Plugins are disabled?
Quax1507
Target OS: Raspberry Pi
Re: Plugins are disabled?
Post by Quax1507 » Tuesday 16 January 2018 14:27
I'm on Stretch. Just updated to 8809.
Python plugins crash immediately :(
Quax1507
Post by Quax1507 » Tuesday 16 January 2018 15:13
Success!
Removed python3.5* and libpython3.5*
At least no immediate crash after startup!!! :D
Looks like that at the moment:
libpython-dev/stable,now 2.7.13-2 armhf [installed,automatic]
libpython-stdlib/stable,now 2.7.13-2 armhf [installed,automatic]
libpython2.7/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython2.7-dev/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython2.7-minimal/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython2.7-stdlib/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython3.4/stable,now 3.4.4-3 armhf [installed,automatic]
libpython3.4-dbg/stable,now 3.4.4-3 armhf [installed]
libpython3.4-dev/stable,now 3.4.4-3 armhf [installed,automatic]
libpython3.4-minimal/stable,now 3.4.4-3 armhf [installed,automatic]
libpython3.4-stdlib/stable,now 3.4.4-3 armhf [installed]
python/stable,now 2.7.13-2 armhf [installed]
python-apt/stable,now 1.1.0~beta5 armhf [installed]
python-apt-common/stable,now 1.1.0~beta5 all [installed]
python-bluez/stable,now 0.22-1 armhf [installed]
python-cffi-backend/stable,now 1.9.1-2 armhf [installed,automatic]
python-chardet/stable,now 2.3.0-2 all [installed]
python-colorama/stable,now 0.3.7-1 all [installed]
python-cryptography/stable,now 1.7.1-3+b2 armhf [installed,automatic]
python-dev/stable,now 2.7.13-2 armhf [installed]
python-distlib/stable,now 0.2.4-1 all [installed]
python-enum34/stable,now 1.1.6-1 all [installed,automatic]
python-html5lib/stable,now 0.999999999-1 all [installed]
python-idna/stable,now 2.2-1 all [installed,automatic]
python-ipaddress/stable,now 1.0.17-1 all [installed,automatic]
python-minimal/stable,now 2.7.13-2 armhf [installed,automatic]
python-openssl/stable,now 16.2.0-1 all [installed,automatic]
python-pkg-resources/stable,now 33.1.1-1 all [installed,automatic]
python-pyasn1/stable,now 0.1.9-2 all [installed,automatic]
python-requests/stable,now 2.12.4-1 all [installed]
python-rpi.gpio/stable,now 0.6.3~stretch-1 armhf [installed]
python-setuptools/stable,now 33.1.1-1 all [installed,automatic]
python-six/stable,now 1.10.0-3 all [installed,automatic]
python-urllib3/stable,now 1.19.1-1 all [installed,automatic]
python-webencodings/stable,now 0.5-2 all [installed,automatic]
python2.7-dev/stable,now 2.7.13-2+deb9u2 armhf [installed]
python3.4/stable,now 3.4.4-3 armhf [installed]
python3.4-dev/stable,now 3.4.4-3 armhf [installed]
Raspberry Piet
Post by Raspberry Piet » Tuesday 16 January 2018 20:35
Success!
Bingo!
Thank you very much. I had exactly the same trouble here.
I hope it will run stable from now on with python plugins.
edit:
.bash_history:
sudo apt-get remove python3.5
sudo apt-get remove python3.5-minimal
sudo apt-get remove libpython3.5
sudo apt-get remove libpython3.5-minimal
Last edited by Raspberry Piet on Wednesday 17 January 2018 22:29, edited 1 time in total.
Siewert308SW
Post by Siewert308SW » Tuesday 16 January 2018 20:38
Great...
As i mentioned earlier my suspicion is right.
Let's hope a dev read this and know how to get old and newer python version compatible.
Edit:
Opened a issue on Github: https://github.com/domoticz/domoticz/issues/2073
Setup:
- RPi3 - PIco hv3.0A Plus / Domoticz Beta Custom 3.8XXX / RFXtrx433E / Aeotec Gen5
- RPi3 - PIco hv3.0A Plus / PiHole / Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- KaKu/z-wave stuff
Domoticz scripts: @GitHub
PIco UPS Toolkit: @GitHub
Quax1507
Post by Quax1507 » Tuesday 16 January 2018 21:29
So happy it is working now. System runs stable for hours now with two Python plugins enabled :D :D :D
domoticzag
Post by domoticzag » Thursday 18 January 2018 11:20
This unfortionatly did not work for my system, its also on stretch. Python plugins are installed correctly but not showing in Hardware.
Any other advice?
Else installing Jessie seems to be the solution?
RPi 3
Domoticz Béta
RFLink Gateway dipool antenna
Many kaku devices
P1 smart meter
Custom made ESP8266 devices
Hue lights / Milight ligts and strips
garethhowell
Post by garethhowell » Thursday 18 January 2018 11:50
My suspicion is that there is an incompatibility between versions of the python3 libraries. Whether you experience the crashing with the pre-built binaries depends on whether you have the same configuration of libraries as the machine on which the binaries are built.
The solution for me was to build from source. It’s not hard and there is a comprehensive how-to in the wiki (google “build domoticz from source”). It does take a long time, but your main domoticz install runs at the same time so why worry.
I use a headless Pi2 and only access using a console. I installed screen so I could disconnect and leave the build running. If you access using the desktop then you don’t need to do this.
On my Pi2 it took about 30 hours to build from scratch. After that I simply shutdown the running domoticz, copied the database to the dev-domoticz folder, modified domoticz.sh to start the version of domoticz in domoticz-dev rather than domoticz and restarted. All the plugins work now.
Dnpwwo
Post by Dnpwwo » Thursday 18 January 2018 13:57
@domoticzag,
Switching to Jessie won't make a difference.
Can you post some of the Domoticz start up log?
@garethhowell ,
The plugin framework does seem way more stable on RPi for people who build from source but not for the reason you think. Domoticz does not link to Python during the build, it links to it at runtime to allow people without Python on their system to still run Domoticz.
garethhowell
Post by garethhowell » Thursday 18 January 2018 14:56
OK, thanks for the clarification. Too bad, it seemed like a credible hypothesis :-)
Quax1507
Post by Quax1507 » Thursday 18 January 2018 15:34
Just cloned my live system to a second one for testing.
Here is my startup log:
2018-01-18 14:28:41.975  RxQueue: queue worker started...
2018-01-18 14:28:43.976  Hardware Monitor: Started
2018-01-18 14:28:43.997  Wunderground: Worker started...
2018-01-18 14:28:43.998  Kodi: Started
2018-01-18 14:28:43.998  DarkSky: Started...
2018-01-18 14:28:43.998  (Sonos) Started.
2018-01-18 14:28:43.999  (Wintergarten) Started.
2018-01-18 14:28:44.000  EventSystem: reset all events...
2018-01-18 14:28:44.005  EventSystem: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Check_Battery_Levels.lua
2018-01-18 14:28:44.019  EventSystem: reset all device statuses...
2018-01-18 14:28:44.100  Kodi: (Wohnzimmer) Starting thread.
2018-01-18 14:28:44.168  PluginSystem: Entering work loop.
2018-01-18 14:28:44.201  Kodi: Starting I/O service thread.
2018-01-18 14:28:44.543  Error: Domoticz received fatal signal 11 !...
2018-01-18 14:28:44.546  Error:   /home/pi/domoticz/domoticz() [0x23753c]
2018-01-18 14:28:44.546  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x2375f4]
2018-01-18 14:28:44.546  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76bef6b0]
Quax1507
Post by Quax1507 » Thursday 18 January 2018 16:06
I just did some more testing...
If "libpython3-5" is installed, system crashes immediately, if not it starts up without issues!
EDIT: not reproducable :(
Dnpwwo
Post by Dnpwwo » Thursday 18 January 2018 22:41
@Quax1507,
Can you please try turning off the event system (Settings / Other tab) and restart?
domoticzag
Post by domoticzag » Monday 22 January 2018 13:51
What would be the solution to this problem now?
Rebuild from source? On Stretch or Jessie?
RPi 3
Domoticz Béta
Many kaku devices
P1 smart meter
Geitje
Post by Geitje » Monday 22 January 2018 23:01
For me also python scripts stopped working after an update.
I use Xiaomi Me Vacuum robot (Gen 1) plugin https://github.com/mrin/domoticz-mirobot-plugin, and I use a small python script to trun on and off my TP-link smart plugs. None of them work.
Today there was a new update of Domoticz beta, but it does not resolve the issue. Hope a solution is at hand.
Domoticz latest beta, on Raspberry Pi
garethhowell
Post by garethhowell » Tuesday 23 January 2018 9:16
It’s difficult to offer advice when the root of the problem is no known. All I can say is that building from source worked for me. It’s not difficult to do provided you are familiar with working with the command prompt.
olicot
Domoticz version: 3.7404
Post by olicot » Friday 26 January 2018 21:56
Hello
Same issue avec some latest beta...
not only python plugins, but all EventSystem (Lua/Blockly/Scripts).
So to enable :
go to : settings/others and enable ! EventSystem (Lua/Blockly/Scripts):
Domoticz should be restarted
and python plugins are back
It works for me :-)
Hope this help
Siewert308SW
Post by Siewert308SW » Friday 26 January 2018 22:37
@domoticzag,
I just wonder then why i still run Jessie and plugins enabled and running fine.
No matter what Domo build i use, Pre compiled binary or manually compiled on RPi3 with jessie and Python3.4 / libpython3.4 no issues.
If i upgrade to 3.5 or try the same on Stretch the entire system gets unstable and eventually ending in a Segmentation fault.
Something isn't right here.
Or you do or amend something so it runs where we have issues.
Or something is missing from our normal installation, my 2 cents ;-)
Setup:
- FI9803P Cams
- KD101 detectors
- KaKu/z-wave stuff
domoticzag
Post by domoticzag » Saturday 27 January 2018 19:08
Hello
So to enable :
It works for me :-)
Hope this help
This also worked for me !
RPi 3
Domoticz Béta
Many kaku devices
P1 smart meter
Phantom
Domoticz version: 3.8922
Post by Phantom » Wednesday 14 February 2018 2:50
@domoticzag,
Same here for me, on Stretch it was impossible for me to run the beta with python plugins, i get segmentation fault direct when try to start domoticz or when i activate the plugin when domoticz is running.
Precompiled or from source makes no difference. Stable was running without any issue's.
Today went back to jessie installed everything and it works perfect, newest beta with all python plugins enabled.
Domoticz on RPi3 with Stretch is having an issue.
Users browsing this forum: No registered users and 9 guests
