Very instable installation - search for reason
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Post by Psybadeck » Monday 19 February 2018 22:46
since 2 days I am playing around with Domoticz 3.8153.
I am using Tasmota Sonoff switches and a Mosquitto server running on an Synology DS 216-II.
Tasmota setup went smooth.
Mosquitto installation took some time to understand, but in the end it works, and I am reading and writing values.
Domoticz has been installed on the Synology and was running quite well.
After setting up all my sensors, setting up the Android app and programming in total 4 events (depending on a read value of a Tasmota Sonoff POW some consumers should be switched), the system ended up to get stuck within minutes.
In order to figure out possible problems I stopped the Package on the Synology and installed Domoticz on an virtual Windows machine running on the Synology. Same effect: System is always freezing after some time / or when I change settings.
Is there any general hint from the experienced users to guide me the correct way?
