Yet another presence detection method
mayyam
Target OS: Raspberry Pi
Domoticz version: 3.5877
Re: Yet another presence detection method
Post by mayyam » Sunday 29 January 2017 10:58
i'm on the Tomato firmware, and when i'm testing the script, i'm getting:
wl: wl driver adapter not found
When i'm asking it for status ( wl -i eth1 status ):
SSID: "XXXXX"
Mode: Managed   RSSI: 0 dBm     SNR: 0 dB       noise: -90 dBm  Channel: 5u
BSSID: AC:22:0B:xx:xx:xx        Capability: ESS ShortSlot RRM
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
HT Capable:
        Chanspec: 2.4GHz channel 3 40MHz (0x1903)
        Primary channel: 5
        HT Capabilities:
        Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 2                                                         1 22 23 32 ]
So i guess, that there is wl adapter, or.....i'm lost.
_______________
- Raspberry Pi 3
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
mayyam
Post by mayyam » Sunday 29 January 2017 11:14
Oh, i know, i have no 5Ghz network, so no 'wl -i eth2'. I disabled it:
# look in 2.4GHz (eth1) network for device
for x in `wl -i eth1 assoclist | awk '{print $2}'`; do
 if [ $x = $mac ]; then
        device_present=On
 fi
done
# look in 5GHz (eth2) network for device
#for x in `wl -i eth2 assoclist | awk '{print $2}'`; do
# if [ $x = $mac ]; then
#        device_present=On
# fi
#done
Anyway, i have no errors, but my status is not updated in Domoticz on ON/OFF switch.
[SOLVED] - I had to unbreak 3 lines:
domoticz_status=`curl -s "http://domoticzUser:domoticzPassword@domoticzIP:domoticzPort/json.htm?type=devices&rid=$idx" | grep Status | awk '{print $3}' | sed 's/[",]//g'`
	curl -s "http://domoticzUser:domoticzPassword@domoticzIP:domoticzPort/json.htm?type=command&param=switchlight&idx=$idx&switchcmd=On" > /dev/null
	curl -s "http://domoticzUser:domoticzPassword@domoticzIP:domoticzPort/json.htm?type=command&param=switchlight&idx=$idx&switchcmd=Off" > /dev/null
Because i don't believe that in Tomato /jffs/scripts/ are triggered automagically, i put:
/jffs/scripts/presence_detection MAC-ADDRESS1 IDX1
/jffs/scripts/presence_detection MAC-ADDRESS2 IDX2
/jffs/scripts/presence_detection MAC-ADDRESS3 IDX3
/jffs/scripts/presence_detection MAC-ADDRESS4 IDX4
and so on...
in Administration/Scheduler first free Custom/every minute/Everyday
Now is working like a charm :)
Bless You Surroot!
_______________
- Raspberry Pi 3
- 2x Xiaomi Gateway
sincze
Domoticz version: 3.8875
Post by sincze » Sunday 29 January 2017 16:15
nice. :D
I tried the script with my tomato router.
It does work... however...
I have a AP on every floor (range problems).
So if I am on the upper floor I am not getting noticed by the router that is running the script.
So it turns Domoticz switch off.
ah. damn
Using Pass2php since 2016-12
LAN: RFLink, P1-Port, OTGW, MySensors
USB: RFXCom, ZWave
WIFI: Mi-light Wifi-Bridge, Sonoff, ESP8266, Xiaomi Gateway
Solar: Omnik Inverter, PVOutput
Video: Kodi clients with Harmony HUB
Sensors: You name it I probably got 1.
mayyam
Post by mayyam » Sunday 29 January 2017 16:26
sincze wrote:nice. :D
ah. damn
I also have AP.
And i'm getting two MACs. One is real MAC, and second is virtual MAC:
AC:C1:EE:12:39:24 - real one
02:0F:B5:12:39:24 - virtual, from AP
You just have to treat it like another device and write another line for it:
/jffs/scripts/presence_detection AC:C1:EE:12:39:24
/jffs/scripts/presence_detection 02:0F:B5:12:39:24
The advantage of this is that You know where You are, in which room/floor (at what AP) :)
I've made something like that - viewtopic.php?f=23&t=31&start=100#p27521 - first blocky
Two of them, for my wife two MACs - Domoticz know my wife is home, and my two MACs - Domoticz know i'm home. Then third blocky, with both of them, to check if we are in home.
I know i could probably make it with one blocky, but now, as i said, i can also check where in home we are, and let say...turn lights off in area, where nobody is pesent ;)
_______________
- Raspberry Pi 3
- 2x Xiaomi Gateway
sincze
Post by sincze » Sunday 29 January 2017 16:40
:D :D well you are absolutely right. "GEO" Location in the house. and indeed it should be considered a new device.
otherwise ground floor will switch it off every minute... upper floor ... on . :shock: and top floor ... off again. pfff
USB: RFXCom, ZWave
mikl10
Post by mikl10 » Monday 30 January 2017 21:07
Hello, thank you for sharing your script.
Did someone has already testing that with iPhone?did it work when iPhone is sleeping?
Surroot
Post by Surroot » Monday 30 January 2017 22:03
mikl10 wrote:Hello, thank you for sharing your script.
Hello!
Yes it also works when the iPhone is sleeping!
BaliBiker
Post by BaliBiker » Sunday 12 February 2017 2:36
When I test by typing
./presence_detection 60:F1:89:87:68:FD 1316
I get the next result
-sh: ./presence_detection: Permission denied
Does some has any idea how I can solve this issue??
Many thanks in advance!!
Surroot
Post by Surroot » Sunday 12 February 2017 10:01
BaliBiker wrote: I get the next result
Hey BaliBiker!
Try: chmod +x presence_detection
Then again ./presence_detection 60:F1:89:87:68:FD 1316
Best regards!
BaliBiker
Post by BaliBiker » Sunday 12 February 2017 12:36
Hey BaliBiker!
Best regards!
Thanks so much Surroot! That was a step forward :-)
The script runs, but gives me:
[: Off: unknown operand
I hope you can help me with the script. I looks like this..
#!/bin/sh
mac=$1
idx=$2
device_present=Off
domoticz_status=`curl -s "http://XXX:YYY@192.168.1.162:8080/json.htm?\type=devices&rid=$idx" | grep Status | awk '{print $3}' | sed 's/[",]//g'`
device_present=On
fi
done
device_present=On
fi
done
# tell domoticz the new device status
if [ $domoticz_status != $device_present ]; then
if [ $device_present = "On" ]; then
curl -s "http://XXX:YYY@192.168.1.162:8080/json.htm?\type=command&param=switchlight&idx=$idx&switchcmd=On" > /dev/null
curl -s "http://XXX:YYY@192.168.1.162:8080/json.htm?\type=command&param=switchlight&idx=$idx&switchcmd=Off" > /dev/null
fi
fi
mayyam
Post by mayyam » Sunday 12 February 2017 12:58
I also get:
or
[: On: unknown operand
But it's working.
_______________
- Raspberry Pi 3
- 2x Xiaomi Gateway
PeGe
Domoticz version: V3.6328
Post by PeGe » Sunday 12 February 2017 13:40
While reading this thread out of pure curiosity, not intending to test or implement the solution in my own environment (due to incompatoble router hardware), I immediately spotted a fundamental error occuring three (3) times in your script:
I assume that the original author intended to split the URL string of the 'curl' command into two separate lines, and therefore introduced a backslash (\) to escape the 'NewLine' character that followed. But you have now joined those into a single line, so the backslash character should no longer be there!
The 'curl' command is however a bit forgiving, so it will not give you a clear indication of that error. But the shell will actually interpret your current string "...?\type..." as "...?<TAB>ype...". :o
I'm not sure if that is the root cause of your problem, but it's still an error that should still be cleaned up...
/P-G
Surroot
Post by Surroot » Sunday 12 February 2017 14:18
PeGe wrote:While reading this thread out of pure curiosity, not intending to test or implement the solution in my own environment (due to incompatoble router hardware), I immediately spotted a fundamental error occuring three (3) times in your script:
/P-G
Yes that's right PeGe, I intended to split the line. I thought that there should be less copy/paste errors if there is a line break. As I said in a post before, nano from busybox is a bit strange and sometimes just cuts long lines...
BaliBiker wrote: I hope you can help me with the script. I looks like this..
#!/bin/sh
mac=$1
idx=$2
device_present=Off
device_present=On
fi
done
device_present=On
fi
done
fi
fi
BaliBiker: You should correct these three lines in your script
Sudden81
Post by Sudden81 » Sunday 12 February 2017 14:53
Sorry I'm a beginner and have big problems with programming lua, but most copying and pasting.
My question is simply this, could this be implemented of Domoticz. Or is that too complicated?
You choose your router from a list, then downloading something _ which one can instalera on the router. It was called "Asus Merlin custom firmware" or something like that?
You choose what the user's mac address you want to use.
You choose which network to trigger the 2.5GHz or 5GHz.
You choose the name of virituel switch, and boom, you have a virituel presence switch.
The result will be the same as programming yourself but it gets super much easier for users.
Is this a stupid idea or this would be feasible.
BaliBiker
Post by BaliBiker » Sunday 12 February 2017 16:29
Many thanks Surroot. That did the job. Its all working fine now.
Verstuurd vanaf mijn SM-G935F met Tapatalk
Surroot
Post by Surroot » Sunday 12 February 2017 18:41
Sudden81 wrote:Sorry I'm a beginner and have big problems with programming lua, but most copying and pasting.
Yes I think it's possible to implement this.
Maybe I put all those steps from the presence detection setup in a script in the future, which would be a lot easier for new users to setup the presence detection. But you still have to flash the router firmware manually, I don't think thats a good idea to let another software handle the flash process.
BaliBiker
Re: RE: Re: Yet another presence detection method
Post by BaliBiker » Tuesday 14 February 2017 17:57
ah. damn
I also have AP.
Ik have an AP as well. I like to ad the virtual MAC to the script. Any Idea where I can find the virtual MAC address?
mayyam
Re: RE: Re: RE: Re: Yet another presence detection method
Post by mayyam » Tuesday 14 February 2017 19:55
ah. damn
I also have AP.
On Your router, on device list.
____
may
_______________
- Raspberry Pi 3
- 2x Xiaomi Gateway
Sudden81
Post by Sudden81 » Tuesday 14 February 2017 21:01
Totally agree, not so good with a program that flashes someones router.
I welcome as script!
Thanks in advance!
BaliBiker
Re: RE: Re: RE: Re: RE: Re: Yet another presence detection method
Post by BaliBiker » Tuesday 14 February 2017 23:34
mayyam wrote:
BaliBiker wrote:
mayyam wrote: I also have AP.
____
may
Unfortunately my router doesn't show a virtual MAC address. It shows only one MAC address even when the phone is connected with the AP. Although my router shows my phone in the device list and it is connected via the AP the script reacts as if the phone is not connected. I understand that this logical as the phone is not directly connected with the wifi of the router.
Is the any way to work around this problem?
