domoticz last beta
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
matteos1
domoticz last beta
Post by matteos1 » Saturday 21 October 2017 20:10
after installed via web last beta version,. domoticz not start?
there is some problem??
Vox1100
Target OS: Raspberry Pi
Re: domoticz last beta
Post by Vox1100 » Saturday 21 October 2017 23:10
Same problem :shock:
FatCat
Post by FatCat » Saturday 21 October 2017 23:15
Hello
It could be due to missing libssl1.1 library
viewtopic.php?f=6&t=19987
Vox1100
Post by Vox1100 » Sunday 22 October 2017 11:18
updaterelease works for me.
cd domoticz
./updaterelease
got it running again ;)
mosjonathan
Post by mosjonathan » Sunday 22 October 2017 13:14
Hello
i followd the directions in that post and beta is working again.
gizmocuz
Post by gizmocuz » Sunday 22 October 2017 13:26
So.... when posting a 'bug/problem', you will see a red block with 'Forum rules'
Hardware/Platform anyone ? Which OS distribution, what raspberry ? Is it a 3 ? Do you run a 32 bit or 64 bit on this ?
Did you update your system ?
mosjonathan
Post by mosjonathan » Sunday 22 October 2017 13:40
i'm on raspberry pi 2b with rasbian jessie
gizmocuz
Post by gizmocuz » Sunday 22 October 2017 13:44
Thanks for reporting.
I am building/testing on a new build system with some patches.
What is the crash log with the latest beta ?
When you updated to the beta, go to the domoticz folder and start domoticz by hand with:
./domoticz
did you try a
sudo apt update
sudo apt upgrade
mosjonathan
Post by mosjonathan » Sunday 22 October 2017 13:48
Oct 22 09:27:24 domoticz-thuis systemd[1]: Starting LSB: Home Automation System...
Oct 22 09:27:24 domoticz-thuis domoticz.sh[1816]: /home/pi/domoticz/domoticz: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory
after installing that file it works again.
edit:
i'm fully updated, did a apt-get update an apt-get upgrade prior to upgrading domoticz
gizmocuz
Post by gizmocuz » Sunday 22 October 2017 13:50
That should hopefully be solved soon... but each test cost me 1+ hour...
gizmocuz
Post by gizmocuz » Sunday 22 October 2017 13:52
I'll give an update when 'that' beta is online
mosjonathan
Post by mosjonathan » Sunday 22 October 2017 13:53
thanks for your effords :)
Derik
Post by Derik » Sunday 22 October 2017 15:35
mmm
version 3.8627
with this and the beta before this one, i do have a otgw problem....
In my log:
2017-10-22 15:34:18.217 (D.M.: Zwave) General/kWh (Z: Slaapkamer)
2017-10-22 15:34:18.593 OTGW: T80383C00
2017-10-22 15:34:18.712 OTGW: B4038FFFF
2017-10-22 15:34:19.127 (D.M.: RFXcomE) Wind (D.M.: Wind)
2017-10-22 15:34:19.148 OTGW: T00394B00
2017-10-22 15:34:19.267 OTGW: BF0394B00
2017-10-22 15:34:19.278 OTGW: AC0395A00
2017-10-22 15:34:19.703 OTGW: T10010A00
2017-10-22 15:34:19.822 OTGW: BD0010A00
2017-10-22 15:34:20.274 OTGW: T80000200
2017-10-22 15:34:20.393 OTGW: B40000200
2017-10-22 15:34:20.438 (D.M.: Zwave) Usage (Z: Screen)
2017-10-22 15:34:20.443 (D.M.: Zwave) General/kWh (Z: Screen Totaal)
2017-10-22 15:34:20.598 (D.M.: Zwave) General/kWh (Z: Screen Totaal)
2017-10-22 15:34:20.722 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Tuin rechts)
2017-10-22 15:34:20.759 (D.M.: Zwave) Usage (Z: Screen)
2017-10-22 15:34:20.764 (D.M.: Zwave) General/kWh (Z: Screen Totaal)
2017-10-22 15:34:20.828 OTGW: T80190000
2017-10-22 15:34:20.840 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Afzuig)
2017-10-22 15:34:20.947 OTGW: BC0191300
2017-10-22 15:34:21.383 OTGW: T80000200
2017-10-22 15:34:21.502 OTGW: B40000200
2017-10-22 15:34:21.579 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Close-in)
2017-10-22 15:34:21.663 (D.M.: Zwave) Usage (Z: Scherm)
2017-10-22 15:34:21.668 (D.M.: Zwave) General/kWh (Z: Scherm Totaal)
2017-10-22 15:34:21.833 (D.M.: Zwave) General/kWh (Z: Scherm Totaal)
2017-10-22 15:34:21.938 OTGW: T80000200
2017-10-22 15:34:22.005 (D.M.: Zwave) Usage (Z: Scherm)
2017-10-22 15:34:22.009 (D.M.: Zwave) General/kWh (Z: Scherm Totaal)
2017-10-22 15:34:22.036 Incoming connection from: 63.143.42.242
2017-10-22 15:34:22.057 OTGW: B40000200
2017-10-22 15:34:22.188 (D.M.: Zwave) Usage (Z: Pellet Actueel)
2017-10-22 15:34:22.215 (D.M.: Zwave) General/kWh (Z: Pellet Totaal)
2017-10-22 15:34:22.244 (D.M.: Zwave) General/kWh (Z: Pellet Totaal)
2017-10-22 15:34:22.278 (D.M.: Zwave) Usage (Z: Pellet)
2017-10-22 15:34:22.299 (D.M.: Zwave) General/kWh (Z: Pellet Totaal)
2017-10-22 15:34:22.391 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2017-10-22 15:34:22.492 OTGW: T80000200
2017-10-22 15:34:22.611 OTGW: B40000200
2017-10-22 15:34:23.047 OTGW: T00110000
2017-10-22 15:34:23.166 OTGW: BC0110000
2017-10-22 15:34:23.207 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Terrarium)
2017-10-22 15:34:23.322 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Dakrand)
2017-10-22 15:34:23.482 (D.M.: P1) P1 Smart Meter (D.M. P1: Stroom)
2017-10-22 15:34:23.593 (D.M.: Zwave) General/kWh (Z: Lanswitch)
2017-10-22 15:34:23.601 OTGW: T80000200
2017-10-22 15:34:23.720 OTGW: B40000200
2017-10-22 15:34:24.005 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Tuin midden)
2017-10-22 15:34:24.157 OTGW: T80000200
2017-10-22 15:34:24.254 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Terrarium)
2017-10-22 15:34:24.275 OTGW: B40000200
2017-10-22 15:34:24.312 (D.M.: Zwave) Usage (Z: Lanswitch)
2017-10-22 15:34:24.318 (D.M.: Zwave) General/kWh (Z: Lanswitch)
2017-10-22 15:34:24.710 OTGW: T10010A00
2017-10-22 15:34:24.715 (D.M.: RFXcomE) Temp + Humidity (D.M.: Zboiler In)
2017-10-22 15:34:24.800 (D.M.: Zwave) General/Voltage (Z: Lanswitch)
2017-10-22 15:34:24.829 OTGW: BD0010A00
2017-10-22 15:34:25.015 (D.M.: Winddelen) General/kWh (D.M.: 3x Jonge Held)
2017-10-22 15:34:25.264 OTGW: T80000200
2017-10-22 15:34:25.291 (D.M.: Zwave) Current (Z: Lanswitch)
2017-10-22 15:34:25.383 OTGW: B40000200
2017-10-22 15:34:25.818 OTGW: T80190000
2017-10-22 15:34:25.871 (D.M.: RFXcomE) Temp + Humidity (D.M.: Zboiler Uit)
2017-10-22 15:34:25.938 OTGW: BC0191300
2017-10-22 15:34:26.135 (D.M.: Zwave) General/Percentage (Z: Lanswitch)
2017-10-22 15:34:26.373 OTGW: T80000200
2017-10-22 15:34:26.460 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Tuin links)
2017-10-22 15:34:26.492 OTGW: B40000200
2017-10-22 15:34:26.928 OTGW: T00120000
2017-10-22 15:34:27.013 (D.M.: Zwave) General/kWh (Z: Printer)
2017-10-22 15:34:27.019 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Tuin midden)
2017-10-22 15:34:27.047 OTGW: B40120133
2017-10-22 15:34:27.305 (D.M.: Zwave) Usage (Z: Printer)
2017-10-22 15:34:27.311 (D.M.: Zwave) General/kWh (Z: Printer)
2017-10-22 15:34:27.482 OTGW: T80000200
2017-10-22 15:34:27.542 (D.M.: Zwave) General/Voltage (Z: Printer)
2017-10-22 15:34:27.597 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Close-in)
2017-10-22 15:34:27.601 OTGW: B40000200
2017-10-22 15:34:27.805 (D.M.: RFXcomE) Temp + Humidity (D.M.: SB2100TL)
2017-10-22 15:34:27.842 (D.M.: Zwave) Current (Z: Printer)
2017-10-22 15:34:28.037 OTGW: T80000200
2017-10-22 15:34:28.081 (D.M.: Zwave) General/Percentage (Z: Printer)
2017-10-22 15:34:28.156 OTGW: B40000200
2017-10-22 15:34:28.593 OTGW: T80000200
2017-10-22 15:34:28.712 OTGW: B40000200
2017-10-22 15:34:28.922 (D.M.: Zwave) General/kWh (Z: Paneel Totaal)
2017-10-22 15:34:29.078 (D.M.: Zwave) Usage (Z: Paneel)
2017-10-22 15:34:29.083 (D.M.: Zwave) General/kWh (Z: Paneel Totaal)
2017-10-22 15:34:29.148 OTGW: T80000200
2017-10-22 15:34:29.267 OTGW: B40000200
2017-10-22 15:34:29.702 OTGW: T10010A00
2017-10-22 15:34:29.821 OTGW: BD0010A00
2017-10-22 15:34:29.947 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: INDICATOR, Label: Indicator, Instance: 1
2017-10-22 15:34:29.948 OpenZWave: Unhandled class: 0x87 (INDICATOR), NodeID: 14 (0x0e), Index: 0, Instance: 1
2017-10-22 15:34:30.256 OTGW: T80000200
2017-10-22 15:34:30.375 OTGW: B40000200
2017-10-22 15:34:30.811 OTGW: T80190000
2017-10-22 15:34:30.930 OTGW: BC0191300
2017-10-22 15:34:31.365 OTGW: T80000200
2017-10-22 15:34:32.039 OTGW: B40000200
2017-10-22 15:34:32.440 (D.M.: RFXcomE) Temp + Humidity (Buiten: Terras)
2017-10-22 15:34:32.474 OTGW: T80000200
2017-10-22 15:34:32.593 OTGW: B40000200
2017-10-22 15:34:32.688 (D.M.: Zwave) General/kWh (Zter: UVB)
2017-10-22 15:34:32.886 (D.M.: RFXcomE) Temp (Garage)
2017-10-22 15:34:33.029 OTGW: T80000200
2017-10-22 15:34:33.088 (D.M.: Zwave) Usage (Z: Ter UVB)
2017-10-22 15:34:33.093 (D.M.: Zwave) General/kWh (Zter: UVB)
2017-10-22 15:34:33.121 (Bpi) General/Percentage (Bpi: CPU)
2017-10-22 15:34:33.127 (D.M.: RFXcomE) Wind (D.M.: Wind)
2017-10-22 15:34:33.147 OTGW: B40000200
2017-10-22 15:34:33.468 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Tuin links)
2017-10-22 15:34:33.491 (D.M.: P1) P1 Smart Meter (D.M. P1: Stroom)
2017-10-22 15:34:33.515 (D.M.: Zwave) General/Voltage (ZTer: Voltage)
2017-10-22 15:34:33.547 EventSystem: Event triggered: Dummy: Terugleveren_1
2017-10-22 15:34:33.593 OTGW: T80000200
2017-10-22 15:34:33.594 (D.M. Van Alles: Dummy) Light/Switch (D.M.: Terugleveren D)
2017-10-22 15:34:33.657 EventSystem: Event triggered: Keuken: Close-in_2
2017-10-22 15:34:33.659 EventSystem: Event triggered: Laders_1
2017-10-22 15:34:33.659 Error: EventSystem: Malformed action sequence!
2017-10-22 15:34:33.676 OpenZWave: Domoticz has send a Switch command! NodeID: 41 (0x29)
2017-10-22 15:34:33.682 (D.M.: Zwave) Light/Switch (Z: Keuken Close-in T)
2017-10-22 15:34:33.712 OTGW: B40000200
2017-10-22 15:34:33.891 (D.M.: Zwave) Current (Z: UVB)
2017-10-22 15:34:34.099 (D.M.: Xiaomi Gateway) Light/Switch (X: Poort)
2017-10-22 15:34:34.148 OTGW: T80000200
2017-10-22 15:34:34.267 OTGW: B40000200
2017-10-22 15:34:34.296 (D.M.: Zwave) General/Percentage (ZTER: UVB)
2017-10-22 15:34:34.702 OTGW: T10010A00
2017-10-22 15:34:34.821 OTGW: BD0010A00
2017-10-22 15:34:35.274 OTGW: T80000200
2017-10-22 15:34:35.298 (D.M.: Winddelen) General/kWh (D.M.: 3x Jonge Held)
2017-10-22 15:34:35.381 (D.M.: Zwave) Light/Switch (Alarm Type)
2017-10-22 15:34:35.389 (D.M.: Zwave) Light/Switch (Alarm Level)
2017-10-22 15:34:35.393 OTGW: B40000200
2017-10-22 15:34:35.394 (D.M.: Zwave) General/Alarm ($ ZTER: spotjes)
2017-10-22 15:34:35.410 (D.M.: Zwave) Light/Switch ($ ZTER: t Ter spotjes)
2017-10-22 15:34:35.828 OTGW: T80190000
2017-10-22 15:34:35.947 OTGW: BC0191300
2017-10-22 15:34:36.211 OpenZWave: Value_Added: Node: 53 (0x35), CommandClass: INDICATOR, Label: Indicator, Instance: 1
2017-10-22 15:34:36.211 OpenZWave: Unhandled class: 0x87 (INDICATOR), NodeID: 53 (0x35), Index: 0, Instance: 1
2017-10-22 15:34:36.218 (D.M.: RFXcomE) Temp + Humidity (D.M.: SofarSolar)
2017-10-22 15:34:36.383 OTGW: T80000200
So can it be that there is something wrong this 2 beta versions?
Before the otgw works fine...
I did change no thing..?
gizmocuz
Post by gizmocuz » Monday 23 October 2017 8:43
new beta online.. same version, but different build
Could you try this one (3.8627+)
@Derik:
The OTGW is not related to the beta, try restarting the OTGW hardware again.
Using it myself for many years, no issue here, it missed a command to switch to another output mode.. for some reason that it should not
Maybe you use two programs ?
Also please before reporting those issues, have a look at our github source code page, open the otgw cpp file, have a look in the history to see when something changes
Just going here and search for 'OTGW' will reveal the last change was 7 months ago (minor) till two years:
https://github.com/domoticz/domoticz/tr ... t/hardware
If you do not do this, and just shout in the open something has changed related to the OTGW you freak other users...
MattLittle
Post by MattLittle » Monday 23 October 2017 11:44
Hi gizmocuz.
Had the issue others described with previous betas.
Now works as it should with v. 3.8627.
Thanks for you hard work you clever man =)
gizmocuz
Post by gizmocuz » Monday 23 October 2017 13:49
Great, i am now statically linking OpenSSL 1.0.2l (25 September 2017)
Eximos
Post by Eximos » Monday 23 October 2017 18:02
Ny "Aeotec DSB28 Home Energy Meter (2nd Edition)" stopped working after I installed the latest beta (3.8630) i have run the stable version but after a bug on a fibary switch I tried the latest beta and that fixed that problem. This morning i noticed that the Energy meter reports 0 on all meters. 8 am this moring they all dropped to zero and have stayed there. The strange thing is that i upgraded domoticz yesterday and it worked fine until this morning.
So either the meter broke or there is some bug in the beta. I really hope for the later :)
Id do still send reports in the log so its not silent and dead that way.
Any idea if something has been updated or touched since the stable version that can affect the meter?
SweetPants
Domoticz version: V4.10069
Post by SweetPants » Monday 23 October 2017 18:59
There where some changes in the latest Beta concerning P1, don't know if it is related to your problem though
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
Mace
Domoticz version: 3.8153
Post by Mace » Monday 23 October 2017 22:39
After trying to update to the latest Beta, I've got a non-starting Domoticz on my hand, I get a 'Segmentation fault'.
Running on a Pi 3.
Already did a get update / upgrade and ran the update from the command line (./domoticz), gives the following:
2017-10-23 22:32:44.072  Domoticz V3.8630 (c)2012-2017 GizMoCuz
2017-10-23 22:32:44.072  Build Hash: e114cf23, Date: 2017-10-23 13:49:56
2017-10-23 22:32:44.073  Startup Path: /home/xxx/domoticz/
2017-10-23 22:32:44.137  Sunrise: 08:22:00 SunSet:18:30:00
2017-10-23 22:32:44.137  EventSystem: reset all events...
2017-10-23 22:32:44.139  EventSystem: Write file: /home/xxx/domoticz/scripts/dzVents/generated_scripts/Real time weather data.lua
2017-10-23 22:32:44.260  PluginSystem: Started, Python version '3.5.3'.
2017-10-23 22:32:44.262  Philips Hue: Using default poll interval of 10 secs.
2017-10-23 22:32:44.270  Active notification Subsystems: email, gcm, http, pushbullet (4/13)
2017-10-23 22:32:44.271  WebServer(HTTP) started on address: :: with port 8080
2017-10-23 22:32:44.280  Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2017-10-23 22:32:44.280  Error: WebServer(SSL) check privileges for opening ports below 1024
2017-10-23 22:32:44.281  Proxymanager started.
2017-10-23 22:32:44.282  Starting shared server on: :::6144
2017-10-23 22:32:44.283  TCPServer: shared server started...
2017-10-23 22:32:46.288  Hardware Monitor: Started
2017-10-23 22:32:51.304  EventSystem: reset all events...
2017-10-23 22:32:51.305  EventSystem: Write file: /home/xxxx/domoticz/scripts/dzVents/generated_scripts/Real time weather data.lua
2017-10-23 22:32:51.306  EventSystem: reset all device statuses...
2017-10-23 22:32:51.599  Python EventSystem: Initalizing event module.
2017-10-23 22:32:51.600  EventSystem: Started
2017-10-23 22:32:51.600  EventSystem: Queue thread started...
2017-10-23 22:32:51.643  PluginSystem: Entering work loop.
Segmentation fault
Any thoughts?
Mace
Post by Mace » Tuesday 24 October 2017 20:49
Have been trying different things to solve my problem. Only way I can get my Domoticz back online is to force a ./updaterelease. After that, Domoticz comes online again and all seems to be working good again (sensors and switches I've tried works). According to the "About" section, I'm on V3.8153. Also get a pop-up that a new beta is available: 8631. As soon as I update to this version, the problem is back again: Domoticz won't start properly any more, ending in Segmentation fault.
This is what I can retrieve in the log (domoticz2.log):
20:52:13.371  Error: EventSystem: in dzVents.lua: cannot open dzVents.lua: No such file or directory
2017-10-24 20:52:13.530  Error: Domoticz received fatal signal 11 !...
2017-10-24 20:52:13.532  Error:   /home/xxx/domoticz/domoticz() [0x22398c]
2017-10-24 20:52:13.532  Error:   /home/xxx/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x223a44]
2017-10-24 20:52:13.532  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76cb76b0]
Can't imagine I'm the only one, please look into this.
Users browsing this forum: Martin and 5 guests
