[Solved with script]: Variable in Blockly would change automatically another Z-Wave device which is not in the Blockly
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
McJohn
Target OS: Raspberry Pi
Domoticz version: 4.9700
Post by McJohn » Thursday 18 October 2018 10:59
We made a simple script in blocky to change a Variable.
But every time when the script is running, a Neo Siren (ID=1) goes on..
(Which was not mentioned into the variable or into the Blockly.)
So, we made a new blank Variable in a new Blockly script but this script would also change another Z-Wave device..
Every new Variable nummer in a Blockly would change automatically the same number of Z-Wave ID!
How is this possible?
2018-10-18 10:37:56.279 EventSystem: Event triggered: SecPanelVariable_2
2018-10-18 10:37:56.298 (Dummy) Light/Switch (SecurityOn)
2018-10-18 10:37:56.280 Error: EventSystem: Device ('Neo', ID=2) used in event 'SecPanelVariable_2' not found, make sure that it's hardware is not disabled!
Screenshot 2018-10-18 at 10.51.50.png (41.89 KiB) Viewed 238 times
Screenshot 2018-10-18 at 11.00.22.png (59.86 KiB) Viewed 238 times
Screenshot 2018-10-18 at 10.51.50.png (41.89 KiB) Viewed 241 times
Nautilus
Re: Bug: Variable in Blockly would change automatically another Z-Wave device which is not in the Blockly
Post by Nautilus » Friday 19 October 2018 12:39
Strange indeed. But it might be related to your attempt to set a variable On and Off. I think you cannot do that. Depending on the variable type (string, int, boolean), you need to set a string, number or true/false as its status. My guess is that trying to set a the variable to On/Off (something you can only use with a switch) is mixing things up with Blockly and Domoticz...
McJohn
Post by McJohn » Sunday 21 October 2018 10:11
Thanks for your feedback. You maybe right but why is it possible to set a Variable On and Off in a blocky? (True or false are not possible to choose in a blocky). Anyway, the status of the Variable changed with this blocky. We choose another higher Variable number and we have to live with an error in the log that Domoticz also want to switch another Z-Wave device which is not active. :?
Nautilus
Post by Nautilus » Monday 22 October 2018 0:11
I don't think there's any real validation in Blockly so that it would inform when the syntax is incorrect. What comes to Domoticz user variables it seems there's actually no type boolean, please see https://www.domoticz.com/wiki/User_variables for more details. As it says there, all variables are stored as string so to set the variable with Blockly, you need to use the text block.
What do you mean by this, how does it change?
Post by waaren » Monday 22 October 2018 0:37
You cannot set a domoticz variable to On or Off
If the variable is defined as type String you can set it to "On" or "Off" (or any other valid string) and if set to type integer to 0 or 1 (or any other valid integer) etc..
The domoticz variables can be type string, integer, float, date or time. There is no type boolean
In blockly trying to set a type string or integer variable to On or Off will lead to an error like
Error: EventSystem: Error updating variable "varname": Not a valid integer
2018-10-22 00:23:07.385 Error: EventSystem: Device no. '56' used in event event_name' no longer exists, disabling event!
where 56 is the variable ID; could well be that this leads to unexpected results elsewhere in domoticz
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
McJohn
Post by McJohn » Monday 22 October 2018 20:30
Thanks gentlemen for your both explanation.
It's strange that there is the possibility in Domoticz to change a Variable in a Blocky but actually it's forbidden because it give errors..
Anyway, why does we need to change this Variable?
Because "Waaren" made us this perfect script below to set the Domotics Alarm panel On and Off with a one-button key fob.
Works perfect!
But the only problem now is that when the Security is set Armed away or disarmed with the build-in security panel of Domoticz, the Variable (which is needed for there Keyfob...) didn't change. So, when the Security is Armed with the build in panel of Domoticz and has to be disarmed with the keyfob, nothing happened...
When you guys could change the script or have a script instead of our Blockly we not may use ;) , that would be grateful!
Thanks in advance!
Screen Shot 2018-10-22 at 20.15.42.png (140.94 KiB) Viewed 147 times
-- Alarm
on = { devices = { "Keyfob" }},
logging = { level = domoticz.LOG_DEBUG,
marker = "Alarm" },
execute = function(dz, item )
local KeyfobState = item.state
local alarmVar = dz.variables("Alarm")
local securitySwitch = dz.devices("SecurityOn")
local securityPanel = dz.devices(1)
dz.log(item.name .. ", state: " .. item.state,dz.LOG_DEBUG)
if KeyfobState == "On" and alarmVar.value == "On" then
securityPanel.disarm().checkFirst()
securitySwitch.switchOff().checkFirst().silent()
alarmVar.set("Off").silent()
elseif KeyfobState == "On" then
securityPanel.armAway().checkFirst()
securitySwitch.switchOn().checkFirst().silent()
alarmVar.set("On").silent()
Post by waaren » Tuesday 23 October 2018 0:20
....But the only problem now is that when the Security is set Armed away or disarmed with the build-in security panel of Domoticz, the Variable (which is needed for there Keyfob...) didn't change. So, when the Security is Armed with the build in panel of Domoticz and has to be disarmed with the keyfob, nothing happened...
The updated script now also triggers on the panel itself when controlled from outside this script and set the var and dummy switch accordingly.
-- Alarm
local securityPanelIDX = 1                     -- device idx of your security panel
local KeyfobName       = "Keyfob"          -- device name of your Key fob
        on      =   {   devices   = { KeyfobName , securityPanelIDX }},
                        marker      =   "Alarm" },
        local KeyfobState    = dz.devices(KeyfobName).state
        local securityPanel  = dz.devices(securityPanelIDX)
        local function signalAlarmPanelState(armed)
            dz.log(item.name .. ", state: " .. item.state .. "; Setting var and switch to " .. armed ,dz.LOG_DEBUG)
            alarmVar.set(armed).silent()
            securitySwitch.setState(armed).checkFirst().silent()
        if item.idx == securityPanel.idx then                    -- triggered by panel
            if securityPanel.state == "Disarmed" then signalAlarmPanelState("Off")
            else signalAlarmPanelState("On")
            return
            securityPanel.disarm().checkFirst().silent()
            securityPanel.armAway().checkFirst().silent()
McJohn
[Solved] Re: Bug: Variable in Blockly would change automatically another Z-Wave device which is not in the Blockly
Post by McJohn » Tuesday 23 October 2018 10:07
Thank you very much my friend, it's working perfectly!
Case closed! :D
Nautilus
Re: [Solved] Re: Bug: Variable in Blockly would change automatically another Z-Wave device which is not in the Blockly
Post by Nautilus » Thursday 25 October 2018 12:45
Case closed! :D
Good that it is working now! :)
But I think there was a slight misunderstanding earlier:
We did not mean that you couldn't change a variable with Blocky - because you definitely can! :)
But you cannot use a device state (On/Off) for this, you need to use a text block. The string in the text block can then be "On", "Off", "True", "False" or whatever you need it to be. Hope this helps for your future event needs...:)
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
