Memory Leakage?
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
EddyG
Target OS: Raspberry Pi
Domoticz version: 4.9999
Re: Memory Leakage?
Post by EddyG » Sunday 12 November 2017 17:03
What's your script to get the Domoticz memory usage?
Regards,
Eddy
DutchHans
Re: Memory Leakage?
Post by DutchHans » Sunday 12 November 2017 17:58
There were more than 700 updates in the beta channel after 8073.
Activate hardware monitor - motherboard..than you will have several hardware sensors activated.
Cheers ...
DutchHans
Re: Memory Leakage?
Post by DutchHans » Wednesday 15 November 2017 22:30
It drops when Domoticz is restarted (after an update)..but than rising again...
Any news?..or anything i can do to help?
Cheers,Hans
Pjedr
Re: Memory Leakage?
Post by Pjedr » Friday 17 November 2017 19:50
Same with me.
Now i am up to latest beta again.
Turned events off for 1 hour.
Now turned it on.
I am afrain something in lua is eating memory, cpu and time.
Need to check later.
heggink
Domoticz version: V4.9999
Re: Memory Leakage?
Post by heggink » Monday 20 November 2017 21:40
Slowly happening to me as well. As of Nov 9th, memory increases by 1.7% per day. Not massive but, before that, it was completely stable, no increase at all from oct 20th to Nov 9th. Weird.
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
RFMuser
Re: Memory Leakage?
Post by RFMuser » Monday 20 November 2017 22:58
Hi all, a few weeks ago I crashed the RPI3 while updating, trying to fight mem problem. So I ended up imaging the SD card again with Jessie light.
Linux raspberrypi 4.9.41-v7+ #1023 SMP Tue Aug 8 16:00:15 BST 2017 armv7l GNU/Linux
After a new Domoticz install
Version: 3.8564
Build Hash: 09e677d
Compile Date: 2017-10-10 00:48:08
dzVents Version: 2.3.0
I recovered the database so most of the settings were the same. I stopped using LUA and setup some dzVents scripts.
I keep an sharp eye on the mem but as you can see a flat line all the time...
Siewert308SW
Re: Memory Leakage?
Post by Siewert308SW » Tuesday 21 November 2017 18:48
Quick question...
Those who suffer from increasing memory.
Are you using (enabled) http aswell as https port when you setup Domoticz?
Setup:
- RPi3 - PIco HV3.0A / Domo Beta 3.9XXX / RFXtrx433E / Aeotec Gen5
- RPi3 - PIco HV3.0A / PiHole / PiVPN / NAS / Print Server
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
MyDomoticz scripts: @GitHub
PIco UPS Toolkit: @GitHub
heggink
Re: Memory Leakage?
Post by heggink » Tuesday 21 November 2017 18:50
I am.
Pi3, latest beta
Harmony hub, Nest
Siewert308SW
Re: Memory Leakage?
Post by Siewert308SW » Tuesday 21 November 2017 19:31
I am.
Thx but i'm also curious id there are users who don't use https.
I asked this as for 2 years ago there was also a leak which had a connection to https.
I disabled the port a few hours ago, it is to early to say but maybe this issues has been popped up again.
For now the memory looks stable but will report tomorrow about my findings.
Setup:
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
DutchHans
Re: Memory Leakage?
Post by DutchHans » Tuesday 21 November 2017 20:36
I am not sure if I installed https ..how can I check (rpi3)
Regards, Hans
Siewert308SW
Re: Memory Leakage?
Post by Siewert308SW » Thursday 23 November 2017 19:44
Regards, Hans
I bit late ;-)
But what does your log say?
WebServer(HTTP) started on address: :: with port 8080
WebServer(HTTP) started on address: :: with port 433
After a few days of testing i don't suspect https as the main culprit.
Yesterday i took a second spare Pi3 with a clean Rasbian Jessie and Domoticz beta installation.
The memory usage was stable after 20hr.
A few hours ago i installed libpython3. which is needed to be able to fire up the python plugin system.
Since then the memory is rising and current mem usage after 2hr is already higher then i saw after 20hr idle
edit:
Already asked is someone on github with more experiance could take a look.
I do suspect libpython3. which is used for enabling python plugin system could be the culprit.
After a running my 2 Rpi3 system idle overnight the one with libpython3. without script has a memory increase.
https://github.com/domoticz/domoticz/issues/1955
Setup:
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
Siewert308SW
Re: Memory Leakage?
Post by Siewert308SW » Saturday 25 November 2017 0:24
After a closer look on both my system it looks like the culprit isn't the libpython3. install
Both system do have a increase in Memory usage.
But the test Pi3 didn't increase that fast as it isn't running any scripts.
For now i disabled the event system on my test Pi3 to see what happens in the upcoming hours.
10min after i disabled the event system i already see a drop in memory usage.
It dropped from 5.89 to 5.6% and still decreasing.
Take in mind no scripts running.
After a few hours without the event system enabled the memory dropped even more till 4.9% and is now running stable.
Will let it run overnight and see what happens.
But someone with more experience do have to look where the culprit is.
As on even a bare system without scripts the memory increases and decreases then run stable if the eventsystem is disabled.
Setup:
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
RFMuser
Re: Memory Leakage?
Post by RFMuser » Saturday 25 November 2017 21:16
like in my previous post another screenshot.
Pretty flat line. I experienced the mem problem already for a long time. The only thing I changed, after the fresh install detailed above with the same database was, I use dzVentz with the event system active. Now 3 scripts are running.
So you might try a fresh install, and your actual database without LUA. Than run a while and see if it stays flat. If it does, try some dzVentz test scripts. If it remains stable run some LUA scripts and check again. I'm wondering what happens...
Pchatill
Domoticz version: V2.3774
Re: Memory Leakage?
Post by Pchatill » Monday 04 December 2017 13:31
Hi.
For information and if that can help:
I have this probleme since beginning of november when I updated Raspbian from Wheezy to Jessie,
and in the same time updated domoticz from last stable to V3.8702.
No others changes in domoticz config.
DutchHans
Re: Memory Leakage?
Post by DutchHans » Thursday 07 December 2017 16:08
A little update for the developers:
I have Domoticz 3.8771 on a RPI3 (Jessie) with about 200 devices and eventsystem running (No DZvents) and memory is increasing.
I have (for test) another RPI3 (Stretch) with no devices and no eventsystem running and memory is also increasing.
Looks like its not the eventsystem...
Regards, Hans
jannl
Re: Memory Leakage?
Post by jannl » Thursday 07 December 2017 16:25
Wondering....what happens when the memory is "full", does the (or some) garbage collector clean it up? Or does the system actually crash?
heggink
Re: Memory Leakage?
Post by heggink » Thursday 07 December 2017 16:26
System stops. If a process allocates mem, no garbage collector can free anything other than cached.
Pi3, latest beta
Harmony hub, Nest
heggink
Re: Memory Leakage?
Post by heggink » Thursday 07 December 2017 16:35
Btw, you can use monit to monitor process and system and restart processed when they exceed a threshold. Prevents locks.
Pi3, latest beta
Harmony hub, Nest
jannl
Re: Memory Leakage?
Post by jannl » Thursday 07 December 2017 16:42
And you actually tested that?
I mean, I know that if a process allocates memory and does not free it, the system will stop.
I am just wondering why that does not happen at my system. I just have a crontab that frees some unused memory regularly and the system runs as long a I let it.
edit: actually "echo 3 > /proc/sys/vm/drop_caches" is what I do
heggink
Re: Memory Leakage?
Post by heggink » Thursday 07 December 2017 17:55
Yes, have it up and running. Driver was the blockly mem bug. Caused my system to lock up.
In terms of clearing cache, on linux there is no need and it's bad practice (some people use the drop_caches) since it interferes with linux own capabilities that do precisely what it needs to.
Pi3, latest beta
Harmony hub, Nest
Users browsing this forum: No registered users and 6 guests
