[REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
moroen
Re: [REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Post by moroen » Sunday 17 September 2017 18:50
Lars65 wrote:
Sunday 17 September 2017 18:35
When I try to install this, I get :
error while loading shared libraries usr/local/bin/python3.5
I don't know how many times I tried this, seems impossible.
I run domoticz beta latest
Raspberry Pi 3
raspbian Jessie
Last time I checked the latest beta still has support for python and python plugins disabled, you need to use the python-enabled branch...
M
Lars65
Target OS: Raspberry Pi
Post by Lars65 » Sunday 17 September 2017 19:43
Dumb question I guess but, How do I get the python-enabled branch?
moroen
Post by moroen » Sunday 17 September 2017 22:54
There are no dumb questions, just silly answers... :)
You need to compile domoticz yourself, following the instructions on the wiki-page: https://www.domoticz.com/wiki/Installin ... spberry_PI
To get the branch that supports python, one additional command is necessary, just after
$ git clone https://github.com/domoticz/domoticz.git dev-domoticz
$ cd dev-domoticz
enter
$ git checkout python-enabled
and follow the rest of the instructions!
$ git pull
$ cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt
$ make -j 3
Regards,
M
ivarka
Post by ivarka » Tuesday 19 September 2017 8:07
I thought Python support was included in 3.8153 (Stable)?
Ivar
andi216
Domoticz version: 3.7243
Post by andi216 » Tuesday 19 September 2017 18:21
@moroen
Hello
I took another step.
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac
IKEA-tradfri COAP-adaptor version 0.3 started (command line)!
Waiting for connection
Connected from IPv4Address(TCP, '127.0.0.1', 54094)
Data received: b'{"observe": "True", "action": "setConfig", "gateway": "192.168.1.226", "key": "blablablabla"}'
pi@raspberrypi:~ $ coap-client -k blablabla coaps://192.168.1.226/15004/
v:1 t:CON c:GET i:3515 {} [ ]
decrypt_verify(): found 24 bytes cleartext
decrypt_verify(): found 19 bytes cleartext
[133243]
pi@raspberrypi:~ $ coap-client -k blablablabla coaps://192.168.1.226/.well-known/core
v:1 t:CON c:GET i:fbcf {} [ ]
decrypt_verify(): found 560 bytes cleartext
<//15001/65536>;ct=0;obs,<//15001/65538>;ct=0;obs,<//15004/133243>;ct=0;obs,<//15005/133243>;ct=0;obs,<//15005/133243/220138>;ct=0;obs,<//15005/133243/214322>;ct=0;obs,<//15005/133243/202541>;ct=0;obs,<//15001>;ct=0;obs,<//15001/reset>;ct=0,<//status>;ct=0;obs,<//15005>;ct=0;obs,<//15004>;ct=0;obs,<//15004/add>;ct=0,<//15004/remove>;ct=0,<//15006>;ct=0;obs,<//15011/15012>;ct=0;obs,<//15011/9034>;ct=0,<//15011/9030>;ct=0,<//15011/9031>;ct=0,<//15011/9063>;ct=0,<//15011/9033>;ct=0,<//15010>;ct=0;obs,<//15010/308046>;ct=0;obs,<//15001/65537>;ct=0;obs
Log
2017-09-19 19:06:05.552 (IKEA) Calling message handler 'onHeartbeat'.
Edit | ×
The above values only appear if the command is "python3 tradfri.tac"
After restart Domoticz
Log
2017-09-19 20:05:13.569 (IKEA) Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
2017-09-19 20:05:15.524 (IKEA) Calling message handler 'onHeartbeat'.
2017-09-19 20:05:15.524 (IKEA) Not connected - nextConnect: 3
2017-09-19 20:05:17.529 (IKEA) Calling message handler 'onHeartbeat'.
2017-09-19 20:05:17.529 (IKEA) Not connected - nextConnect: 2
2017-09-19 20:05:19.534 (IKEA) Calling message handler 'onHeartbeat'.
2017-09-19 20:05:19.534 (IKEA) Not connected - nextConnect: 1
2017-09-19 20:05:19.534 (IKEA) Transport set to: 'TCP/IP', 127.0.0.1:1234.
2017-09-19 20:05:19.534 PluginSystem: Starting I/O service thread.
2017-09-19 20:05:19.535 (IKEA) Connect directive received, action initiated successfully.
2017-09-19 20:05:19.585 (IKEA) Calling message handler 'onConnect'.
moroen
Post by moroen » Wednesday 20 September 2017 21:27
Ivar
Quite correct, the latest stable includes python, but the latest beta does (at least did) not...
Regards,
M
moroen
Post by moroen » Wednesday 20 September 2017 21:30
@moroen
Hello
So, the adapter starts, receives the initial setup command, and then fails?
Could you provide me the rest of the output from tradfri.tac? Or send it to me as a PM?
Regards,
M
sejonr
Post by sejonr » Friday 22 September 2017 11:04
Hi i also try to add trådfri plugin. Everything is working exept that i cant find the Trådfri plugin in Domoticz.
(I got help from a person that is very god at Linux and python.) he told me that i need to reinstall domoticz with compile. Do i need that?
Im afraid to loose all my data.
I get this message when i start domoticz.
2017-09-22 09:40:39.391 EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
I using Beta Version 3.8423
I tryed to install libpython3.x but it whas already installed.
moroen
Post by moroen » Friday 22 September 2017 11:52
You need to compile domoticz from the python-enabled branch yourself if you need to use the latest betas. I wrote some intstructions earlier in the thread. If you don't need any other beta features, the latest stable has python enabled and works with the master-branch of the IKEA-plugin.
Regards,
M
Ravenbankie
Post by Ravenbankie » Tuesday 26 September 2017 23:27
Moroen , thanxs for this excellent plugin.
I have followed the instructions and everything is working. i hope i can help someone for what's worth my setup:
my setup: Raspberry pi, OSMC , Python 3.4 dev , domoticz beta, IKEA-tradfri git clone development.
it's my first time raspb and linux so it's nice to see everything working now.
i'm curious: Is the async choice better than the syncrounous version within pytradfri of ggravlingen? Is that the future?
I hope to see all the colors for the color lamps supported someday in your plugin Moroen :-)
greetz
moroen
Post by moroen » Wednesday 27 September 2017 0:25
greetz
Thank you for the feedback!
As to async, it's definitely the future, and the current focus of my work on the plugin. If you'd like to monitor progress (slow, but steady), it's in the aiocoap-branch of the repo. The main motivation for switching to async is to get some kind of stable observation going, the way it's done now seems to crash the gateway, especially when monitoring many lights.
As soon as RGB-bulbs are made available here in Norway, I'll get my hands on a couple and start implementing colors.
Regards,
M
sejonr
Post by sejonr » Friday 29 September 2017 9:01
Hi All i have one problem i cant find IKEA lamps and i got this fault in Domoticz logg. What can it be?
2017-09-29 08:55:14.104 (IKEA Lampor) Received 76 bytes of data:.
2017-09-29 08:55:14.104 (IKEA Lampor) 7b 22 73 74 61 74 75 73 22 3a 20 22 46 61 69 6c 65 64 22 2c {"status":."Failed",
2017-09-29 08:55:14.104 (IKEA Lampor) 20 22 61 63 74 69 6f 6e 22 3a 20 22 73 65 74 43 6f 6e 66 69 ."action":."setConfi
2017-09-29 08:55:14.105 (IKEA Lampor) 67 22 2c 20 22 65 72 72 6f 72 22 3a 20 22 43 6f 6e 6e 65 63 g",."error":."Connec
2017-09-29 08:55:14.105 (IKEA Lampor) 74 69 6f 6e 20 74 69 6d 65 64 20 6f 75 74 22 7d .. .. .. .. tion.timed.out"}
2017-09-29 08:55:14.105 (IKEA Lampor) Calling message handler 'onMessage'.
2017-09-29 08:55:14.105 (IKEA Lampor) Received: b'{"status": "Failed", "action": "setConfig", "error": "Connection timed out"}'
2017-09-29 08:55:14.105 (IKEA Lampor) Command setConfig failed with error: Connection timed out.
2017-09-29 08:55:14.106 (IKEA Lampor) {'action': 'setConfig', 'error': 'Connection timed out', 'status': 'Failed'}
moroen
Post by moroen » Friday 29 September 2017 12:14
It appears that the coap-client can't connect to the ikea-gateway. Have you tried testing the coap-client from the command-line?
$ coap-client -k your_key_goes_here coaps://ip/.well-known/core
Regards,
M
m0rph13
Domoticz version: 3.4834
Post by m0rph13 » Saturday 30 September 2017 11:04
Regards,
M
Have you received your RGB lamp yet?
I've had mine for a couple of weeks now and would love to be able to control colours through your plugin :)
Another thing I would really love to see is a way to detect that a WB has been activated. Currently, all my remotes (WB) shows as being ON all the time.
Thank you for an awesome plugin!
moroen
Post by moroen » Saturday 30 September 2017 12:47
Just checked Ikea store-page, and still no RGB-bulbs available here, I'll keep checking! :)
I'm not quite sure what you mean by WB has been activated?
Regards,
M
m0rph13
Post by m0rph13 » Sunday 01 October 2017 8:54
My bad. I thought the units with WB were the controllers but of course its the white balance :)
sejonr
Post by sejonr » Sunday 01 October 2017 10:03
Regards,
M
Hi M
When i putting in my ip and Key i got this. I am new in Linux so i need help :) I run another Coap-script that i find on the web an could find IKEA lamps. (I removed my IKEA Key)
I using Domoticz V3.8153, Python 3.4, Ikea gateway version 1.1.0015.
coap-client -k "MY Key" coaps://192.168.1.45/.well-known/core
v:1 t:CON c:GET i:190c {} [ ]
<//15001/65541>;ct=0;obs,<//15001/65536>;ct=0;obs,<//15001/65542>;ct=0;obs,<//15001/65544>;ct=0;obs,<//15001/65543>;ct=0;obs,<//15001/65550>;ct=0;obs,<//15001/65546>;ct=0;obs,<//15001/65547>;ct=0;obs,<//15001/65548>;ct=0;obs,<//15001/65545>;ct=0;obs,<//150v:1 t:CON c:GET i:190d {} [ ]
01/65537>;ct=0;obs,<//15001/65540>;ct=0;obs,<//15001/65538>;ct=0;obs,<//15001/65549>;ct=0;obs,<//15001/65539>;ct=0;obs,<//15004/179393>;ct=0;obs,<//15004/142833>;ct=0;obs,<//15004/144989>;ct=0;obs,<//15004/170133>;ct=0;obs,<//15004/170529>;ct=0;obs,<//1500v:1 t:CON c:GET i:190e {} [ ]
5/179393/210242>;ct=0;obs,<//15005/179393/221571>;ct=0;obs,<//15005/179393/213378>;ct=0;obs,<//15005/170529/197393>;ct=0;obs,<//15005/179393/227922>;ct=0;obs,<//15005/142833/216337>;ct=0;obs,<//15005/179393>;ct=0;obs,<//15005/142833>;ct=0;obs,<//15005/1449v:1 t:CON c:GET i:190f {} [ ]
89/204536>;ct=0;obs,<//15005/144989/214163>;ct=0;obs,<//15005/144989/200829>;ct=0;obs,<//15005/142833/207015>;ct=0;obs,<//15005/142833/200247>;ct=0;obs,<//15005/142833/219269>;ct=0;obs,<//15005/142833/198771>;ct=0;obs,<//15005/142833/198755>;ct=0;obs,<//15v:1 t:CON c:GET i:1910 {} [ ]
005/170133/204103>;ct=0;obs,<//15005/170133/207258>;ct=0;obs,<//15005/170133/208775>;ct=0;obs,<//15005/170529/210006>;ct=0;obs,<//15005/170529/227710>;ct=0;obs,<//15005/144989>;ct=0;obs,<//15005/170133>;ct=0;obs,<//15005/170529>;ct=0;obs,<//15005/170529/19v:1 t:CON c:GET i:1911 {} [ ]
9134>;ct=0;obs,<//15005/170529/201532>;ct=0;obs,<//15005/170529/219012>;ct=0;obs,<//15005/170133/198681>;ct=0;obs,<//15005/170133/202935>;ct=0;obs,<//15005/170133/213727>;ct=0;obs,<//15001>;ct=0;obs,<//15001/reset>;ct=0,<//status>;ct=0;obs,<//15005>;ct=0;ov:1 t:CON c:GET i:1912 {} [ ]
moroen
Post by moroen » Sunday 01 October 2017 17:15
Regards,
M
Hi M
So, the coap-client works, the next step is to run tradfri.tac from the command-line and post the output...
Regards,
M
Ravenbankie
Post by Ravenbankie » Sunday 01 October 2017 18:48
Hi moroen,
After a few days (and switching to the aiocoap branch) i get after a few hours an offline domoticz. I can't seem to find the problem. Were can I find the errorlog of domoticz? Domoticz says in systemctl: active(exited). And the tradfri service is running fine. Systemctl doesn't give much feedback for both . Can someone help me?
Last edited by Ravenbankie on Sunday 01 October 2017 20:09, edited 2 times in total.
Lars65
Post by Lars65 » Sunday 01 October 2017 19:17
So I have spent a looooong time, compiling a new domoticz beta, i have installed python 3.6.0, and so on when I get to the point where I should this plugin, I get:
File "tradfri.tac", line 1, in <module>
from twisted.conch.telnet import TelnetTransport, TelnetProtocol
ImportError: No module named 'twisted' and it's installed, tried the opnssl, etc. everything I have got in the documentation on this page.
Any suggestios what do?
Users browsing this forum: No registered users and 7 guests
