1 wire counter DS2423 wrong data
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
JMdomotique
Target OS: Raspberry Pi
Post by JMdomotique » Sunday 03 September 2017 23:01
Version: 3.8153 now 3.873
Platform: Raspberry Pi 3
Plugin/Hardware: RFX (PCR800 , 2 x THGR810 ), 1-wire( 2 x DS1820 3 x DS2423 , 1 x DS2408, DS9490-usb )
Hi All,
All devices and system worked very well before update to 3.8153 .
since update to 3.8153, all DS2423 devices reading are wrong in domoticz.
Today I made the update to 3.873, no progress. Exactly the same problems.
Description:
It seem there is a reading problem with this number :
Device : 12C7 with SSH reading = 4469177 but in domoticz = 429467295 ???
Device : 2A6E with SSH reading = 27000004 but in domoticz = 429467295 ???
Device : 1C6C with SSH reading = 3205423 but in domoticz = 3205424128 ???
Strange, I find nothing that could explain this trouble.
Find below the screen shot .
Hope somebody could help me to understand and solve this issue.
Many thanks in advance.
JMdomotique
Re: 1 wire counter DS2423 wrong data
Post by JMdomotique » Monday 04 September 2017 23:03
Hi guys,
nobody is using DS2423 dual counters ?
please help me
toast
Post by toast » Tuesday 05 September 2017 22:15
This is how it's been for me for a long time if your issue is the same.
In the source code the counter is multiplied with 1000. I always remove this when I compile to get the correct counter. I think your first values är what you get when the value is to large for the calculation. That's why they are the same.
I don't know what the intention is to multiply with 1000.
Perhaps something to do with power meter and kWh...
JMdomotique
Post by JMdomotique » Thursday 07 September 2017 0:33
Hi toast,
many thanks for your answer.
I think you right this multiplication with 1000 will bring the value to large.
Could you explain me please how you proceed to remove this multiplication .
And also where I can find the source code and how you proceed for the compilation.
I never do that task, but I open for learning.
Thanks in advance for your support
toast
Post by toast » Thursday 07 September 2017 8:05
You probably find guides on the wiki how to download the git repository and compile from sources.
I make this change for the counter
In the file: hardware/DomoticzHardware.cpp
unsigned long counter = (unsigned long)(metervalue*1000.0f);
To
unsigned long counter = (unsigned long)(metervalue*1.0f);
JMdomotique
Post by JMdomotique » Sunday 10 September 2017 12:15
Hi toast,
many, many thanks for your help.
After some hours I found the guides to download and compile the sources directly in the raspberry pi.
I have now follow your instructions and upgrade the installation to version v3.8390.
This version use dark-th3me Theme after compilation.
You are absolutely right. The trouble is coming from this "metervalue*1000" .
Compilation is a very long process but the result is amazing. Since months I tried to find a way to resolve this trouble.
Find below screen shots of the result after the modification. On one counter you can see a small different.
(This is coming from the small delay between the both screen shots.)
@ all,
is there really no way to correct this wrong calculation with big number ???
What is the advantage with the multiplication of the metervalue by 1000 ????
Anyway thanks again very much this method help me to follow from now my electricity energy.
gizmocuz
Post by gizmocuz » Sunday 10 September 2017 12:21
Okey, you should not edit DomoticzHardware.cpp as this is used by many hardware classes (classes without this error)
So this error/problem must be inside the 1wire class, and this class needs to be patched.
But please discuss it with the creator of this class before submitting a pull request with the needed changes
JMdomotique
Post by JMdomotique » Thursday 14 September 2017 8:29
Hi gizmocuz ,
understood tank's.
could you made me in connection with the creator of the one wire class and/or indicate where the concerned class is located ?
toast
Post by toast » Saturday 16 September 2017 0:29
Ok, I was digging a bit mode at the code for this. I cant really write/read code... so excuse me if it looks stupid...
In hardware/1Wire.cpp
SendMeterSensor(deviceIdByteArray[0], deviceIdByteArray[1]+unit, 255, (const float)count
er, "Counter");
changed to
er/1000, "Counter");
Actually, now when I checked "SendMeterSensor" I can see that others also use /1000 in the code... Don't know why...
Regards,
Patrik
fantom
Post by fantom » Sunday 15 October 2017 21:31
I'm not 1wire creator, but I take care of this module.
I created pul request with fix: https://github.com/domoticz/domoticz/pull/1873
Fantom
ps. Yes, this is one of the biggest problem with domoticz: data is modified before save, and not stored "as is". I have all time problem with this :( I send one value, and domoticz save another. Because domoticz divided, multiplied, added or performs other activities on original data. This is a big mistake and is not improved.
fantom
Post by fantom » Saturday 21 October 2017 13:47
Please install domoticz ver >= 3.8611
If fix resolve problem, please close this topic.
Fantom
toast
Post by toast » Friday 27 October 2017 13:29
Thanks fantom,
Yes I noticed the change some days ago and its and I have been running with that code for weeks before that with my own change.
There is one other thing I noticed. I am not 100% sure. But to get rid of those spikes that still happens some times. E.g. when the value is logged as 86201744. I have done this to. Its not a nice solution and I dont know the root cause to the issue. Maybe value becomes negative for some reason. Maybe bad data from 1wire bus. But this so far have removed the spikes for me. Maybe there is a more clever generic and better way of validating the data...
void C1Wire::ReportCounter(const std::string& deviceId, const int unit, const unsigned long counter)
        if ((counter > 4000000000) || (counter < 1))
                return;
        unsigned char deviceIdByteArray[DEVICE_ID_SIZE]={0};
        DeviceIdToByteArray(deviceId,deviceIdByteArray);
        SendMeterSensor(deviceIdByteArray[0], deviceIdByteArray[1]+unit, 255, (const float)counter/1000.0f, "Counter");
