MiLight Controller - Domoticz
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
poudenes
Domoticz version: 3.8993
Post by poudenes » Friday 15 December 2017 11:49
Hi All,
Version: V3.8783
Platform: Rasbian
Plugin/Hardware: Applamp (Milight Controller)
Description:
I'm not sure, but i think there are little bug between MiLIght Controller and Domoticz.
Sometimes the device to turn on a bulb of MiLight doesn't work anymore. When i check the log i don't see any lines to turn them on.
After a restart the AppBridge is coming back and then everything work again.
When i check this on my Homekit using Homebridge everything is working but when the AppBridge is disconnect, or broken in domoticz in homekit all bulbs are in "updating" status.
After the restart all bulbs are coming back in Homekit as well.
I have this problem in all beta versions. Im using now V3.8783
Does someone have same issues or know how to solve this?
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
jono
Target OS: Raspberry Pi
Re: MiLight Controller - Domoticz
Post by jono » Wednesday 20 December 2017 9:16
I cannot get mine to work get the error message
2017-12-19 17:07:17.773 Error: AppLamp: Bridge not found, check IP Address/Port!...
2017-12-19 17:07:17.774 Error: AppLamp: Worker stopped!...
Any ideas
poudenes
Post by poudenes » Wednesday 20 December 2017 12:16
Add the correct IP and port in the Hardware settings?
Port: 5987
jono
Post by jono » Tuesday 26 December 2017 22:54
poudenes wrote:Add the correct IP and port in the Hardware settings?
Port: 5987
I changed the ip and port settings on the Mi-Light WiFi controller settings and added it to Domoticz hardware ,
Also configured my router file wall settings but still no joy
Users browsing this forum: BartdaMan, Google [Bot] and 9 guests
