Bug in level widget display (Beta 3.8783)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pshadoko
Target OS: Raspberry Pi
Post by pshadoko » Friday 15 December 2017 12:02
Hi all of you harder worker. :D
I notice when I upgraded from last stable to beta 3.8783 (because of the display counter lastweek bug) that now there is a bug on displaying widget for multilevel switch in button mode
When there is a lot of levels, they are displayed out off the widget box.
Use a raspberry raspbian up to date.
Best regards and thank you for this beautifull project.
SweetPants
Domoticz version: V3.9462
Re: Bug in level widget display (Beta 3.8783)
Post by SweetPants » Friday 15 December 2017 16:36
Did you follow the red forum rules concerning app cache and browser cache? (both are different things)
Ubuntu 16.04.3 LTS on Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.1.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
pshadoko
Post by pshadoko » Saturday 16 December 2017 12:20
Hi thank you for the first reply of my first post... :D
Version: 3.8789
Platform: raspberry pi with the raspbian OS up to date
Plugin/Hardware: OpenZwave / RFXCOM
Description:
There is a bug on displaying widget for multilevel switch in button mode When there is a lot of levels, they are displayed out off the widget area
I have cleared all navigators (chrome/firefox) caches from Win and app cache by restarting domoticz and raspberry
I have updgraded from latest stable to beta 3.8783 and today upgrade to beta 3.8789
Usualy I use the elemental theme, so I do a couple of tests with the others themes
But the problem is still there.
If someone that use one of the 2 releases 3.8783 or 3.8789 could make a test to infirm or confirm the display problem.
Best regards
SweetPants
Post by SweetPants » Saturday 16 December 2017 17:26
I'm on 3.8789 and created a multi (Off + 6) level switch using elemental theme but can't replicate this. If I remember correctly this was reported before, but don't know what the solution was. I will check later.
Edit: My bad, this problem was related to a counter device with multiple the same entries https://github.com/domoticz/domoticz/issues/1950, but it looks similar
zak45
Domoticz version: V3.9056
Post by zak45 » Sunday 17 December 2017 0:42
the same here.
V8740 on win 10 / Firfox or Chrome the same
SweetPants
Post by SweetPants » Sunday 17 December 2017 12:17
I did not read the initial post correct. If you want more selector buttons better use menu style selectors instead of button set.
Users browsing this forum: Google [Bot] and 4 guests
