Fire TV Status
All kinds of 'OS' scripts
DanM
Target OS: Raspberry Pi
Fire TV Status
Post by DanM » Tuesday 08 May 2018 14:44
Figured I'd share my fireTV status script. To run the script you need ADB tools installed as this is how the pi connects to the stick. It triggers a selector switch via curl so you need to alter the urls and the device IDs etc to make it work.
#!/bin/bash
adb kill-server
adb start-server
adb connect IP_OF_FIRETV
#I like to see the output when I run from the command line, helps to identify the IDs of new apps.
adb shell dumpsys activity recents |grep "Recent #0"
playing="$(adb shell dumpsys activity recents |grep "Recent #0")"
if [[ $playing = *"iplayer"* ]]; then
state="STATE_ON_IPLAYER"
fi
if [[ $playing = *"kodi"* ]]; then
state="STATE_ON_KODI"
fi
if [[ $playing = *"netflix"* ]]; then
state="STATE_ON_NETFLIX"
fi
if [[ $playing = *"disney"* ]]; then
state="STATE_ON_DISNEY"
fi
if [[ $playing = *"amazon.avod"* ]]; then
state="STATE_ON_AMAZON"
fi
if [[ $playing = *"launcher"* ]]; then
state="STATE_ON_LAUNCHER"
fi
adb shell dumpsys power | grep "Display Power"
playing="$(adb shell dumpsys power | grep "Display Power")"
if [[ $playing = *"state=OFF"* ]]; then
state="STATE_OFF"
fi
#This echo isnt needed but useful to keep track when running from command line.
echo $state
#Splitting the script into two like this doesnt do much in this implementation. It is done this way because I feed in other devices (such as the actual television power status) and have more complex logic than shown below.
case $state in
"STATE_ON_NETFLIX")
curl 'http://192.168.0.1:8080/json.htm?type=command&param=switchlight&idx=XXXXX&switchcmd=Set%20Level&level=XXX'
"STATE_ON_LAUNCHER")
"STATE_ON_AMAZON")
"STATE_OFF")
"STATE_ON_KODI")
"STATE_ON_DISNEY")
"STATE_ON_IPLAYER")
esac
adb disconnect
