Installation problem
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
rignon
Target OS: Raspberry Pi
Post by rignon » Sunday 13 May 2018 21:14
hello, I try to install domoticz on my raspberry PI3, I followed the wiki to the letter, everything seems to be well except that I do not arrive on any web page by entering the IP address: 8080. I do not have an error except that no web page is displayed. do you have an idea.
Re: Installation problem
Post by waaren » Sunday 13 May 2018 23:07
What do you see if you enter ?
sudo ps -ef | grep domo
btw. What os did you install ?
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
rignon
Post by rignon » Monday 14 May 2018 17:51
hello,
I install RASPBIAN STRETCH LITE version april 2018 kernel 4.14 and the last version stable of domoticz 3.8153
I obtain this result :
pi@domotic:~ $ sudo ps -ef | grep domo
avahi 303 1 0 17:44 ? 00:00:00 avahi-daemon: running [domotic.local]
pi 653 634 0 17:46 pts/0 00:00:00 grep --color=auto domo
Thanks for help
minbiocabanon
Post by minbiocabanon » Monday 14 May 2018 18:47
I may have the same problem as rignon.
Rpi2B+
Version:April 2018
Release date:2018-04-18
Kernel version:4.14
Fresh install today with 'easy way' method... No problem during install.
SSH enabled manually (by adding an ssh file on root partition)
Web interface unreachable (8080 or https 443).
domoticz seems to be not running :
pi@raspberrypi:~/domoticz $ sudo ps -ef | grep domo
pi         725   436  1 18:43 pts/0    00:00:00 grep --color=auto domo
status gives :
pi@raspberrypi:~/domoticz $ sudo /etc/init.d/domoticz.sh status
● domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
   Active: active (exited) since Mon 2018-05-14 18:29:53 CEST; 5min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 662 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
  Process: 672 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
mai 14 18:29:53 raspberrypi systemd[1]: Starting LSB: Home Automation System...
mai 14 18:29:53 raspberrypi domoticz.sh[672]: Illegal instruction
mai 14 18:29:53 raspberrypi systemd[1]: Started LSB: Home Automation System.
I have tried ./updaterelease but it doesn't solve the problem.
Regards,
Minbiocabanon
Post by waaren » Monday 14 May 2018 20:40
What do you see if start domoticz manually ?
cd "your domoticzdir"
./domoticz
rignon
Post by rignon » Monday 14 May 2018 22:26
hello,
i have found soluce :
it's a problem with librarie you have to enter
sudo service domoticz.sh status
if the answer was not ok you whil see why, i solve it whith an install of the beta version of domoticz
thanks all
minbiocabanon
Post by minbiocabanon » Wednesday 16 May 2018 21:39
./domoticz
About my issue :
pi@raspberrypi:~/domoticz $ ./domoticz
Instruction not allowed
Post by waaren » Wednesday 16 May 2018 21:50
try sudo ./domoticz
minbiocabanon
Post by minbiocabanon » Wednesday 16 May 2018 22:11
already tried ;-) same error message
minbiocabanon
Post by minbiocabanon » Friday 18 May 2018 22:05
Like Rignon, updating to beta and then it works ... (webpage is accessible, i didn't go further for now)
Don't know if it is really solved but I can now try domoticz :-)
Users browsing this forum: JoergZ and 7 guests
