[RELEASED] Python plugin: Modbus RTU / ASCII / TCP/IP Topic is solved
Domoticx
Target OS: Raspberry Pi
Domoticz version: 3.8153
Post by Domoticx » Monday 08 January 2018 0:07
DOWNLOAD
You can download the plugin directly from here: https://github.com/DomoticX/domoticz-mo ... master.zip
Project @ GitHub: https://github.com/DomoticX/domoticz-modbus
Please note: Tested and working on Domoticz stable v3.8153 and may not work on some beta versions, i can't give support for (all) beta versions.
MASTER Hardware
RTU RS485
- Raspberry Pi / Windows - USB RS485 to Serial stick: http://domoticx.nl/webwinkel/index.php? ... uct_id=386
TCP/IP
- Nothing specific
SLAVE Hardware (examples)
RTU RS485
- Relais module 12V, 4x250V/10A NO/NC Modbus RS485: http://domoticx.com/modbus-relaisbord/
- KWh meter – DDS238-1 ZN: http://domoticx.com/modbus-kwh-meter-dds238-1-zn/
- KWh meter – Eastron SDM120: http://domoticx.com/modbus-kwh-meter-eastron-sdm120/
- KWh meter – Socomec Countis E03: http://domoticx.com/modbus-kwh-meter-so ... untis-e03/
- D/A converter – HY4AO: http://domoticx.com/modbus-d-a-converter-hy4ao/
Create your own MODBUS SLAVES! :ugeek:
RTU RS485
- Arduino UNO/MEGA/NANO/MINI: http://domoticx.com/arduino-modbus-rs485-rtu-slave/
TCP/IP
- Arduino UNO/MEGA & Ethernet W5100 shield: http://domoticx.com/arduino-shield-ethe ... -ip-slave/
- Arduino UNO/MEGA/NANO/MINI & ENC28J60 module: http://domoticx.com/module-ethernet-lan ... -ip-slave/
- Wire the ENC28J60 module: http://domoticx.com/module-ethernet-lan ... -enc28j60/
TCP/IP Wireless
- ESP8266/NodeMCU/Wemos: http://domoticx.com/esp8266-wifi-modbus-tcp-ip-slave/
SIMULATOR
No hardware? try a Modbus simulator: https://sourceforge.net/projects/modrssim/
So i am using Domoticz (again) now for 3 days (before that trying OpenHab) and see it's maturity has grown since the last years!, very nice! so i installed it all again....and still no Modbus, M-bus, KNX, KAKU TCP-200/300 support!
I also use pymodbus to readout and switch some Modbus stuff you can read here on this page: http://domoticx.com/io-interface/
So.....after many many hours of learning and experimenting...trial and error (since python 3 is pretty new for me) about how to build a Domoticz Python plugin, i have almost finished the first Modbus plugin for Domoticz !!
I still have to make some small adjustments (de puntjes op de "i") and post it on github and wiki so we can all improve it to make it better!
For now i have implemented the SWITCH function for ON/OFF usage (READ functions need to be build but that should be easy, any help is welcome)
I'll try to release the plugin this week!
Here is a sneek peek:
modbusrtu domoticz.png (125.39 KiB) Viewed 5439 times
modbusrtu functions domoticz.png (29 KiB) Viewed 5439 times
Logs:
2018-01-07 20:41:55.300 (TEST) onCommand called for Unit 1: Parameter 'Off', Level: 0
2018-01-07 20:41:55.300 (TEST) MODBUS DEBUG HW - Port=/dev/ttyUSB0 BaudRate=9600 StopBits=1 ByteSize=8 Parity=N
2018-01-07 20:41:55.300 (TEST) MODBUS DEBUG CMD - Address=1 Register=4 Function=6 PayLoadON=0x0100 PayLoadOFF=0x0200
My Domoticz plugins:
- Modbus RS485 RTU/ASCII/TCP
Maatwerk in: Domotica - Automatisering - Elektronica - 3D printing - Software ontwikkeling
Website / Webshop / Knowledge Center / Facebook (like de pagina en blijf op de hoogte!)
Domoticx
Re: Python plugin: Modbus Universal
Post by Domoticx » Monday 08 January 2018 0:10
Ps. There will be 2 universal plugins, one to READ and one to WRITE :D
modbus domoticz universal write 01.png (146.07 KiB) Viewed 5435 times
modbus domoticz universal write 02.png (64.21 KiB) Viewed 5435 times
miljume
Domoticz version: v3.8742
Post by miljume » Monday 08 January 2018 10:35
Really great work!
Any chance you will include Modbus TCP support as well?
Domoticx
Post by Domoticx » Monday 08 January 2018 19:49
Really great work!
Well that should be possible i have to merge/abuse some settings then :lol:
Also i don't have any Modbus TCP laying around, so i can write psuedo code so people can test it out!
Domoticx
Post by Domoticx » Monday 08 January 2018 21:14
So i had to crank some (serial) settings into eachother (stopbit, bytesize, parity) to make some room for more settings, because domoticz officially supports ONLY 6 extra fields....
Sneek peeks:
domoticz modbus portsettings.png (76.66 KiB) Viewed 5376 times
domoticz modbus methode.png (68.78 KiB) Viewed 5376 times
Domoticx
Post by Domoticx » Monday 08 January 2018 22:26
Alright....the Modbus WRITE v1.0.0 has been released! Enjoy! :D
Now i will write the Universal READ plugin... ;)
Stay tuned!
Domoticx
Post by Domoticx » Tuesday 09 January 2018 18:31
Modbus WRITE examples
Settings RTU example
domoticz modbus rtu voorbeeld.png (97.21 KiB) Viewed 5318 times
Settings TCP example:
domoticz modbus tcp voorbeeld.png (97.87 KiB) Viewed 5318 times
Domoticx
Post by Domoticx » Thursday 11 January 2018 1:11
Hi All,
Today i've finished the Modbus READ plugin, it works very nice! you can download it here: https://github.com/DomoticX/domoticz-modbus
Enjoy!
domoticz modbus universal read.png (85.58 KiB) Viewed 5271 times
Supported Functions:
domoticz modbus universal read functions.png (19.15 KiB) Viewed 5271 times
Supported Datatypes:
domoticz modbus universal read data types.png (10.12 KiB) Viewed 5271 times
Domoticx
Post by Domoticx » Thursday 11 January 2018 1:15
Tested the modbus READ plugin with the EASTRON SDM120 KWH Modbus meter:
Result (voltage):
domoticz modbus universal read test.png (17.38 KiB) Viewed 5268 times
Ps. if you wanna buy 8-) :
http://domoticx.nl/webwinkel/index.php? ... ct_id=1865
devros
Re: [Released] Python plugin: Modbus RS485 RTU/ASCII/TCP
Post by devros » Thursday 11 January 2018 21:29
Great and what about 3 phase metter? any cheap supported device?
Ricard1
Post by Ricard1 » Friday 12 January 2018 12:26
Hi @Domoticx
Big thanks for initiating Modbus support to Domotiz!
I am soon going to replace my home Ventilation unit and new one will have Modbus... :)
Best Regards,
Ricard
Domoticx
Post by Domoticx » Friday 12 January 2018 19:18
Hi devros,
It's a universal modbus plugin, so it wil work with all modbus appliances!
Domoticx
Post by Domoticx » Friday 12 January 2018 19:20
Hi @Domoticx
Best Regards,
Ricard
No problem ;) let me know if it works as it is intended or if you need any help.
EdddieN
Domoticz version: 4.9700
Post by EdddieN » Friday 12 January 2018 19:24
Is there a Like? This is fantastic! Great work
11101101 - www.machinon.com
winnie
Post by winnie » Saturday 13 January 2018 9:03
Hi @Domoticx,
Thanks for sharing the plugin. It looks great !
But i have a problem. I can't fill in any parameter.
Any idea?
Thanks Erwin.
Domoticx
Post by Domoticx » Sunday 14 January 2018 9:27
Hello Erwin,
That is really strange, i use the same domoticz version, and i got all the options :roll: , i assume you restarted domoticz like:
sudo service domoticz.sh restart
Or rebooted it?
It seems the XLM layout (plugin) isn't loaded somehow.... i cannot recreate your situation on my pi...
Can you test:
Open a browser to the domoticz log window, and a putty session and use
What does the log say?
winnie
Post by winnie » Sunday 14 January 2018 15:42
Hello Domoticx,
Thanks for your suggestions.
I have restart domoticz several times wihout results.
Here a copy of the log file, baybe you see something wrong...
Greetz and thanks in advance,
Erwin;
2018-01-14 09:10:17.473 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2018-01-14 09:10:17.473 Build Hash: 494fff7, Date: 2017-07-30 12:19:41
2018-01-14 09:10:17.473 Startup Path: /home/pi/domoticz/
2018-01-14 09:10:17.526 EventSystem: reset all events...
2018-01-14 09:10:17.613 PluginSystem: Started, Python version '3.4.2'.
2018-01-14 09:10:17.624 WebServer(HTTP) started on address: :: with port 8080
2018-01-14 09:10:17.630 WebServer(SSL) started on address: :: with port 443
2018-01-14 09:10:17.631 Proxymanager started.
2018-01-14 09:10:17.632 Camera: settings (re)loaded
2018-01-14 09:10:17.678 RxQueue: queue worker started...
2018-01-14 09:10:17.833 Incoming connection from: 127.0.0.1
2018-01-14 09:10:17.875 Incoming connection from: 192.168.0.121
2018-01-14 09:10:19.679 Wunderground: Worker started...
2018-01-14 09:10:19.681 Hardware Monitor: Started
2018-01-14 09:10:19.694 EventSystem: reset all events...
2018-01-14 09:10:19.695 EventSystem: reset all device statuses...
2018-01-14 09:10:19.894 RFLink: Using serial port: /dev/ttyACM0
2018-01-14 09:10:19.918 Python EventSystem: Module not found - Trying to initialize.
2018-01-14 09:10:19.920 Python EventSystem: Initalizing event module.
2018-01-14 09:10:19.920 EventSystem: Started
2018-01-14 09:10:20.028 PluginSystem: Entering work loop.
2018-01-14 09:10:20.814 RFLink: Controller Initialized!...
2018-01-14 09:10:20.890 RFLink Detected, Version: 1.1 Revision: 45 Build: 9
2018-01-14 09:10:22.179 Incoming connection from: 172.16.0.109
2018-01-14 09:11:00.451 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_zwembad.lua
2018-01-14 09:11:00.561 LUA: =====================================================
2018-01-14 09:11:00.561 LUA: >>> Handler: oled
2018-01-14 09:11:00.561 LUA: .....................................................
2018-01-14 09:11:00.561 LUA: Zwembadtemperatuur: 18.62
2018-01-14 09:11:00.612 LUA: .....................................................
2018-01-14 09:11:00.612 LUA: <<< Done
2018-01-14 09:11:00.612 LUA: -----------------------------------------------------
Domoticx
Post by Domoticx » Sunday 14 January 2018 15:43
What could this be?
winnie
Post by winnie » Sunday 14 January 2018 16:36
I also noticed this error, find out if there is something to find about this.
Domoticx
Post by Domoticx » Sunday 14 January 2018 20:28
Indeed wierd..... i have a higher python version (stretch image) :roll:
This is my log:
2018-01-14 18:22:48.140 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2018-01-14 18:22:48.140 Build Hash: 494fff7, Date: 2017-07-30 10:19:41
2018-01-14 18:22:48.140 Startup Path: /home/pi/domoticz/
2018-01-14 18:22:48.182 Sunrise: 07:42:00 SunSet:15:53:00
2018-01-14 18:22:48.182 EventSystem: reset all events...
2018-01-14 18:22:48.319 PluginSystem: Started, Python version '3.5.3'.
2018-01-14 18:22:48.327 Active notification Subsystems: (0/12)
2018-01-14 18:22:48.329 WebServer(HTTP) started on address: :: with port 8080
2018-01-14 18:22:48.334 WebServer(SSL) started on address: :: with port 443
2018-01-14 18:22:48.336 Proxymanager started.
2018-01-14 18:22:48.337 Starting shared server on: :::6144
2018-01-14 18:22:48.337 TCPServer: shared server started...
2018-01-14 18:22:48.337 RxQueue: queue worker started...
2018-01-14 18:22:49.240 Incoming connection from: 192.168.0.1
2018-01-14 18:22:50.338 EventSystem: reset all events...
2018-01-14 18:22:50.339 EventSystem: reset all device statuses...
2018-01-14 18:22:50.494 Python EventSystem: Module not found - Trying to initialize.
2018-01-14 18:22:50.494 Python EventSystem: Initalizing event module.
2018-01-14 18:22:50.494 EventSystem: Started
2018-01-14 18:22:50.683 PluginSystem: Entering work loop.
Also the same error (can be common though)
But it loads the plugins nicely!
Have you installed pymodbus:
sudo pip3 install -U pymodbus
Aslo a thing noticed is that the log should say Modbus - Universal READ loaded. because it's stated in the python file:
    def onStart(self):
        # Domoticz.Log("onStart called")
        if (len(Devices) == 0): Domoticz.Device(Name="ModbusDEV-READ", Unit=1, TypeName="Custom", Image=0, Used=1).Create() # Used=1 to add a switch immediatly!
        DumpConfigToLog()
        Domoticz.Log("Modbus - Universal READ loaded.")
        return
on plugin load and the message is also gone on my side (plugin loaded correctly though), really wierd, hopefully someone can shed a light on this
