Ultimate Wifi and Bluetooth Presence Detection
All kinds of 'OS' scripts
Yustmenl
Target OS: Raspberry Pi
Domoticz version: 3.5997
Re: Ultimate Wifi and Bluetooth Presence Detection
Post by Yustmenl » Wednesday 29 March 2017 10:27
I am having problems running the script, i have been looking throught the posts of the same problem but none of the solutions seem to work :(
when running
sudo sh ./script.sh
i get
./telrichard.sh: 21: ./telrichard.sh: [[: not found
./telrichard.sh: 31: ./telrichard.sh: [[: not found
./telrichard.sh: 41: ./telrichard.sh: [[: not found
./telrichard.sh: 51: ./telrichard.sh: [[: not found
Status in sync Wifi 1st attempt
when running
sudo ./script
i get
sudo: ./telrichard.sh: command not found
when running
./script
i get
bash: ./telrichard.sh: Permission denied
i already used dos2unix on the file
and created the file with touch and filled it with nano
but somehow i can't get it to work
so now i am out of ideas hopefully someone here can help me.
Rasberry Pi 3; Razberry 2.0; RFXCOM
ben53252642
Post by ben53252642 » Wednesday 29 March 2017 13:14
This should fix it:
sudo chmod 755 telrichard.sh
then run:
sudo ./telrichard.sh
Yustmenl
Post by Yustmenl » Wednesday 29 March 2017 13:18
wel it's running now with sudo ./telrichard.sh
but i still get
any idea what can be the solution for that?
ben53252642
Post by ben53252642 » Wednesday 29 March 2017 13:32
Try sudo bash ./telrichard.sh
u still get the error?
Yustmenl
Post by Yustmenl » Wednesday 29 March 2017 13:34
thats's it thanks wil change it in cron to
ben53252642
Post by ben53252642 » Wednesday 29 March 2017 13:41
Cool,
The first line of the script:
#!/bin/bash
Is supposed to tell systems to run it as a bash script but for some reason your system seems to ignore that.
Anyway you can run it with that command:
And it essentially does the same thing. :D
Yustmenl
Post by Yustmenl » Wednesday 29 March 2017 13:50
Looks i removed to much from the script
#!/bin/bash
was missing :oops:
Yustmenl
Post by Yustmenl » Wednesday 05 April 2017 8:38
I found out that the WIFI ping isn't working with my and my girlfriends phone.
Does anyone have an idea if this can be solved? or is this becuase of the power saving from the phones?
ToneStrife
Post by ToneStrife » Sunday 16 April 2017 18:44
Hello to anyone!
I get the sensor working correctly but I'm having problems to get it in the startup. I'm running the script in a Rpi3
startup.sh file is
cd /home/pi/domoticz/scripts
# Start Carlos Mobile Ping Monitor
#/usr/bin/screen -S PingCarlosMobile -d -m ./carlos_phone.sh
And the file in init.d is
#!/bin/sh
### BEGIN INIT INFO
# Provides: Startscripts
# Required-Start: $network
# Required-Stop: $network
# Default-Start: 2 3 5
# Default-Stop:
# Description:
### END INIT INFO
case "$1" in
'start')
        sudo sh /home/pi/domoticz/scripts/startup.sh
'stop')
        echo "Usage: $0 { start | stop }"
esac
exit 0
I have added the file to the startup using defaults command. But on startup is not detecting changes. Any help?
chrisk81
Post by chrisk81 » Thursday 11 May 2017 18:03
I'm using this code to detect my iPhone bluetooth. I've found it to be rock solid so far and it also gives the RSSI. Can anyone see any issues with it?
#!/bin/bash
sudo hcitool cc AA:BB:CC:DD:EE:FF 2> /dev/null
while true
do
	bt=$(hcitool rssi AA:BB:CC:DD:EE:FF 2> /dev/null)
	if [ "$bt" == "" ]; then
	fi
	echo "$bt"
done
beounet
Post by beounet » Saturday 08 July 2017 12:41
A very nice script indeed!! works fine till now!!
Thanks a lot Ben!
I think that it will be a good idea to include some sort of security here!!
As i see if the domoticz page is code protected then the virtual switch does not refresh it's state!!
One more is that the same happens if the virtual switch is also password protected!
Protecting the switch is usefull in order to prevent accidentally change of the state!!
rudiraz
Domoticz version: latest
Post by rudiraz » Tuesday 07 November 2017 15:24
I do not need the commandline output. I obly need the script for witching the alarm-switches on and off.
How do I have to use this script then.?
Starting manually ist not the right way...?!
schulpr
Post by schulpr » Friday 01 December 2017 15:41
I'm getting this error: ./iphone_rob.sh: 75: ./iphone_rob.sh: Syntax error: "done" unexpected (expecting "then").
Anyone an idea what's going wrong?
Regards, Rob
theo69
Domoticz version: la. beta
Post by theo69 » Wednesday 03 January 2018 19:51
Hi I am a Newbi and have no clue how to add a script like this, is there somebody that can write down all the steps for me?
I have two phones with these Bluetooth Mac Adress: 00:14:22:01:23:45 and 00:0a:95:9d:68:16
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
theo69
Post by theo69 » Wednesday 03 January 2018 20:26
okay its running (more or less) however my Dummy switch is not changing using this code:
echo "Status out of sync, correcting..."
if [ "$device" = On ] ; then
echo "$Name" "Online"
curl -s "http://"10.0.1.32:8080"/json.htm?type=command&param=switchlight&idx="$392"&switchcmd=On" 2>/dev/null 1>/dev/null
echo "$Name" "Offline"
curl -s "http://"10.0.1.32:8080"/json.htm?type=command&param=switchlight&idx="$392"&switchcmd=Off" 2>/dev/null 1>/dev/null
fi
fi
jvdz
Domoticz version: Stable
Post by jvdz » Wednesday 03 January 2018 20:30
Guess that needs to be:
curl -s "http://"10.0.1.32:8080"/json.htm?type=command&param=switchlight&idx=392&switchcmd=On" 2>/dev/null 1>/dev/null
curl -s "http://"10.0.1.32:8080"/json.htm?type=command&param=switchlight&idx=392&switchcmd=Off" 2>/dev/null 1>/dev/null
A $ infront means it is a variable defined before and guess 392 is the actual IDX for the dummy switch.
Jos
theo69
Post by theo69 » Wednesday 03 January 2018 20:32
Jos
yep found that myself right now :oops:
Only problem now, i can only start the sh with sudo bash iphone.sh
theo69
Post by theo69 » Wednesday 03 January 2018 20:41
Also a lot of times when i switch of bluetooth on the phone, it still shows online...
jvdz
Post by jvdz » Wednesday 03 January 2018 20:51
What is the problem with running it without sudo? Access to curl or the scriptfile?
The script should tell you what it finds. Which version are you using and did you also use the IP address as that looks like it is required for the script I see on the first page? (I am not using this version and wrote my own LUA version)
Jos
theo69
Post by theo69 » Wednesday 03 January 2018 22:09
if I just use sudo (without bash) it says
Command not found
and if I just write bash (without sudo) it says
Can't create socket: Operation not permitted
Can you share your LUA Srcipt with me please?
