buienradar lua script
nf999
Target OS: Raspberry Pi
Domoticz version: latest
Post by nf999 » Saturday 03 February 2018 10:54
based on a lot of ideas from this forum i recreated a lua only (no dzvents no python) buienradar script, to add a weather rain device showing the rain based on buienradar, rain expected in a dummy text sensor and a switch to use in sunscreen scripts.
The script does require curl, but that's all. If on rpi run apt-get install curl if curl is missing.
for latest version of the script click here
-- BuienRadar Module
-- curl in os required!!
-- create dummy text device from dummy hardware 'Buien Radar'
-- create dummy rain sensor from dummy hardware 'BuienRadarMeter'
-- create dummy switch from dummy hardware for triggering screens etc based on rain
-- add as time based lua script
-- set your longitude & lattitude below!
-- 2017-12-27 working version
-- 2017-12-28 trying to get the rain device working .. missing documentation ..
-- 2017-12-30 isolated the bug, i was overwriting the updatedevice .. should be ok now
local myBuienRadarDevice='Buien Radar'
local myBuienRadarMeter='BuienRadarMeter'
local myBuienRadarFlg='flgBuienRadar'
-- longitude lattitude
local lat='your-lattitude-here'
local lon='your-longitude-here'
time = os.date("*t")
if time.min % 5 == 0 then
    print('BuienRadar module')
    function os.capture(cmd, rep)  -- execute command to get site
        -- rep is nr of repeats if result is empty
        r = rep or 1
        local s = ""
        while ( s == "" and r > 0) do
            r = r-1
            local f = assert(io.popen(cmd, 'r'))
            s = assert(f:read('*a'))
            f:close()
        if ( rep - r > 1 ) then
            print("os.capture needed more than 1 call: " .. rep-r)
      return s
    --  get data from buienradar
    local commando = "curl --max-time 5 -s 'http://br-gpsgadget-new.azurewebsites.net/data/raintext/?lat=" .. lat .. "&lon=" .. lon .. "'"
    -- print("commando: " .. commando)
    local tmp = os.capture(commando, 3)
    -- print('buienRadar data:\n' .. tmp)
    if ( tmp == "" ) then
        print("buienRadar: Empty result from curl command")
        -- analyse data
        -- to mm/h 10^((waarde-109)/32)
        function tomm(r)
            return 10^((r-109)/32)
        -- to string formatted
        function tos(r, c)
            c = c or 1
            return string.format("%." .. c .. "f", r)
        local c=0
        local rainNow=0
        local rainNowAvg = 0
        local rainSoon = 0
        local rainTime = ""
        local rainMax = 0
        for k,v in tmp:gmatch('(.-)|(.-)\r?\n') do
            -- k is rain value, v is time
            kn = tonumber(k)
            if c<=1 then
                if rainNow < kn then
                    rainNow = kn
                if kn > 0 then
                    rainNowAvg = rainNowAvg + tomm(kn)/2
            if c<=3 and rainSoon < kn then
                rainSoon = kn
            if rainTime == "" and kn > 0 then
                rainTime = v
            if kn > rainMax then
                rainMax = kn
            c = c+1
        if rainNow>0 then
            tmp = "now; " .. tos(tomm(rainNow)) .. "mm/h"
            if rainMax > rainNow then
                tmp = tmp .. " upto " .. tos(tomm(rainMax)) .. "mm/h"
        elseif rainSoon>0 then
            tmp = "soon in 15mins; " .. tos(tomm(rainSoon)) .. "mm/h"
            if rainMax > rainSoon then
        elseif rainTime ~= "" then
            tmp = "expected @ " .. rainTime .. "; upto " .. tos(tomm(rainMax)) .. "mm/h"
        else tmp = "No rain"
        -- calculate totalrainfall using rainNowAvg as average of 2 next reports
        -- print("buienRadarMeterOld: " .. otherdevices_svalues[myBuienRadarMeter])
        local rainTot = tonumber(otherdevices_svalues[myBuienRadarMeter]:match("[^;]+;([^;]+)")) + rainNowAvg/12 -- /12 to acount for 5min measurements ?? ..
        -- print("buienRadarDebug: rainNow=" .. tos(tomm(rainNow)) .. " rainNowAvg=" .. tos(rainNowAvg) .. " rainSoon=" ..
        --      tos(tomm(rainSoon)) .. " rainTot=" .. tos(rainTot,2) .. " rainTime=" .. rainTime .. " rainMax=" .. tos(tomm(rainMax)))
        local cmd = otherdevices_idx[myBuienRadarMeter] .. "|0|" .. tos(tomm(rainNow)*100,0) .. ";" .. tos(rainTot,2)
        -- print("buienRadar: " .. cmd)
        table.insert(commandArray, { ['UpdateDevice'] = cmd } ) -- table.insert needed to avoid overwriting with next updatedevice
        -- write to text device
        if otherdevices[myBuienRadarDevice] ~= tmp then
            table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[myBuienRadarDevice] .. '|0|' .. tmp })
            -- trigger based when rainNow or rainSoon
            if ( rainNow>0 or rainSoon>0 ) then
                if otherdevices[myBuienRadarFlg] == "Off" then
                    commandArray[myBuienRadarFlg] = "On"
            elseif otherdevices[myBuienRadarFlg] == "On" then
                commandArray[myBuienRadarFlg] = "Off"
    end -- empty result
EdwinK
Re: buienradar lua script
Post by EdwinK » Saturday 10 February 2018 23:20
2018-02-10 22:20:02.390 LUA: os.capture needed more than 1 call: 3
2018-02-10 22:20:02.390 LUA: buienRadar: Empty result from curl command
Is what I get.
Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | RFxcom | Dashticz V2
nf999
Post by nf999 » Saturday 17 February 2018 18:07
did it improve? Looks like the curl call times out??? try the curl command from commandline? see what happens?
uncomment the line:
and run the commando from cli on your pc.
EdwinK
Post by EdwinK » Saturday 17 February 2018 23:53
uncomment the line:
At the moment I'm looking at something else first. If that doesn't work, I'll check in here again :)
EdwinK
Post by EdwinK » Sunday 18 February 2018 10:12
 curl http://br-gpsgadget-new.azurewebsites.net/data/raintext/?lat=51.86&lon=4.41
[1] 14331
Going to wait a couple of hours to see what happens next :), but it looks it works now. At least I see some data in the devices tab
rickiewickie
Post by rickiewickie » Friday 02 March 2018 23:02
Finally buienradar in Lua ! --> (Buienradar plugin keeps crashing after 4 updates)
I already intended to create my own, but this look great so far!
I will test it this weekend :D
nf999
Post by nf999 » Friday 23 March 2018 18:01
The url for buienradar has changed .. update your script with:
local command = "curl --max-time 5 -s 'http://gpsgadget.buienradar.nl/data/raintext?lat=" .. lat .. "&lon=" .. lon .. "'"
I also added detection to at least log when the script can't parse the curl output.
full script now:
-- 2018-03-28 updated buienradar url
local lat='51.99'
local lon='4.50'
        r = rep or 1
        local s = ""
            r = r-1
            f:close()
      return s
    -- print("command: " .. command)
    local tmp = os.capture(command, 3)
        -- analyse data
        function tomm(r)
        function tos(r, c)
            c = c or 1
        local c=0
        local rainNow=0
        local rainSoon = 0
        local rainTime = ""
        local rainMax = 0
            kn = tonumber(k)
            if c<=1 then
                    rainNow = kn
                if kn > 0 then
                rainSoon = kn
                rainTime = v
                rainMax = kn
            c = c+1
        -- if c = 0 no data found!
        if ( c == 0 ) then
            print("buienRadar: Unparsable result from curl command")
            if rainNow>0 then
        end -- unparsable
    end -- empty result
poudenes
Domoticz version: 3.8993
Post by poudenes » Wednesday 28 March 2018 11:07
Nice script!!!
See sometimes this error:
2018-03-28 07:55:10.236 Error: EventSystem: Warning!, lua script Script Buienradar has been running for more than 10 seconds
Does anybody know what to do with it?
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
nf999
Post by nf999 » Saturday 31 March 2018 21:26
is no real problem, although it's blocking the event system for this period I think. The number of repetitions is however. the script uses a curl command with 5 secs timeout, to ensure minimum errors but maximum result ..
Sometimes the call to buienradar seems to return nothing, therefore I added a timeout. However after 2 timeouts the script crosses the 10secs .. Your logline was probably accompanied by:
Still no big issue except that buienrader timed out. It tries x times, in the script here 3 times:
If still no result it will log empty result ..
So incidentally this script will go over 10secs. If you don't want this adjust the nr of repetitions to 2, or reduce the timeout to 3 secs in os.capture. This setup was fine for me.
gizmocuz
Post by gizmocuz » Sunday 01 April 2018 16:22
Thank you for this script! Worth to note that the lat/long has to be 2 digits max otherwise no result is returned (redirect)
to follow the redirect as well, you can add -L to the curl argument list
local command = "curl --max-time 5 -L -s 'http://gpsgadget.buienradar.nl/data/raintext?lat=" .. lat .. "&lon=" .. lon .. "'"
Small spelling mistake, it is latitude
nf999
Post by nf999 » Monday 02 April 2018 16:01
:D thanx!
HansieNL
Post by HansieNL » Monday 02 April 2018 20:05
@nf999: If I try to use an other name for "local myBuienRadarDevice='Buien Radar'" i get an error: Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_buienradar.lua: /home/pi/domoticz/scripts/lua/script_time_buienradar.lua:129: attempt to concatenate field '?' (a nil value)
I wanna rename "Buien Radar" to "Regen". Can you tell me if that's possible and how to fix it?
Blah blah blah
nf999
Post by nf999 » Wednesday 04 April 2018 20:14
My guess is either you have not created the "Regen" device yet or made a typo in the variable name. I tested it and anything concatenated with
otherdevices_idx[bla]
when "bla" is empty or device behind "bla" is non existent results in this error.
nf999
Post by nf999 » Wednesday 04 April 2018 20:17
latest version of script:
-- set your longitude & latitude below!
-- 2018-04-02 added follow redirect for curl & fixed typo as tipped by gizmocuz
-- longitude latitude
local lat='51.99'
local lon='4.50'
        r = rep or 1
        local s = ""
            r = r-1
            f:close()
      return s
        -- analyse data
        function tomm(r)
        function tos(r, c)
            c = c or 1
        local c=0
        local rainNow=0
        local rainSoon = 0
        local rainTime = ""
        local rainMax = 0
            kn = tonumber(k)
            if c<=1 then
                    rainNow = kn
                if kn > 0 then
                rainSoon = kn
                rainTime = v
                rainMax = kn
            c = c+1
        if ( c == 0 ) then
            if rainNow>0 then
        end -- unparsable
    end -- empty result
gizmocuz
Post by gizmocuz » Thursday 05 April 2018 9:08
It would also be nice if you could add the following functionality (rain perception) into the script
http://www.domoticz.com/forum/viewtopic ... 8&start=20
For example you specify the window to be 15 minutes, how much change of rain there is there in the next 15 minutes, and put this in a percentage sensor
Now we can close the blinds if that is very high.... this way you have have some more time in advance
HansieNL
Post by HansieNL » Thursday 05 April 2018 17:07
@nf999: Got it working :-)
Blah blah blah
nf999
Post by nf999 » Monday 09 April 2018 20:24
That's actually what I'm using the myBuienRadarFlg for ;-) in other words, it's already in there. The myBuienRadarFlg flips to true based on rainNow and rainSoon. rainSoon is the highest rainfall for the next approx 15mins (highest of first 3 data from buienradar), where rainNow is now (only first row of data from buienradar).
So you can use the myBuienRadarFlg to open all blinds.
rainDev = "flgBuienRadar"
    elseif devicechanged[rainDev] == "On" then
        screens("up")
The only issue I have with my screens script is that weatherunderground uv (used for closing the blinds) is really unreliable, so if you have a tip for getting sunpower in a reliable fashion?? Still planning to build an esp8266 uv sensor ;-) but that's a completely different topic :-0
gizmocuz
Post by gizmocuz » Sunday 22 April 2018 18:44
Ahhh perfect... yes, when i now look at the code, i see that you use both rainNow and rainSoon ;) great!
Driesser
Post by Driesser » Wednesday 22 August 2018 23:13
Hi There,
I Installed the Script and it runs every 5 minutes as intented.
I Do have problem with the flgBuienRadar. As instucted I made a dummy switch with the mane "flgBuienRadar"
But it doesn't switch on or off. I switched it on and see if it would switch off after the module have run.
What do I miss? I would like to use the flgBuienRadar in an blockly.
HansieNL
Post by HansieNL » Thursday 23 August 2018 1:33
Flg BuienRadar switch will only be switched if there is gonna be rain expected or it starts raining. So you have to wait till it's gonna be rainy again.
Blah blah blah
Users browsing this forum: No registered users and 5 guests
