[REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
moroen
Re: [REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Post by moroen » Wednesday 06 September 2017 19:16
There's a new version of the IKEA-plugin available on the github page: https://github.com/moroen/IKEA-Tradfri-plugin.
The major change is support for groups. Groups defined in Ikea's app now appears to domoticz as regular switches, that supports turning on/off, dimming and observation of state changes.
There are to separate branches. The master branch corresponds to the current master branch/stable of domotics, the development branch is for the development branch of domoticz.
As always, comments, suggestions, fixes etc are most welcome!
Regards,
M
guykes1
Target OS: Raspberry Pi
Post by guykes1 » Thursday 07 September 2017 12:56
Since yesterdays update, the groups have now become visible in my domoticz setup :)
Thanks so much for developing this, I'm a happy user!
andnyg
Domoticz version: 3.8389
Post by andnyg » Sunday 10 September 2017 18:12
andi216 wrote:
Saturday 05 August 2017 19:26
moroen wrote:
There's definitely something wrong with your twisted install, you should be able to import twisted from interactive python... Try forcing an update?
$ pip3 install --upgrade twisted
Regards,
M
pi@pi:~/domoticz/plugins/IKEA-Tradfri $ sudo pip3 install --upgrade twisted
Requirement already up-to-date: twisted in /usr/local/lib/python3.4/dist-packages
Requirement already up-to-date: zope.interface>=4.0.2 in /usr/local/lib/python3.4/dist-packages (from twisted)
Requirement already up-to-date: constantly>=15.1 in /usr/local/lib/python3.4/dist-packages (from twisted)
Requirement already up-to-date: incremental>=16.10.1 in /usr/local/lib/python3.4/dist-packages (from twisted)
Requirement already up-to-date: Automat>=0.3.0 in /usr/local/lib/python3.4/dist-packages (from twisted)
Requirement already up-to-date: hyperlink>=17.1.1 in /usr/local/lib/python3.4/dist-packages (from twisted)
Downloading/unpacking setuptools from https://pypi.python.org/packages/f6/d0/ ... 627bbe57da (from zope.interface>=4.0.2->twisted)
Downloading setuptools-36.2.7-py2.py3-none-any.whl (477kB): 477kB downloaded
Installing collected packages: setuptools
Found existing installation: setuptools 5.5.1
Not uninstalling setuptools at /usr/lib/python3/dist-packages, owned by OS
Successfully installed setuptools
Cleaning up...
pi@pi:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac
File "tradfri.tac", line 1, in <module>
from twisted.conch.telnet import TelnetTransport, TelnetProtocol
ImportError: No module named 'twisted'
Ill get that exact same fault as andi2160, and can not get pass this. Anyone that have any more ideas?
Thank you
moroen
Post by moroen » Monday 11 September 2017 14:44
Regards,
M
Thank you
Just a quick question, which version of Python are you using? You should at least have Python 3.4.1.
Regards,
M
andnyg
Post by andnyg » Monday 11 September 2017 18:29
Im running 3.4.2
Thank you
/Andreas
andi216
Domoticz version: 3.7243
Post by andi216 » Monday 11 September 2017 19:45
I have reinstalled domoticz (RPi B+, with stable Version 3.8153)
Python 3.4.5
Now there is another type of error
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac
  File "tradfri.tac", line 2, in <module>
    from twisted.internet import protocol, task, reactor, endpoints
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/reactor.py", line 38, in <module>
    from twisted.internet import default
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/default.py", line 56, in <module>
    install = _getInstallFunction(platform)
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/default.py", line 44, in _getInstallFunction
    from twisted.internet.epollreactor import install
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/epollreactor.py", line 24, in <module>
    from twisted.internet import posixbase
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/posixbase.py", line 18, in <module>
    from twisted.internet import error, udp, tcp
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/tcp.py", line 28, in <module>
    from twisted.internet._newtls import (
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/_newtls.py", line 21, in <module>
    from twisted.protocols.tls import TLSMemoryBIOFactory, TLSMemoryBIOProtocol
  File "/usr/local/lib/python3.4/dist-packages/twisted/protocols/tls.py", line 63, in <module>
    from twisted.internet._sslverify import _setAcceptableProtocols
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/_sslverify.py", line 38, in <module>
    TLSVersion.TLSv1_1: SSL.OP_NO_TLSv1_1,
AttributeError: 'module' object has no attribute 'OP_NO_TLSv1_1'
Log
2017-09-11 20:37:57.278 (ikea) Initialized version 1.0.0, author 'moroen'
2017-09-11 20:37:57.346 (ikea) Debug log level set to: 'true'.
2017-09-11 20:37:57.347 (ikea) Heartbeat interval set to: 2.
2017-09-11 20:37:57.347 (ikea) Protocol set to: 'JSON'.
2017-09-11 20:37:57.347 (ikea) Transport set to: 'TCP/IP', 127.0.0.1:1234.
2017-09-11 20:37:57.349 PluginSystem: Starting I/O service thread.
2017-09-11 20:37:57.349 (ikea) Connect directive received, action initiated successfully.
2017-09-11 20:37:57.399 (ikea) Calling message handler 'onConnect'.
2017-09-11 20:37:57.400 (ikea) Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
2017-09-11 20:37:57.701 (Batt zwave) Calling message handler 'onHeartbeat'.
2017-09-11 20:38:06.782 (ikea) Calling message handler 'onHeartbeat'.
2017-09-11 20:38:06.782 (ikea) Not connected - nextConnect: 3
2017-09-11 20:38:07.685 (Batt zwave) Calling message handler 'onHeartbeat'.
2017-09-11 20:38:08.790 (ikea) Calling message handler 'onHeartbeat'.
2017-09-11 20:38:08.790 (ikea) Not connected - nextConnect: 2
2017-09-11 20:38:10.797 (ikea) Calling message handler 'onHeartbeat'.
2017-09-11 20:38:10.797 (ikea) Not connected - nextConnect: 1
moroen
Post by moroen » Tuesday 12 September 2017 20:02
Python 3.4.5
There might be a problem with openssl, could you try to upgrade to latest openssl and latest openssl-libs?
And this might help as well:
pip install --upgrade pyopenssl
Regards,
M
andi216
Post by andi216 » Tuesday 12 September 2017 22:10
I tried - upgrade. No change.
pi@raspberrypi:~ $ openssl version
OpenSSL 1.0.1t 3 May 2016
moroen
Post by moroen » Wednesday 13 September 2017 0:32
Strange... I'm pretty sure this is a twisted/openssl issue, and not the plugin as such. You should at least be able to import twisted from interactive python, if that fails, there must be an issue with twisted on your setup.
Another try:
pip3 install -U twisted[tls]
You might find some info at https://github.com/django/daphne/issues/83 or https://twistedmatrix.com/trac/ticket/9121
(those are for python 2.x, but I think it's relevant for python3 as well)
Regards,
M
andi216
Post by andi216 » Wednesday 13 September 2017 17:20
@moroen
Thank very much you for your advice. A step forward for me.
But...
IKEA-tradfri COAP-adaptor version 0.3 started (command line)!
Waiting for connection
Connected from IPv4Address(TCP, '127.0.0.1', 56914)
Data received: b'{"key": "blablablabla", "action": "setConfig", "observe": "True", "gateway": "192.168.1.111"}'
Unhandled Error
File "/usr/local/lib/python3.4/dist-packages/twisted/python/log.py", line 103, in callWithLogger
return callWithContext({"system": lp}, func, *args, **kw)
File "/usr/local/lib/python3.4/dist-packages/twisted/python/log.py", line 86, in callWithContext
return context.call({ILogContext: newCtx}, func, *args, **kw)
File "/usr/local/lib/python3.4/dist-packages/twisted/python/context.py", line 122, in callWithContext
return self.currentContext().callWithContext(ctx, func, *args, **kw)
File "/usr/local/lib/python3.4/dist-packages/twisted/python/context.py", line 85, in callWithContext
return func(*args,**kw)
--- <exception caught here> ---
File "/usr/local/lib/python3.4/dist-packages/twisted/internet/posixbase.py", line 597, in _doReadOrWrite
why = selectable.doRead()
File "/usr/local/lib/python3.4/dist-packages/twisted/internet/tcp.py", line 208, in doRead
return self._dataReceived(data)
File "/usr/local/lib/python3.4/dist-packages/twisted/internet/tcp.py", line 214, in _dataReceived
rval = self.protocol.dataReceived(data)
File "tradfri.tac", line 51, in dataReceived
self.factory.initGateway(self, command['gateway'], command['key'], command['observe'])
File "tradfri.tac", line 231, in initGateway
for group in self.groups:
builtins.TypeError: 'Group' object is not iterable
Disconnected
Log
2017-09-13 18:23:30.105 (ikea) Calling message handler 'onHeartbeat'.
2017-09-13 18:23:30.256 (ikea) Calling message handler 'onHeartbeat'.
2017-09-13 18:23:32.263 (ikea) Calling message handler 'onHeartbeat'.
moroen
Post by moroen » Wednesday 13 September 2017 17:34
@moroen
But...
Disconnected
Glad it worked out!
It seems you have discovered a bug in the coap-adapter, it looks like you might not have any groups defined? I'll fix it as soon as I can, and commit it to github!
Thanks for your interest in the plugin and thanks for the bug-report! :)
Regards,
M
andi216
Post by andi216 » Wednesday 13 September 2017 18:06
I have a single group with 2 bulbs.
moroen
Post by moroen » Wednesday 13 September 2017 20:02
Ok, so not the error I imagined then... Would you mind providing me with the output of:
coap-client -k key-goes-here coaps://192.168.x.x/15004/
Regards,
M
andi216
Post by andi216 » Wednesday 13 September 2017 20:15
Would you mind providing me with the output of: coap-client -k key-goes-here coaps://192.168.x.x/15004/
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ coap-client -k key-goes-here coaps://192.168.1.111/15004/
v:1 t:CON c:GET i:4b5d {} [ ]
Sep 13 21:10:28 ALRT 20 invalidate peer
Sep 13 21:10:28 WARN received alert, peer has been invalidated
moroen
Post by moroen » Wednesday 13 September 2017 20:45
Hm, no group information at all?
Ok, what about:
coap-client -k key-goes-here coaps://192.168.x.x/.well-known/core
If you still get the same
there's something wrong with libcoap and coap-client, the plugin uses coap-client to talk to the gateway
Regards,
M
andi216
Post by andi216 » Wednesday 13 September 2017 20:56
Ok, what about:
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ coap-client -k key-goes-here coaps://192.168.1.111/.well-known/core
v:1 t:CON c:GET i:1a65 {} [ ]
Sep 13 21:54:41 ALRT 20 invalidate peer
Sep 13 21:54:41 WARN received alert, peer has been invalidated[/quote]
moroen
Post by moroen » Thursday 14 September 2017 0:11
[/quote]
[/quote]
I've reproduced this error by specifying the wrong key, are you sure the key your using is correct?
Regards,
M
andi216
Post by andi216 » Friday 15 September 2017 19:17
key is correct !
I checked with the next order $ python3 -i -m pytradfri IP KEY (and it works)
Lars65
Post by Lars65 » Sunday 17 September 2017 18:35
When I try to install this, I get :
error while loading shared libraries usr/local/bin/python3.5
I don't know how many times I tried this, seems impossible.
I run domoticz beta latest
Raspberry Pi 3
raspbian Jessie
moroen
Post by moroen » Sunday 17 September 2017 18:49
key is correct !
Hm, I'm running out of ideas... coap-client must work from the command line, but since pytradfri works, I guess it somehow does... I'll think some more...
Regards,
M
