
i have tried that but it doesn't work. no popup
the trange thing is that when i put the config.js in the notworking state the i get the connection with Domoticz
the ipad don´t get a connection either way (it is an ipad 1)
robgeerts
Domoticz version: 3.7067
Post by robgeerts » Tuesday 14 November 2017 21:02
What type of login did you enter in Domoticz (Settings), shoudl be Basic Authentication...
Creator of Dashticz
Do you appreciate my work and want to buy me a beer?
Send:
- XVG to D8fwNbyV6YxJk1aSiXftWTtdaPipsKn2Fa
- ANY ERC20-TOKEN to 0x9b8ee84329d77765a28bca188218c6c793875a8a
or donate via PayPal: https://www.paypal.me/robgeerts
aiolos
Domoticz version: stable
Post by aiolos » Tuesday 14 November 2017 21:42
evandenboom wrote:
Tuesday 14 November 2017 17:21
Thanks for the quick response. But unfortunately still no icon.
Use
blocks['64_2']['icon'] = 'fa fa-sun-o';
(Note the extra fa)
Looks like there is a small bug in this. I might look into it later, right now I have quite some changes in the whole graphs stuff. I noted some missing units (so displaying '?') and some more small issues.
Contributor to Dashticz
More on my Github profile
FrankDutch
Post by FrankDutch » Tuesday 14 November 2017 23:03
then i get the popup on the tablet but there is no connection with Domoticz. No buttons
robgeerts
Post by robgeerts » Tuesday 14 November 2017 23:15
Maybe I can assist you tomorrow via Teamviewer?
Creator of Dashticz
Send:
FrankDutch
Post by FrankDutch » Tuesday 14 November 2017 23:21
that is alright
we kan talk Dutch then lol
tommorow evening i have to work tomorrow
evandenboom
Post by evandenboom » Tuesday 14 November 2017 23:50
@aiolos Thank you. That was the tip I needed. Seems to work fine.
siklosi
Dashticz on tablet in fullscreen
Post by siklosi » Wednesday 15 November 2017 13:11
I was looking for solution to put Dasthicz in fullscreen on tablet and all solutions I found were not free or not working as I would like. Then I started googling if it's possible to put using metatag or script and found working solution. It can be implemented on some better way in Dashticz maybe through config or... there is downside when using this method that it has to be user initiated (button or keypress...) I edited index.html body tag to include onload of custom function and added script that adds keypress or click listener anywhere on page so basicly when i start dashticz (added to home screen through chrome) and press anywhere on screen Dashticz goes to fullscreen. If you want to exit you need to drag from top and than when buttons are visible you press back. Here is code for fullscreen:
<body id="page-top" onload="goFullscreen();">
    <script type="text/javascript">
    function goFullscreen() {
        function eventforfullscreen() {
            document.documentElement.webkitRequestFullScreen(); // Must be called as a result of user interaction to work
        document.documentElement.onclick = eventforfullscreen;
        document.onkeydown = eventforfullscreen;
    </script>
EdwinK
Re: Dashticz on tablet in fullscreen
Post by EdwinK » Wednesday 15 November 2017 15:06
Screen Shot 2017-11-15 at 14.05.33.png (10.61 KiB) Viewed 572 times
Isn't this button not doing the same?
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
siklosi
Post by siklosi » Wednesday 15 November 2017 15:10
Probably but I have not seen that button and still don't know where it is :(
EdwinK
Post by EdwinK » Wednesday 15 November 2017 15:13
I just have 'fa-sun-o' without the need of an extra 'fa' tag.
siklosi
Post by siklosi » Wednesday 15 November 2017 15:20
OK I see it's in beta.
aiolos
Post by aiolos » Wednesday 15 November 2017 16:57
Exactly, I just implemented that a few days ago :)
It indeed needs user interaction, luckily I would say, since otherwise websites could just go fullscreen by themselves.
aiolos
Post by aiolos » Wednesday 15 November 2017 16:59
Is that in a block without an underscore?
EdwinK
Post by EdwinK » Wednesday 15 November 2017 18:02
It is indeed in one without an underscore.
aiolos
Post by aiolos » Wednesday 15 November 2017 19:58
A fix for this is available in the pull request I just made.
EdwinK
Post by EdwinK » Wednesday 15 November 2017 20:02
I'll wait till Rob has included it in his beta
robgeerts
Post by robgeerts » Wednesday 15 November 2017 21:47
Check latest beta :)
Creator of Dashticz
Send:
woody4165
Post by woody4165 » Wednesday 15 November 2017 21:57
Thanks @robgeerts
Now the graph work and shows temp and hum.
But not for all sensors... :? :roll:
I have these two sensors, first is an ESP8266 with ESPEasy with a DHT11
  "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "12.0 C, 25 %",
         "Description" : "",
         "DewPoint" : "-7.45",
         "Favorite" : 1,
         "HardwareID" : 14,
         "HardwareName" : "various",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveTimeout" : false,
         "Humidity" : 25,
         "HumidityStatus" : "Normal",
         "ID" : "140CD",
         "LastUpdate" : "2017-11-15 20:51:11",
         "Name" : "TempPatio",
         "Notifications" : "false",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "THGN122/123, THGN132, THGR122/228/238/268",
         "Temp" : 12.0,
         "Timers" : "false",
         "Type" : "Temp + Humidity",
         "TypeImg" : "temperature",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "xxx"
and the second is the Netatmo Temp
    "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 96,
         "CustomImage" : 0,
         "Data" : "20.4 C",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "HardwareName" : "Netatmo",
         "HardwareType" : "Netatmo",
         "HardwareTypeVal" : 54,
         "ID" : "1AC7",
         "LastUpdate" : "2017-11-15 20:42:38",
         "Name" : "NetatmoTemperatura",
         "PlanID" : "2",
         "PlanIDs" : [ 2, 8 ],
         "SignalLevel" : 10,
         "SubType" : "LaCrosse TX3",
         "Temp" : 20.399999999999999,
         "Timers" : "false",
         "Type" : "Temp",
         "Unit" : 199,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "xxx"
In both case I see this kind of window:
Sorry to bother you!!! :)
aiolos
Post by aiolos » Wednesday 15 November 2017 22:06
Good to hear it works, partly ;)
I also have a device with sort of that issue, that one has no data for the selected period, however, it looks like you have selected the last month, so that should have some data I can imagine.
Does one of the buttons give a result? And what does the same sensor look like in Domoticz itself? I'll investigate also my own device, see if I can find out more.
