Missing decimal place
sailmich
Target OS: Raspberry Pi
Post by sailmich » Saturday 26 August 2017 10:43
Domoticz V3.8337
RPi2
Aeotec Z-Stick Gen5
I need help with a Lua script which I found here in the forum and modificated sligthly to my needs. I have a personal weather station which produce a xml file every minute. With the script I grab the windspeed value and update a virtual custom sensor. Problem is the sensor just showing numbers without decimal place. I.e. xml value is 0.7 while virtual sensor showing 0.
Would be fine if somebody could give me the right kick to add a decimal place to my virtual sensor.
I'm more the visuell guy, I prefer Blockly and therefore I would like to use this virtual sensor.
Appreciate any help from you.
Mike
See below the script
-- Title: script_device_weewx.lua
-- Date: 10-01-2016
-- this script reads the weewxpws xml file and uploads current data to virtual device
time = os.date("*t")
if ((time.min % 1)==0) then
os.execute('sudo wget http://168.xx.xx.xx/weewx_pws.xml -O /home/pi/domoticz/scripts/lua/weewx_pws.xml')
local filename = "/home/pi/domoticz/scripts/lua/weewx_pws.xml"
local line = ''
local windspeed = 0
local speeddevice = ''
for line in io.lines(filename) do
if string.find(line,"\"windspeed\"") then
windspeed=tonumber(string.match(line, "%d+"))
-- Update virtual device id
speeddevice='132|0|'..windspeed..';0'
--print(speeddevice))
commandArray['UpdateDevice'] = speeddevice
sailmich
Re: Missing decimal place
Post by sailmich » Monday 28 August 2017 21:35
Solve it.
windspeed=tonumber(string.match(line, "%d+")) just deliver value before the decimal point. Instead of "%d+" use "%d+ . %d+" and I get the digit behind the decimal point.
