Battery level check
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pgas37
Battery level check
Post by pgas37 » Friday 15 December 2017 16:30
version: 3.8153
platform: raspberrypi V3. Raspbian-Jesse
RFXcom433e
I copied the script (domoticz wiki/ battery level check Alt. in More/options/Events and adjusted the user configuration (also report time)
Battery Treshold set to 100 to get a report.( see below)
This script failed. No output, no email
Did i missed something?
To get at least a list of all devices i isolated the part __ GET a list of all devices__ and runned that part with an odd output:
----------------092080822165192926933052
Content-type: text/plain; charset=utf-8; format=flowed
Content-transfer-encoding: 7bit
=== I do not understand that output.
Can anyone help??
Paul
-- Check battery level for all used devices
-- User Configuration
BatteryThreshold = 100
WeeklySummary = true
SummaryDay = 6 -- Sunday is 1
EmailTo = "xxx@gmail.com"
ReportHour =15
ReportMinute = 05
Domoticz = "192.168.178.59"
DomoticzPort = "8080"
Message = ''
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- linux
--json = (loadfile "C:\\Domoticz\\scripts\\lua\\json.lua")() -- windows
time = os.date("*t")
-- Weekly Device Battery Summary
if WeeklySummary == true and time.wday == SummaryDay and time.hour == ReportHour and time.min == ReportMinute then
-- Get a list of all devices
handle = io.popen("curl 'http://" .. Domoticz .. ":" .. DomoticzPort .. "/json.htm?type=devices&order=name'")
devicesJson = handle:read('*all')
handle:close()
devices = json:decode(devicesJson)
BattToReplace = false
for i,device in ipairs(devices.result) do
if device.BatteryLevel < 100 and device.Used == 1 then
Message = Message .. device.Name .. ' battery level is ' .. device.BatteryLevel .. '%<br>'
print(device.Name .. ' battery level is ' .. device.BatteryLevel .. '%')
commandArray['SendEmail']='Domoticz Battery Levels#'.. Message .. '#' .. EmailTo
-- Daily Low Battery Report
elseif time.hour == ReportHour and time.min == ReportMinute then
handle:close()
if device.BatteryLevel < BatteryThreshold and device.Used == 1 then
SweetPants
Domoticz version: V4.9701
Re: Battery level check
Post by SweetPants » Saturday 16 December 2017 18:02
Please use code sections when posting code/scripts, makes it much easier to read.
I use this script using dzVentz and telegram to report all devices with low battery, but you can easily adapt it to send emails.
local BATTERY_THRESHOLD = 20
	active = true,
		timer = { 'every hour' }
	execute = function(domoticz)
	local function telegram(msg)
            domoticz.openURL('https://api.telegram.org/<yourbot>/sendMessage?chat_id=<your chat_id>&text=' .. msg)
        domoticz.log('Low battery warning fired:')
		local message = ''
		-- first filter on low battery level
		local lowOnBat = domoticz.devices().filter(function(device)
		local level = device.batteryLevel   -- level is 0-100%
		return (level ~= nil and            -- not all devices have this attribute
					level <= BATTERY_THRESHOLD)
		end)
		-- then loop over the results
		lowOnBat.forEach(function(lowDevice)
			message = message .. 'Device ' ..
				lowDevice.name .. ' is low on battery (' .. tostring(lowDevice.batteryLevel) .. '), '
		end)
		if (message ~= '') then
			telegram(message)
PS: I'm using latest Beta with dzVentz 2.3.0
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
pgas37
Post by pgas37 » Saturday 16 December 2017 18:32
Thanks for your advice. I did not know. Very new here.
i will look into your script. Sorry, but what is “ telegram”?
I did some test with the script from wiki and published here;
When i set the batterythreshold above the measured level by domoticz then the script sends a correct readable emailmessage!
Otherwise i get the unreadable output.
Maybe someone else can make sense of this.
Regard
Paul
SweetPants
Post by SweetPants » Saturday 16 December 2017 18:52
Telegram is the Russian version of Whatsapp. Messages are send almost instantly to you phone or PC. Take a look at http://www.domoticz.com/wiki/Telegram_Bot
Users browsing this forum: Fabnik1s and 4 guests
