Sonoff(Tasmota) status not same as in Domoticz
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
snuiter
Target OS: Raspberry Pi
Post by snuiter » Monday 06 August 2018 20:22
I have a few Sonoff devices flashed with Tasmota. Every few weeks the lights connected to the sonoff are reported to be switched off in Domoticz but actually they are still switched on. When I open the tasmota webinterface of the sonoff its actual status is still ON.
My perception was that with MQTT the status is being reported of the device, in this case the sonoff(tasmota) switch. So after a seconds/minutes it is reporting to domoticz that it is still On and then changes state in domoticz of the light switch. This is not happening.
Is there something wrong in my configuration, any suggestions how I can trouble shoot this?
Ivo
jake
Re: Sonoff(Tasmota) status not same as in Domoticz
Post by jake » Friday 10 August 2018 18:59
The best solution would be separate 'mqtt virtual hardware': a new status would only be set after an acknowledgement from the device itself.
snuiter
Post by snuiter » Friday 10 August 2018 20:46
Hi Jake,
thanks for the reply, I have been searching the wiki and forum and subsequently the internet but I am not able to understand your comment. The sonoff/tasmota devices are implemented/controlled per wiki MQTT page.
The devices are controlled in domoticz by creating a virtual device, can you explain a bit further or point me to a forum topic or internet page explaining what you mean?
Thanks for your help so far.
Regards,
Ivo
Andyf66
Post by Andyf66 » Friday 10 August 2018 21:05
Are you using the MQTT Tasmota plugin to do the auto-configure?
I use it and it set everything up perfectly - state works transparently and almost instantly in both directions.
snuiter
Post by snuiter » Friday 10 August 2018 21:30
if you mean the domoticz hardware setup "MQTT Client Gateway with LAN interface" then yes I do.
The domoticz switches the light on/off instantly and perfectly but now I have had a few occassions that the night light is switched off in domoticz but the tasmota webinterface shows status "on".
Andyf66
Post by Andyf66 » Friday 10 August 2018 23:18
Nope, that's a different plugin, its this one
https://github.com/emontnemery/domoticz_mqtt_discovery
snuiter
Post by snuiter » Saturday 11 August 2018 16:03
thanks I have installed the plugin, it worked as the tasmota/sonoff devices were auto discovered and added to domoticz. So I removed my old dummy ones. Now I need to check onsite if devices can be switched on/off and if my scripts are working and the original issue where the domoticz status was not aligned with the tasmota switch status.
Thanks so far for your help !!
Greetings,
Ivo
Users browsing this forum: King1987, michelscholte and 7 guests
