Virtual switches missing in all switches tab V3.9639 Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Bufoto
Target OS: Raspberry Pi
Post by Bufoto » Monday 18 June 2018 13:29
Version: 3.9639
Platform: Pi3B
On V.3.9639 I noticed that newly added virtual switches are not showing in the tab ALL Switches; previously added virtual switches are present but a newly added switch can only be seen after adding it to a roomplan. This occurs both in Chrome and in Firefox. I cleared the caches, but that did not make any difference.
Anyone an idea how to solve this? Or is it a bug?
SweetPants
Domoticz version: V4.9999
Re: Virtual switches missing in all switches tab V3.9639
Post by SweetPants » Monday 18 June 2018 13:34
Did you update recently?
check www/js
if domoticz.js, keep it
if domoticz.js.gz, delete it
restart domoticz
Try again
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
Bufoto
Post by Bufoto » Monday 18 June 2018 13:53
Thanks for your quick reply; I checked the folder; both files were present.
I removed the file domoticz.js.gz en rebooted.
Also cleared cache. Problem still there.
Anything else I can try?
SweetPants
Post by SweetPants » Monday 18 June 2018 15:31
Cleared the app. cache too? (different from browser cache)
Tried another (new) browser?
Bufoto
Post by Bufoto » Monday 18 June 2018 16:27
Yes, I did all that. No luck.
I partly solved the problem using the solution given in:
viewtopic.php?t=23036
After doing that the switches were there and I am able to add a new virtual switch.
However, I still cannot add a virtual selector switch; although I see them in Used devices and I can add them to a Room, they are invisible both in All Switches and in Switches in that Room. Are there any issues known with selector switches? I have been using them for a while (with older builds) without a problem.
Bufoto
Post by Bufoto » Monday 18 June 2018 16:49
the problem with the selector switches was solved after a clear cache (again). Do not know why I had to do it again, but the problem is solved.
Thanks Sweetpants for your support!
Users browsing this forum: No registered users and 6 guests
