Problems enabling PHP
josvink66
Target OS: Raspberry Pi
Post by josvink66 » Wednesday 10 January 2018 17:18
I'm trying to enable PHP with the Domoticz webserver. But it's not working.
I've read that you need to supply the argument to the php cgi.
I've installed php7.0 and php7.0-cgi. I've changed the /etc/init.d/domitcz.sh to include the path to php:
DEAMON_ARGS="$DEAMON_ARGS -php_cgi_path /usr/bin/php7.0-cgi"
But when i put a php file in the www folder i get: 501 Not Implemented
I've also try't it with php5, same effect.
Any idea's?
Greetings,
Jos Vink
Egregius
Re: Problems enabling PHP
Post by Egregius » Wednesday 10 January 2018 17:23
I would suggest running Apache2, lighttpd, Nginx... besides domoticz.
josvink66
Post by josvink66 » Wednesday 10 January 2018 18:02
Yes i was looking for that, but the page https://www.domoticz.com/wiki/Secure_Nginx_Proxy_Setup has no info anymore..
I've set up the webserver and php and set the documentfolder to /home/pi/domoticz/www but that did not work.
Do you know if there is any (working) tutorial out there?
Egregius
Post by Egregius » Wednesday 10 January 2018 18:23
It should be as simple as apt-get install apache2 I think.
Why would you use the same www folder? You can perfectly use a different folder.
Only downside of this way is that you'll have 2 port numbers.
In my case that's no problem because I only use the Apache web interface, the domoticz gui only for adding new devices.
josvink66
Post by josvink66 » Wednesday 10 January 2018 18:25
My first idea was to run all of domoticz and the php scripts from the webserver.
But i'm gonne run it side by side now.
Egregius
Post by Egregius » Wednesday 10 January 2018 18:29
If you only use php for scripts that shouldn't be an issue.
If you also like to have pages available in a browser you need to consider which ports you gonna use.
I only use my php floorplan as a front gui, so I didn't need to make that decision ;)
DewGew
Domoticz version: V3.8799
Post by DewGew » Friday 02 February 2018 11:32
Help needed. I installed php5-cgi.
When i try to open my php file I get error '404 Not found'.
Raspberry Pi 2B - domoticz - Aeon Labs Z-Stick GEN5 - RFlink gateway
NanoPi NEO-air - domoticz - REGO6XX interface
