How to use curl in bash with domoticz API to control switch Topic is solved
All kinds of 'OS' scripts
tonywk
Post by tonywk » Thursday 13 July 2017 15:13
I have setup a switch in domoticz and want to use curl in a bash file with domoticz API to control switch. bash command is this:
curl http://192.168.1.205:8080/json.htm?type=command&param=switchlight&idx=134&switchcmd=On
the domoticz API: http://192.168.1.205:8080/json.htm?type=command&param=switchlight&idx=134&switchcmd=On
has been tested successfully in web browser, but once I try just type the curl command as above in terminal, below error appears
Can you help me with it? Thanks!
SweetPants
Domoticz version: V3.8926
Re: How to use curl in bash with domoticz API to control switch
Post by SweetPants » Thursday 13 July 2017 16:13
Have you put the command between single quotes already?
Ubuntu 16.04.3 LTS on Intel NUC, MySensors 2.2.1, Pro Mini 3.3 8M RFM69, ESP8266 (SDK2.1.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
tonywk
Post by tonywk » Thursday 13 July 2017 17:39
No I didn't. That is it! A tiny thing took me hours yet to figure out, Thanks!
SweetPants
Post by SweetPants » Friday 14 July 2017 15:25
tonywk wrote:No I didn't. That is it! A tiny thing took me hours yet to figure out, Thanks!
Can you mark this solved?
tonywk
Post by tonywk » Monday 17 July 2017 6:59
yes, it is working now.
