Domoticz chrashed when hardware edit
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
capman
Post by capman » Friday 10 August 2018 14:41
Version: latest beta
Platform: raspberry pi
Plugin/Hardware: all
When I change some value in my hardware, like active or not ,domoticz crashed.
This is in the crashlog.
[New LWP 1751]
[New LWP 998]
[New LWP 995]
[New LWP 994]
[New LWP 992]
[New LWP 991]
[New LWP 990]
[New LWP 973]
[New LWP 969]
[New LWP 968]
[New LWP 967]
[New LWP 966]
[New LWP 962]
[New LWP 961]
[New LWP 960]
[New LWP 957]
[New LWP 956]
[New LWP 955]
[New LWP 954]
[New LWP 953]
[New LWP 925]
[New LWP 924]
[New LWP 923]
[New LWP 922]
[New LWP 920]
[New LWP 919]
[New LWP 918]
[New LWP 917]
[New LWP 916]
[New LWP 906]
[New LWP 886]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
0x76eaf730 in nanosleep () at ../sysdeps/unix/syscall-template.S:81
81 ../sysdeps/unix/syscall-template.S: Bestand of map bestaat niet.
Thread 32 (Thread 0x76247440 (LWP 886)):
#0 0x76eaf730 in nanosleep () at ../sysdeps/unix/syscall-template.S:81
#1 0x0025e674 in sleep_milliseconds(long) ()
#2 0x002d3dd4 in CSQLHelper::Do_Work() ()
#3 0x00980618 in execute_native_thread_routine ()
#4 0x76ea6e90 in start_thread (arg=0x76247440) at pthread_create.c:311
#5 0x76d0f598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 31 (Thread 0x75a47440 (LWP 906)):
#0 0x76eafef8 in __libc_waitpid (pid=3178, stat_loc=0x75a46540, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:40
#1 0x00228abc in dumpstack_gdb() ()
#2 0x00228f1c in signal_handler(int, siginfo_t*, void*) ()
#3 <signal handler called>
#4 0x762e7fb4 in PyModule_GetDict () from /usr/lib/arm-linux-gnueabihf/libpython3.4m.so
#5 0x005a31cc in Plugins::CPlugin::LoadSettings() ()
#6 0x005aa6f0 in Plugins::CDirectiveBase::Process() ()
#7 0x005ace5c in Plugins::CPluginSystem::Do_Work() ()
#8 0x00980618 in execute_native_thread_routine ()
#9 0x76ea6e90 in start_thread (arg=0x75a47440, arg@entry=<error reading variable: Cannot access memory at address 0x0>) at pthread_create.c:311
#10 0x76d0f598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
/home/pi/dev/gdb-7.7.1+dfsg/gdb/frame.c:472: internal-error: get_frame_id: Assertion `fi->this_id.p' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session? (y or n) [answered Y; input not from terminal]
Create a core file of GDB? (y or n) [answered Y; input not from terminal]
My domoticz log:
2018-08-10 14:51:52.990 Status: Domoticz V4.9817 (c)2012-2018 GizMoCuz
2018-08-10 14:51:53.026 Status: Build Hash: 696904b8, Date: 2018-08-10 08:32:51
2018-08-10 14:51:53.044 Status: Startup Path: /home/pi/domoticz/
2018-08-10 14:51:53.748 Status: EventSystem: reset all events...
2018-08-10 14:51:53.895 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Luchtkwaliteit.lua
2018-08-10 14:51:53.895 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Regen verwacht.lua
2018-08-10 14:51:55.004 Status: PluginSystem: Started, Python version '3.4.2'.
2018-08-10 14:51:55.306 Status: WebServer(HTTP) started on address: 0.0.0.0 with port 8080
2018-08-10 14:51:55.496 Status: WebServer(SSL) started on address: 0.0.0.0 with port 443
2018-08-10 14:51:55.500 Status: Proxymanager started.
2018-08-10 14:51:55.559 Status: Camera: settings (re)loaded
2018-08-10 14:51:55.569 Status: TCPServer: shared server started...
2018-08-10 14:51:55.569 Status: RxQueue: queue worker started...
2018-08-10 14:52:07.902 Status: Kodi: Started
2018-08-10 14:52:07.902 Status: Nest: Worker started...
2018-08-10 14:52:07.902 Status: Logitech Media Server: Worker started...
2018-08-10 14:52:07.912 Status: Logitech Media Server: 2 player-switch(es) found.
2018-08-10 14:52:07.933 Status: AppLamp: Worker Started...
2018-08-10 14:52:07.933 Status: (Reistijd) Started.
2018-08-10 14:52:07.933 Status: (Kodi Players) Started.
2018-08-10 14:52:07.933 Status: (Batterij monitor) Started.
2018-08-10 14:52:07.933 Status: (LG TV) Started.
2018-08-10 14:52:07.933 Status: (Internet speed) Started.
2018-08-10 14:52:07.934 Status: Pinger: Started
2018-08-10 14:52:07.935 Status: Wunderground: Worker started...
2018-08-10 14:52:07.935 Status: EventSystem: reset all events...
2018-08-10 14:52:07.938 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Luchtkwaliteit.lua
2018-08-10 14:52:07.938 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Regen verwacht.lua
2018-08-10 14:52:07.939 Status: EventSystem: reset all device statuses...
2018-08-10 14:52:08.369 Status: PluginSystem: Entering work loop.
2018-08-10 14:52:08.409 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2018-08-10 14:52:08.471 Status: OpenZWave: Starting...
2018-08-10 14:52:08.471 Status: OpenZWave: Version: 1.4-2888-g54682370-dirty
2018-08-10 14:52:08.689 Status: OpenZWave: Driver Ready
2018-08-10 14:52:08.908 Status: RFXCOM: Using serial port: /dev/ttyUSB0
2018-08-10 14:52:10.430 Status: Incoming connection from: 192.168.178.42
2018-08-10 14:52:11.732 Status: OpenZWave: Received timeout notification from HomeID: 3925666186, NodeID: 3 (0x03)
2018-08-10 14:52:19.155 Status: OpenZWave: Received timeout notification from HomeID: 3925666186, NodeID: 3 (0x03)
2018-08-10 14:52:20.614 Status: OpenZWave: Received Node Dead notification from HomeID: 3925666186, NodeID: 4 (0x04)
2018-08-10 14:52:20.615 Status: OpenZWave: Awake Nodes queried
2018-08-10 14:52:39.241 Status: Logitech Media Server: 2 connected player(s) found.
2018-08-10 15:02:49.564 Status: Incoming connection from: 192.168.178.100
I think it have something to do with the python module ? I run python 3.4.2.
