Domoticz Offline but domoticz.sh service is running
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Neuvidor2307
Target OS: Raspberry Pi
Post by Neuvidor2307 » Saturday 18 August 2018 14:04
Dear everybody,
Version: 4.9700
Platform: RASPBIAN STRETCH LITE June 2018 on Raspberry pi 3 model B
Plugin/Hardware: Virtual switch + RFXCOM
Description: Domoticz server not available by Webserver (Domoticz Offline message) and Android App (empty box)
I checked the domoticz status by SSH and I always get "Domoticz is Running..."
pi@raspberrypi:~ $ sudo service domoticz.sh status
● domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
   Active: active (exited) since Sat 2018-08-18 08:17:11 CEST; 4h 38min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 570 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/domoticz.service
août 18 08:17:10 raspberrypi systemd[1]: Starting LSB: Home Automation System...
août 18 08:17:11 raspberrypi domoticz.sh[570]: 2018-08-18 08:17:11.281  Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
août 18 08:17:11 raspberrypi domoticz.sh[570]: 2018-08-18 08:17:11.290  Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
août 18 08:17:11 raspberrypi domoticz.sh[570]: 2018-08-18 08:17:11.297  Status: Startup Path: /home/pi/domoticz/
août 18 08:17:11 raspberrypi domoticz.sh[570]: domoticz: Domoticz is starting up....
août 18 08:17:11 raspberrypi domoticz[586]: Domoticz is starting up....
août 18 08:17:11 raspberrypi domoticz[590]: Domoticz running...
août 18 08:17:11 raspberrypi systemd[1]: Started LSB: Home Automation System.
If I simply restart the domoticz service, everything works again (webserver + Android App).
pi@raspberrypi:~ $ sudo service domoticz.sh stop
pi@raspberrypi:~ $ sudo service domoticz.sh start
   Active: active (running) since Sat 2018-08-18 12:56:38 CEST; 6s ago
  Process: 5486 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
  Process: 5527 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
           └─5534 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443
août 18 12:56:38 raspberrypi systemd[1]: Starting LSB: Home Automation System...
août 18 12:56:38 raspberrypi domoticz.sh[5527]: 2018-08-18 12:56:38.324  Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
août 18 12:56:38 raspberrypi domoticz.sh[5527]: 2018-08-18 12:56:38.324  Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
août 18 12:56:38 raspberrypi domoticz.sh[5527]: 2018-08-18 12:56:38.324  Status: Startup Path: /home/pi/domoticz/
août 18 12:56:38 raspberrypi domoticz.sh[5527]: domoticz: Domoticz is starting up....
août 18 12:56:38 raspberrypi domoticz[5534]: Domoticz running...
août 18 12:56:38 raspberrypi systemd[1]: Started LSB: Home Automation System.
I have changed the SD-card by a new one (Sandisk 16Gb Ultra), completly new RASPBIAN STRETCH LITE and Domoticz v4.9700 installation but I get the same behavior.
Do you have any idea about this issue ?
Because the raspberry is located into my mother house, the best way is to solve the issue by SSH.
Laulo7
Domoticz version: 3.9030
Re: Domoticz Offline but domoticz.sh service is running
Post by Laulo7 » Tuesday 28 August 2018 20:16
Good evening,
check the date and time of the Pi.
If Date / Time < DATE / TIME of the DOMTICZ.DB file, set the date / time.
It's a long way to the top..
Neuvidor2307
Post by Neuvidor2307 » Tuesday 28 August 2018 23:25
Dear,
As you can read above, the main difference when the system is running or not is that I get "exited" message compared to "running" when I request domoticz.sh status.
System NOK :
System OK :
I have activated the domoticz.txt log file and I have discovered something strange.
Indeed, the "exited" status seems apear when I get "Error: Domoticz received fatal signal 6" message after a lot of "Error: PROXY: Connect failed, reconnecting: Operation canceled".
2018-08-28 21:52:09.425  Error: PROXY: Connect failed, reconnecting: Operation canceled
2018-08-28 21:52:24.428  Error: PROXY: Connect failed, reconnecting: Operation canceled
2018-08-28 21:52:25.105  (RFXCOM) Temp + Humidity (Sonde Salon)
2018-08-28 21:52:33.287  (RFXCOM) Temp + Humidity (Sonde Chambre 1)
2018-08-28 21:52:39.456  Error: PROXY: Handshake failed, reconnecting: Operation canceled
2018-08-28 21:52:39.456  Error: Domoticz received fatal signal 6 !...
2018-08-28 21:52:39.466  Error:   /home/pi/domoticz/domoticz() [0x262154]
2018-08-28 21:52:39.466  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x26220c]
2018-08-28 21:52:39.466  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76ca56b0]
2018-08-28 21:52:39.467  Error:   /lib/arm-linux-gnueabihf/libc.so.6(gsignal+0xa0) [0x76ca445c]
2018-08-28 22:01:41.212  Status: RxQueue: queue worker started...
2018-08-28 22:01:43.213  Status: EventSystem: reset all events...
2018-08-28 22:01:43.214  Status: EventSystem: reset all device statuses...
2018-08-28 22:01:43.248  Status: EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2018-08-28 22:01:43.248  Status: EventSystem: Started
2018-08-28 22:01:43.248  Status: EventSystem: Queue thread started...
2018-08-28 22:01:44.216  Status: RFXCOM: Using serial port: /dev/ttyUSB0
2018-08-28 22:01:44.792
2018-08-28 22:01:44.868  subtype           = Interface Response
Sequence nbr      = 2
response on cmnd  = Get Status
Transceiver type  = 433.92MHz
Firmware version  = 1011
Firmware type     = Ext
Hardware version  = 1.3
Undec             off
X10               enabled
ARC               enabled
AC                enabled
HomeEasy EU       disabled
Another remark, the system still in "Running" mode if I get "Status: PROXY: Authenticate result: success." message.
2018-08-28 22:06:27.327  Error: PROXY: Connect failed, reconnecting: Operation canceled
2018-08-28 22:06:42.355  Error: PROXY: Connect failed, reconnecting: Operation canceled
2018-08-28 22:06:43.093  (RFXCOM) Temp + Humidity (Sonde Salon)
2018-08-28 22:06:51.276  (RFXCOM) Temp + Humidity (Sonde Chambre 1)
2018-08-28 22:06:57.358  Error: PROXY: Connect failed, reconnecting: Operation canceled
2018-08-28 22:07:04.715  (RFXCOM) Temp (Sonde Extérieur)
2018-08-28 22:07:12.360  Error: PROXY: Connect failed, reconnecting: Operation canceled
2018-08-28 22:07:22.103  (RFXCOM) Temp + Humidity (Sonde Salon)
2018-08-28 22:07:27.363  Error: PROXY: Handshake failed, reconnecting: Operation canceled
2018-08-28 22:07:30.269  (RFXCOM) Temp + Humidity (Sonde Chambre 1)
2018-08-28 22:07:42.367  Error: PROXY: Connect failed, reconnecting: Operation canceled
2018-08-28 22:07:43.724  (RFXCOM) Temp (Sonde Extérieur)
2018-08-28 22:07:57.395  Error: PROXY: Connect failed, reconnecting: Operation canceled
2018-08-28 22:08:01.098  (RFXCOM) Temp + Humidity (Sonde Salon)
2018-08-28 22:08:09.264  (RFXCOM) Temp + Humidity (Sonde Chambre 1)
2018-08-28 22:08:12.399  Error: PROXY: Connect failed, reconnecting: Operation canceled
2018-08-28 22:08:19.619  Error: PROXY: Connect failed, reconnecting: Connection refused
2018-08-28 22:08:22.720  (RFXCOM) Temp (Sonde Extérieur)
2018-08-28 22:08:37.010  Status: PROXY: Authenticate result: success.
2018-08-28 22:08:40.107  (RFXCOM) Temp + Humidity (Sonde Salon)
2018-08-28 22:08:48.274  (RFXCOM) Temp + Humidity (Sonde Chambre 1)
2018-08-28 22:09:01.712  (RFXCOM) Temp (Sonde Extérieur)
2018-08-28 22:09:19.100  (RFXCOM) Temp + Humidity (Sonde Salon)
2018-08-28 22:09:27.267  (RFXCOM) Temp + Humidity (Sonde Chambre 1)
2018-08-28 22:09:40.722  (RFXCOM) Temp (Sonde Extérieur)
2018-08-28 22:09:58.093  (RFXCOM) Temp + Humidity (Sonde Salon)
2018-08-28 22:10:06.276  (RFXCOM) Temp + Humidity (Sonde Chambre 1)
2018-08-28 22:10:19.715  (RFXCOM) Temp (Sonde Extérieur)
2018-08-28 22:10:37.104  (RFXCOM) Temp + Humidity (Sonde Salon)
2018-08-28 22:10:45.270  (RFXCOM) Temp + Humidity (Sonde Chambre 1)
2018-08-28 22:10:58.726  (RFXCOM) Temp (Sonde Extérieur)
2018-08-28 22:11:16.097  (RFXCOM) Temp + Humidity (Sonde Salon)
2018-08-28 22:11:24.265  (RFXCOM) Temp + Humidity (Sonde Chambre 1)
2018-08-28 22:11:37.911  (RFXCOM) Temp (Sonde Extérieur)
2018-08-28 22:11:55.092  (RFXCOM) Temp + Humidity (Sonde Salon)
2018-08-28 22:12:03.274  (RFXCOM) Temp + Humidity (Sonde Chambre 1)
2018-08-28 22:12:16.714  (RFXCOM) Temp (Sonde Extérieur)
2018-08-28 22:12:34.102  (RFXCOM) Temp + Humidity (Sonde Salon)
My questions :
Could you explain me how the proxy works ? Where can I check proxy parameters ?
Is there any link with the android app ? (I'm using android app on both phone)
Neuvidor2307
Post by Neuvidor2307 » Tuesday 28 August 2018 23:28
Good evening,
Dear Laulo7,
Could you help me, how can I check that ? Which command ?
Laulo7
Post by Laulo7 » Sunday 02 September 2018 21:21
Dear Neuvidor2307 ,
1) date / heure Domoticz.db
~/domoticz $ ls -l domoticz.db
sep 2 21:15 domoticz.db
2) Define Date
sudo date -s 02092018
3) Define Time ( > Time DOMOTICZ.DB)
sudo date -s 21:16
4) Sudo Reboot
Enjoy!
