Launch Putty from Domoticz [Solved]
Posted: Wednesday 12 September 2018 8:18
by woods
In HomeSeer it’s possible to launch Putty with parameters in one go. I would like to control the HDMI port (on/off) from another Raspberry Pi (controlling my magic mirror).
Is this possible with Domoticz?
Example from HomeSeer:
Edit. Updated the title to solved.
Re: Launch Putty from Domoticz
Posted: Wednesday 12 September 2018 8:38
by ben53252642
Something like this should do it:
Requires: apt-get install sshpass
timeout 20s sshpass -p "PASSWORD" ssh -o ConnectTimeout=20 -o StrictHostKeyChecking=no "USERNAME"@"IPADDRESS" 'THECOMMANDTORUNGOESHERE'
Note the command is set not to verify the ssh keys.
Posted: Wednesday 12 September 2018 8:43
by SweetPants
putty for linux?
Posted: Wednesday 12 September 2018 9:18
by Egregius
If it's just a command that you need to send you can do that by the builtin ssh client.
Something like:
ssh root@192.168.2.212 -i /root/.ssh/home "find /home -type f -printf '%T@\n' | sort -n | tail -1 | cut -f1- -d\" \""
This command grabs the modification time of the last updated file in /home on a remote pi to determine if I need to run a backup or not :D
Of course, that command could be anything you like.
Posted: Wednesday 12 September 2018 14:11
by woods
Thanks guys, I really appreciate the help.
I ‘ve made two scripts (on/off) which I intended to use as on/off parameters on a virtual switch. I tried to call ex. “script://magicmirrorON.sh”, but I got the error 32512 in return in the logs.
Is there a better way implementing this script?
Thanks again.
Ps.
Here's my script:
sshpass -p "PASSWORD" ssh -o ConnectTimeout=20 -o StrictHostKeyChecking=no "username"@"ipadress" 'vcgencmd display_power 0'
Posted: Wednesday 12 September 2018 14:33
by ben53252642
Does the script work from terminal without Domoticz?
If you have that right I can provide a Lua script for Domoticz that can launch it.
I have many sh scripts I launch from Domoticz, it's quite common.
Posted: Wednesday 12 September 2018 14:37
by woods
Yes, it work's perfectly fine without Domoticz.
That would be perfect. Do you run the Lua script directly from the switch configuration?
Posted: Wednesday 12 September 2018 14:52
by ben53252642
Put this in Domoticz events, Lua script TYPE (VERY IMPORTANT) is "device" (not the default "all").
if (devicechanged['SwitchNAME'] == 'On')  then
    os.execute ('/root/scripts/zrc90/bedroom/onscript.sh &')
elseif (devicechanged['SwitchNAME'] == 'Off')  then
    os.execute ('/root/scripts/zrc90/bedroom/offscript.sh &')
SwitchNAME is a virtual switch you created, the event system will watch and when it changes to on or off execute the bash / sh script accordingly.
The & symbol should be kept after the script name, if you remove it, it will still work but could slow down the Domoticz event system.
Cheers
Posted: Wednesday 12 September 2018 15:12
by woods
Fixed it with a new script:
#!/bin/bash
sshpass -p "PASSWORD" ssh -o StrictHostKeyChecking=no pi@ipadress "vcgencmd display_power 1"
Works perfectly. Considering making a new button which safely shutdowns all the raspberry pies as well (including Domoticz).
Case closed. Thanks all.
