Problem with virtual selector switch (3.9464)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
cmartens75
Target OS: Raspberry Pi
Post by cmartens75 » Tuesday 22 May 2018 18:38
Version: 3.9464
Platform: Raspberry Pi
Plugin/Hardware: AeonLabs Z-Wave Plus, RFXCOM, P1-Wifi Gateway
Description: Virtual selector switch not displayed correctly on Dashboard page.
I am using a virtual selector switch (off/on) to activate automatic lighting control in my living room. This virtual selector switch is working correctly in the Switches page in Domoticz (see attachment). However, on the Dashboard page, the virtual switch is not working anymore and the different switch options/levels are displayed incorrectly. I have cleared my cache and have also tried to create a new virtual selector switch. This new switch has the same issues as the current one. In release 3.9462, there were no problems with virtual selector switch. Can somebody please help me? Thanks in advance for your reaction.
Kind regards, Corne
virtual selector switch.docx
(154.06 KiB) Downloaded 34 times
SweetPants
Domoticz version: V3.9639
Re: Problem with virtual selector switch (3.9464)
Post by SweetPants » Tuesday 22 May 2018 19:03
No attachments present, please upload them and place them inline with the message.
BTW, there was a change in the selector switch recently, maybe this has to with it. commit https://github.com/domoticz/domoticz/co ... 04db3d9dd0
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
SweetPants
Post by SweetPants » Tuesday 22 May 2018 20:30
I think this is fixed now, there was a report n github. Please upgrade first
cmartens75
Post by cmartens75 » Tuesday 22 May 2018 20:40
Hi Sweetpants,
Thanks. Upgrading to release 3.9468 solved this issue. Thanks for your support.
Corne
EdwinK
Post by EdwinK » Wednesday 23 May 2018 9:19
Version: 3.9471
Platform: Pi 3
Plugin/Hardware: Hue
Description:
Not sure if this is the same problem, but since 3.9468 I noticed that some switches don't work anymore. After checking I found this:
http%3A//192.168.0.11%3A8080/json.htm%3Ftype%3Dcommand%26param%3Dswitchlight%26idx%3D45%26switchcmd%3DOn
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
DAVIZINHO
Post by DAVIZINHO » Wednesday 23 May 2018 10:47
Same problem with the beta 3.9476.
I have a lot of virtual selector switches and all are crazy :-)
All works fine, but the description of the values are a lot of letters.
This ocurs in floorplan and in switches section
If i edit the virtual selecto switch the values are correct
SweetPants
Post by SweetPants » Wednesday 23 May 2018 20:44
Please upgrade first, this should be fixed.
Edit: I was wrong, in the floorplan the dropdown menu is empty V3.9476, selector switches look ok
DAVIZINHO
Post by DAVIZINHO » Wednesday 23 May 2018 21:56
Yes, with the last update 3.9476 solved the problem with the switches in the switches menu, but in floor plan the party continues. jejeje
Holland
Domoticz version: Beta Ch
Post by Holland » Thursday 24 May 2018 9:05
For me there is still a problem with all selector switches. See screen below
The switches worked perfectly before 3.946x.
But for some reason recent updates changed the script commandline. The colon has been changed to %3A
Strange enough, changing it back to a colon is not possible, as the colon is not saved.
elgringo
Domoticz version: Left
Post by elgringo » Thursday 24 May 2018 20:01
Selector switch is solved in dashboard, but not in room plan:
Running on a PI 3:
Version: 3.9483
Build Hash: a74f7c4a
Compile Date: 2018-05-24 11:42:36
dzVents Version: 2.4.5
Python Version: 3.5.3 (default, Jan 19 2017, 14:11:04) [GCC 6.3.0 20170124]
aurelihein
Post by aurelihein » Saturday 26 May 2018 9:01
Same problem for me I just upgrade to v3.9501 should I restore the database also ?
Thank you for your feedback
Post by waaren » Saturday 26 May 2018 9:06
No.
just clear your browser caches (including appcache)
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave , dzVents 2.4.n, Amazon echo
aurelihein
Post by aurelihein » Saturday 26 May 2018 9:13
Actually this is working with firefox browser
But not working anymore with iOs devices using safari and pilot app https://itunes.apple.com/fr/app/pilot-c ... 46368?mt=8
aurelihein
Post by aurelihein » Saturday 26 May 2018 9:25
No.
Yes waaren thank you ! That makes the job https://support.apple.com/en-us/HT201265
But no idea of how to clear pilot app cache (don't want to uninstall and reinstall since I did in app purchases)
DAVIZINHO
Post by DAVIZINHO » Saturday 26 May 2018 13:40
Same problem for my in somes virtual switchs (not all).
And still problems in floorplan
deennoo
Post by deennoo » Sunday 27 May 2018 11:35
Same for me, that not a web browser issue, but a domoticz one, all my selector switch are down.
html update failure.PNG (57.01 KiB) Viewed 396 times
Rfxtrxe / RFLink / Milight / Yeelight / ESP8266 / MQTT / BLE
http://domo-attitude.fr
DAVIZINHO
Post by DAVIZINHO » Sunday 27 May 2018 11:37
The floorplan isue are solved in the last beta 3.9517.
And the problem with the action i solved replacing the %3A with the :
its a waste of time but easy to resolve :-)
deennoo
Post by deennoo » Sunday 27 May 2018 13:07
i do this for major selector, but i can't to this for all, this will take a full day. Probleme isn't only with : but with all &?:= sigle
elmortero
Domoticz version: 2.3852
Post by elmortero » Monday 28 May 2018 12:02
Hi guys,
Any chance you are using the Weekly Programming (from this topic ?
I just noticed that while updating the selector switches go back to normal. After applying the changes needed for the Weekly programming it goes bad again.
Confirmed this by 1. updating to latest beta 2. apply "weekly programming" - here the selector switch gets corrupted - 3. install the lates beta again - switch goes to normal.
Screenshots added.
WeekProg not applied
The attachment withOutProg.JPG is no longer available
quack3d
Post by quack3d » Thursday 31 May 2018 19:51
I'm not using Weekly Programming and I have %3A in my selector switches in 3.9528. :cry:
Users browsing this forum: Bufoto and 3 guests
