Custom icon uploaded not working with latest beta releases
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Jem101
Target OS: Raspberry Pi
Post by Jem101 » Tuesday 26 June 2018 22:56
Can anyone else check and confirm that the custom icon upload feature is broken with the latest beta (and I'm guessing the new stable release version)?
I can prepare the zip file containing the icon files, go to the option in Domoticz, select the file, press the upload button and nothing happens. No error message but the icons never get updated.
I've made sure that caches are cleared, I've tried with three different browsers and also, (just in case), two different themes but with the same result.
Is it just me or is the feature really broken for others as well?
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
Re: Custom icon uploaded not working with latest beta releases
Post by waaren » Tuesday 26 June 2018 23:09
Did you have a look here and checked if it is the same issue ?
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
Jem101
Post by Jem101 » Wednesday 27 June 2018 11:49
I did see that post, yes but in my case although the symptoms are very similar, refreshing the screen (even clearing down all the caches( and reloading doesn't show the new icon.
biggav
Post by biggav » Thursday 28 June 2018 8:48
I have just upgraded to 4.9723 and cant upload anymore either. This is the massage i get from the chrome console. Any ideas?
Custom Icon.JPG (31.92 KiB) Viewed 417 times
biggav
Post by biggav » Friday 29 June 2018 8:57
it now appears to be working however i still get the errors in the console
Jem101
Post by Jem101 » Friday 29 June 2018 9:18
Still doesn't seem to be working for me though. Still the errors in the javascript console and nothing actually gets uploaded when the button is pushed.
Gianni
Post by Gianni » Wednesday 05 September 2018 10:17
create a icon and try to upload
Same error
angular.min.js:124 TypeError: $http.post(...).success is not a function
    at m.$scope.uploadFileToUrl (CustomIconsController.js:14)
    at m.$scope.UploadIconSet (CustomIconsController.js:34)
    at fn (eval at compile (angular.min.js:242), <anonymous>:4:159)
    at e (angular.min.js:288)
    at m.$eval (angular.min.js:151)
    at m.$apply (angular.min.js:151)
    at HTMLButtonElement.<anonymous> (angular.min.js:288)
    at HTMLButtonElement.dispatch (jquery-3.3.1.min.js:2)
    at HTMLButtonElement.y.handle (jquery-3.3.1.min.js:2)
try a icon from the wiki page and that's works well.
So the question is what's the different.
I used a wiki icon and edit the png files and create a new zip.
Thats all but not working.
Ap.zip
(7.85 KiB) Downloaded 9 times
jandirkv
Domoticz version: 3.9117
Post by jandirkv » Sunday 30 September 2018 10:48
I do not upload new icons, I just transfer them to
~/home/pi/domoticz/www/images
and manually change the
switch_icons.txt
through SSH. I add a Line at the bottom of the list with the name of the iconset without the '48_On' extension save it, restart and the custom icon is selectable.
with this Command you can alter the switch file:
sudo nano domoticz/www/switch_icons.txt
I'm also experimenting with the resolution and maximum size of my icons. Haven't figured out what the maximum resolution and size is for Domoticz.
digitallez
Post by digitallez » Friday 26 October 2018 10:23
