Event not triggered by variable set by other event
Slinkos
Target OS: Raspberry Pi
Domoticz version: 3.4834
Post by Slinkos » Saturday 07 October 2017 1:00
Hi all, I'm having a weird issue and I hope I can explain it properly.
So I made a User Variable called "Save State". It's a interger variable. In my blocky's I made it so, that "Save State" can either have value 0, 1 or 2.
The problem is, when I set the variable to one of those values, for example value "1", another blocky what is meant to be triggered, does not start. When I update the variable myself and give it value "1", then the other blocky does get triggered. How is this possible?
I hope I made my problem clear to you all, if not please tell me. :-)
mosjonathan
Re: Event not triggered by variable set by other event
Post by mosjonathan » Sunday 08 October 2017 15:21
that is a safeguard to prevent a loop.
scripts and blockly only trigger on variables set through webinterface.
luckily there is a work around for this.
update your variable with the following command:
http://127.0.0.1:domoport/json.htm?param=updateuservariable&type=command&vname=variablename&vtype=2&vvalue=value
replace: domoport with your port
replace: variablename with name of your variable
replace: value with the value that the variable must be changed to
Slinkos
Post by Slinkos » Sunday 08 October 2017 22:56
