Domoticz 3.0.8153-7 crashes on my synology (DS212j 6.1-15047)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
hanssie
Post by hanssie » Sunday 21 January 2018 15:17
version: Domoticz 3.0.8153-7
Platform: synology DS212j 6.1-15047
Plugin/hardware: rfxcom, 4 flamingo switches and one switch that I bought in China (433Mhz Universal Relay 1CH Wireless Remote Switch Receiver Module and RF 433 Mhz Remote Control: QIACHIP KR2201+KT05)
I saw that my Domoticz crashes every day (last night at 01.20h or every two days on my synology while my synology is still running. I believe that domoticz crashed between 8.00 and 8.30 the day before. This means that it not happen at a fixed time. The problem can be "solved" by restarting my synology. Unfortunately, this is not the desired solution. What could be my next step to analyse this problem?
By the way, is it possible to restart Domoticz automatically every night on my Synology (see it as a bypass of above problem).
febalci
Re: Domoticz 3.0.8153-7 crashes on my synology (DS212j 6.1-15047)
Post by febalci » Sunday 21 January 2018 15:58
Hi Hanssie, did you checked log files about an error(/usr/local/domoticz/var/domoticz.log) ? You have to do that before restarting domoticz and synology. Also, Which scripts and python plugins are you using?
hanssie
Post by hanssie » Sunday 21 January 2018 17:05
Hi, many thanks for the quick reply!!! At the moment, I use only blockly scripts. I've attached the log-file
domoticz.log
(39.84 KiB) Downloaded 14 times
. I saw that domotics doesn't work at the moment. I think that there are some problems with rfxcom tranceiver.....
2018-01-21 14:16:05.051 (RFXCOM Tranceiver) Temp + Humidity (Temp en Vocht)
2018-01-21 14:16:44.050 (RFXCOM Tranceiver) Temp + Humidity (Temp en Vocht)
2018-01-21 14:18:00.995 Error: RFXCOM Tranceiver hardware (2) nothing received for more than 1 Minute!....
2018-01-21 14:18:02.015 Error: Restarting: RFXCOM Tranceiver
2018-01-21 14:18:02.144 RFXCOM: Serial Worker stopped...
febalci
Post by febalci » Sunday 21 January 2018 18:25
As i don't have any experience with rfxcom, i cannot be much of help. But it sounds like a definite rfxcom problem.
Users browsing this forum: f14driver and 5 guests
