No log on latest betas Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
mrkrabs
Target OS: Raspberry Pi
Domoticz version: 3.9589
Post by mrkrabs » Saturday 09 June 2018 8:09
Version: 9599 (happened on previous release as well)
Platform: latest raspbian strech
Plugin/Hardware: All plugins are disabled/rasperry pi zero w
Currently domoticz do not log anything when started with loglevel=0. nothing was changed from my side apart from updating to latest beta, so it must be something in that release as 2 days ago logging was working fine. is someone experiencing the same behavior?
SweetPants
Domoticz version: V3.9639
Re: No log on latest betas
Post by SweetPants » Saturday 09 June 2018 8:41
I'm not sure if you can select 0 anymore.
domoticz --help shows:
-loglevel (combination of: normal,status,error,debug)
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
Xztraz
Post by Xztraz » Saturday 09 June 2018 15:19
had same problem. only start and stop logging with loglevel 0
"loglevel normal" works fine
Corrected the wiki to say normal
gerardosamara
Domoticz version: 3.8153
Post by gerardosamara » Monday 11 June 2018 19:39
Hi ,
I had the same issue on the beta 9625 .
The domoticz manual also has to be updated page 8 :
Command Line parameters
The following command line parameters are available:
loglevel (0 =All, 1 =Stat us+Erro r, 2 =Erro r)
Thank you
Domoticz RPi3 V3.8153 + App Android Domoticz Lite V0.1.408 & Imperihome Pro V2.8.4
Zwave+ Z Stick Z90 USB dongle + USB300 Ocean GW dongle + Arduino Serial GW
Smart witch Aeotec DSC24 Gen2
jake
Post by jake » Wednesday 13 June 2018 22:15
I change the domoticz.sh file from "loglevel 0" to "loglevel normal". This makes the log 'tick' again. However, I used to see the updates of all devices, but in the 'Status' tab in a green font all the 'status' of script output. This used to be nice to have a better focus on the 'status' log lines.
Only when I make it into "loglevel status", I see plenty of status messages, but zero device updates.
Is this behaviour for both settings normal? Does it differ from the "loglevel 0"?
jake
Post by jake » Monday 18 June 2018 7:37
jake wrote:I change the domoticz.sh file from "loglevel 0" to "loglevel normal". This makes the log 'tick' again. However, I used to see the updates of all devices, but in the 'Status' tab in a green font all the 'status' of script output. This used to be nice to have a better focus on the 'status' log lines.
Should I use multiple statements, like 'loglevel normal, status, error' or something like that? I already tried the previous sentence, but that gives the same result as 'loglevel normal', only the normal logging.
Users browsing this forum: Bufoto and 8 guests
