[Solve] LUA : attempt to index global 'devicechanged' (a nil value)
deennoo
Post by deennoo » Thursday 09 June 2016 12:43
Hi there,
Got an error on my script and don't know how to solve, maybe someone can help me
1 - Situation :
Running Domoticz (Version: 3.5228) on a Syno + RFLink + RFXTRXE
2 - Goal :
Manage Milight Bulb or wall socket true wall switch with chacon module inside, i want to be able to turn on/off the device or group depending of his previous state who can be drive by a scene or a remote
I Don't care about ON or Off wall switch status, just want : when his status change, script check "esclave device" status and toggle it from On to OFF or OFF to ON
3 - Script :
This one have to drive a wall plug From IDK with a Chacon wall switch
Inter lum Salon : the wall switch
Lumiere Salon = the wall plug
 if (devicechanged['Inter lum salon'])  then
     commandArray['Lumiere Salon']='Toggle'
4 - Current status :
For the Wall switch
1297	Inter lum salon	On	2016-06-09 09:46:59	15
   "ActTime" : 1465469517,
   "ServerTime" : "2016-06-09 12:51:57",
   "Sunrise" : "06:17",
   "Sunset" : "21:45",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 11,
         "HardwareName" : "RFXTRXE",
         "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
         "HardwareTypeVal" : 1,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "1145DC6",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2016-06-09 09:46:59",
         "Level" : 100,
         "LevelInt" : 15,
         "MaxDimLevel" : 15,
         "Name" : "Inter lum salon",
         "Notifications" : "false",
         "PlanID" : "1",
         "PlanIDs" : [ 1 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : 7,
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "1297"
   "status" : "OK",
   "title" : "Devices"
For the wall Plug
105	Lumiere Salon	Off	2016-06-09 09:47:03	0
   "ActTime" : 1465469552,
   "ServerTime" : "2016-06-09 12:52:32",
   "Sunset" : "21:45",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 110,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 25,
         "HardwareName" : "RFLink Ser2net",
         "HardwareType" : "RFLink Gateway with LAN interface",
         "HardwareTypeVal" : 62,
         "ID" : "00000060",
         "Image" : "Lampadaire",
         "LastUpdate" : "2016-06-09 09:47:03",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "Lumiere Salon",
         "PlanID" : "2",
         "PlanIDs" : [ 2, 11 ],
         "SignalLevel" : "-",
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "ELRO AB400",
         "Timers" : "true",
         "Type" : "Light/Switch",
         "Unit" : 4,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "105"
   "status" : "OK",
   "title" : "Devices"
5 - Error :
2016-06-09 12:40:00.959 Error: EventSystem: in Lum salon: [string "commandArray = {} ..."]:2: attempt to index global 'devicechanged' (a nil value)
Your Help will be very appriciated to solve this.
Rfxtrxe / RFLink / Milight / Yeelight / ESP8266 / MQTT / BLE
http://domo-attitude.fr
Raducanu
Target OS: Raspberry Pi
Re: LUA : attempt to index global 'devicechanged' (a nil value)
Post by Raducanu » Thursday 09 June 2016 13:33
I'm also new to LUA, but if i understand https://www.domoticz.com/wiki/Events correctly, you have to specify what changed...
 if (devicechanged['Inter lum salon'] == 'On')  then
Westcott
Post by Westcott » Thursday 09 June 2016 13:58
Is it a 'time' script rather than a 'device' script?
Zwave - Sigma Z+ stick, Fibaro 2x FGSD002, FGMS001
Horstmann - 2x HRT4, 2x C-stat-11, 4x ASR-ZW, TKB 2x TZ56, 2x TZ68E
Max-EQ Cube, Valve, Neo 2x door
RFXtrx433E, RFlink - 1byone driveway, doorbell, Oregon and BangGood temp
Wifi - YeeLight RGB, 3x ESP8266
deennoo
Post by deennoo » Thursday 09 June 2016 14:45
@Westcott t
That a device script i'm looking for a device status change (Chacon wall switch)
deennoo
Post by deennoo » Thursday 09 June 2016 14:54
@Raducanu
even if i try this :
 if (devicechanged['Inter loisir'] == 'On')  then
     commandArray['Plafonnier Loisir']='Toggle'
  if (devicechanged['Inter loisir'] == 'Off')  then
Log give this :
2016-06-09 14:53:00.288 Error: EventSystem: in Lum Loisir: [string "commandArray = {} ..."]:2: attempt to index global 'devicechanged' (a nil value)
Both script works very well and as i'm leasy guy i will use the first, but i don't like thos red line on my log
jvdz
Domoticz version: Stable
Post by jvdz » Thursday 09 June 2016 17:03
When you use the internal script editor make sure you do not have "All" but "Device" selected underneath LUA.
Jos
deennoo
Post by deennoo » Thursday 09 June 2016 20:40
jvdz wrote:When you use the internal script editor make sure you do not have "All" but "Device" selected underneath LUA.
Jos
that it !!!
thank you very much !
sangve
Re: [Solve] LUA : attempt to index global 'devicechanged' (a nil value)
Post by sangve » Wednesday 14 December 2016 0:34
Oh, that's just lovely!
Thank you for helping me with the exact same thing! <3
mbeefcake
Post by mbeefcake » Wednesday 05 April 2017 13:16
Helped me too :) Thanks!
Raspberry Pi 2B with RFXCOM RFXtrx433E
Raspbian Jessie Lite with Domoticz Beta v3.7253
Amazon Echo Dot v2, NEST Thermostat, Smart P1 Meter, YeeLights (White, Color and LED Strip), KaKu switches, Conrad RSLU, Alecto WS1700 and Digoo SB-XYZ Video doorbell
freijn
Post by freijn » Thursday 20 April 2017 15:17
Helped me , many thanks !
Stefan
Domoticz version: 3.5877
Post by Stefan » Sunday 06 August 2017 13:31
helped me too :D bedankt
rammstan
Post by rammstan » Monday 13 November 2017 19:06
Jos
That's it. thanks
RPi 2 + UPS Pico + enOcean + RFXCOM ext 250
digdilem
Post by digdilem » Sunday 28 January 2018 17:12
Another one this helped!
Really non-intuitive behaviour and not a very helpful error message, so glad for this help.
Medzu
Post by Medzu » Tuesday 17 April 2018 14:37
Thnx! :D
