crash webserver offline
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pvklink
Target OS: Raspberry Pi
Post by pvklink » Wednesday 05 December 2018 20:42
I just bought a fresn new rpi 3b+ and installed the latest raspbian and the latest domoticz beta..
Cant access my domoticz. When i do a sudo ./updatebeta i can access my domoticz.
But when i do a shutdown, and restart again i cant access again...
at some point i saw this entries in my log...
2018-12-05 19:36:04.494 Error: > Thread 10 (Thread 0x713ff430 (LWP 466)):
2018-12-05 19:36:04.494 Error: > #0 0x76d4d294 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
2018-12-05 19:36:04.494 Error: > #1 0x003da8dc in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2018-12-05 19:36:04.494 Error: > #2 0x003dc404 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2018-12-05 19:36:04.494 Error: > #3 0x0064819c in tcp::server::CTCPServer::Do_Work() ()
2018-12-05 19:36:04.494 Error: > #4 0x009d3a8c in execute_native_thread_routine ()
2018-12-05 19:36:04.494 Error: > #5 0x76ef3fc4 in start_thread (arg=0x713ff430) at pthread_create.c:335
2018-12-05 19:36:04.494 Error: > #6 0x76d4cbc8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
2018-12-05 19:36:04.494 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
clang
Re: crash webserver offline
Post by clang » Thursday 06 December 2018 23:34
I have the exact same issue.
I have tried with PI B+, Pi 2, and Pi 3
Clean fresh install of latest Raspbain Stretch, install of 4.9700. I get the Domoticz offline page - run updatebeta (12/6), system starts normally and all is good. System restart and domoticz Offline.
clang
Post by clang » Thursday 06 December 2018 23:41
As an addendum, each time I run updatebeta - even with the latest beta release installed, the system comes back online normally. A restart produces the above results.
haajee
Domoticz version: V4.10149
Post by haajee » Monday 10 December 2018 0:30
Here the same. When i shutdown my OrangePi One with Armbian 5.65 and start it up again Domoticz webinterface stay offline. When i give the command 'sudo service domoticz.sh restart' Domoticz runs perfest. If i do a status check when Domoticz webinterface is offline with the command: 'sudo service domoticz.sh status' looks like there are no problems.
Joep123
Post by Joep123 » Monday 10 December 2018 8:20
I had the same problem yesterday. After an OS update everything works perfect again:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo reboot
