Mi Flora plugin fails
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
manjh
Target OS: Raspberry Pi
Domoticz version: 3.8153
Post by manjh » Wednesday 15 August 2018 16:37
I tried to install the Mi Flora plugin, went OK until I tried to pair the sensor.
On the command "sudo tools/btmgmt le on" I get an error message:
"Set connectable for hci0 failed with status 0x11 (Invalid Index)".
Looks like BT is not working on my R-Pi 3. I re-ran everything to install all pre-req packages etcetera, but no result.
Any ideas?
Hans
blauwebuis
Domoticz version: current
Re: Mi Flora plugin fails
Post by blauwebuis » Thursday 16 August 2018 14:20
It's best to do a forum search before you post.
https://domoticz.com/forum/viewtopic.ph ... ra#p188656
manjh
Post by manjh » Thursday 16 August 2018 18:21
You're pointing me at my own post.... :shock: Doesn't help!
Hans
DAVIZINHO
Post by DAVIZINHO » Thursday 16 August 2018 18:26
but this is not a bug, in my case the plugin works perfect. but i can´t help you because i dont know which is the problem
manjh
Post by manjh » Thursday 16 August 2018 18:31
After several days of searching the web, and lots of trial-and-error, I finally found something that helped me solve the BT problem.
https://raspberrypi.stackexchange.com/q ... ooth-issue
It turns out there was a line in config.txt that disabled the BlueTooth.....
Perhaps this can be added to the instructions for Mi Flora installation?
Hans
manjh
Post by manjh » Thursday 16 August 2018 18:35
OK, so now that BT is finally working, I stumbled on the next hurdle.
Currently I own one Xiaomi Flora device, and it shows up OK on the Android App that is available from the manufacturer.
But my R-Pi cannot find it in the scan.
Does anyone know the range of LE Bluetooth? Could the distance be too great?
Hans
vikasaldana
Post by vikasaldana » Tuesday 28 August 2018 9:55
Hey! Looks like only the locale "Mainland China" is fully supported. For now, the trick is to select Locale = "Mainland China" and select Language = "English". However, even with that trick, the location is off, so you don't have access to the full range of feature I guess. When will the United States / Europe version be fully functional ?
Nox Showbox Mobdro
