Memory Leakage?
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
manjh
Target OS: Raspberry Pi
Domoticz version: 3.8153
Re: Memory Leakage?
Post by manjh » Wednesday 11 October 2017 19:28
jvandenbroek wrote:
Wednesday 20 September 2017 15:10
manjh wrote:
Monday 18 September 2017 21:19
Memory usage increases from 8% to 10% over the past four days. I understand that 10% is nothing to worry about, but the slope of the graph is: is goes up consistently.
I use the Pi for Domoticz only, run lua scripts (not Blockly).
Are you sure there are no errors in de log which might indicate that Lua scripts never finishes? Something like "warning script took more than 10 seconds to execute", it's not guarantied that they will ever finish (thus holding the allocated memory). I suppose you could test it easily by temporary disabling all Lua scripts and see what happens in a few hours. 8 to 10% is way too much, my experience is that it will almost stay the same after a few min after starting up.
@manjh I now see that you're not the TS. You mentioned rebooting the Pi, but then we don't know if it's Domoticz causing the climb. Does restarting just Domoticz result in the same dip? In that case, try what I said above (disabling Lua).
Thanks for the tip! I investigated the log, and found a LUA script that would run more than 10 seconds occasionally. This script tried to pull devices from a roomplan. I replaced this script by one that simply has an array of device names, and it now runs quickly and does not run long.
Result: memory is now stable at about 6%!
I am happy now...... :)
Hans
DutchHans
Re: Memory Leakage?
Post by DutchHans » Saturday 14 October 2017 0:33
Memory Leak is now also in the beta versions...
Grtz, Hans
pj-r
Domoticz version: V3.8650
Re: Memory Leakage?
Post by pj-r » Monday 16 October 2017 12:20
Grtz, Hans
What version you was using before the problem occurred and what is your version now?
Whats causing this on your setup: Lua, dzVents, blocky. timers, some HW..? Can you try to disable these one by one and see if it has any effect?
DennisD
Re: Memory Leakage?
Post by DennisD » Monday 16 October 2017 15:57
I enabled zram and it helped alot to keep the memory low, i followed this: https://www.novaspirit.com/2016/12/24/i ... pberry-pi/
In my case the memory begins at 9% creeps up to 15% (time span of 12 hours) and then drops to 9% again. This however is not a solution tho but just a quick fix.
DutchHans
Re: Memory Leakage?
Post by DutchHans » Friday 20 October 2017 15:34
I installd it too, but am not happy with it... Domoticz crashed for the first time in months..
I wonder who else is suffering from this memory leak.. maybe we can pin-down where the source is..
Cheers and have a nice weekend,
Hans
Siewert308SW
Re: Memory Leakage?
Post by Siewert308SW » Friday 20 October 2017 17:36
Hans
Really don't have a clue about the amount of affected users.
I do know and can remember it was mentioned a long time ago.
It didn't bother me or better said i didn't pay attention to it as my Pi3 is rebooted every 24 or 48 hours due to me fiddling with it.
This time i will let up and running for a couple of days and see when (if it does) stabilizes.
Over the last two years of me using the beta's i didn't found a solution or clue what it could cause.
It aint a script which is running in a loop or other malfunction in a script.
Last two years i tried a lot but gave up.
I did notice as you al noticed as well it is something in the eventsystem.
For now i will let my Pi up and running for a couple of days with out rebooting.
Will see how far the memory usage is taking it.
One little question:
The show Memory usage in Domoticz is showing how much Domoticz is using, right.
As the real memory usage as shown in cli and there for counting the entire usage by the system is more the shown in Domoticz
Setup:
- RPi3 - PIco HV3.0A / Domo Beta 3.9XXX / RFXtrx433E / Aeotec Gen5
- RPi3 - PIco HV3.0A / PiHole / PiVPN / NAS / Print Server
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
MyDomoticz scripts: @GitHub
PIco UPS Toolkit: @GitHub
ArieKanarie
Re: Memory Leakage?
Post by ArieKanarie » Thursday 02 November 2017 23:01
Same problem here, version V3.8153 (with some blockly scripts running)
Yesterday evening a few reboots because Domoticz keeps hanging:
DutchHans
Re: Memory Leakage?
Post by DutchHans » Thursday 02 November 2017 23:09
Same here, no blockly...
Grtz, Hans
jeanclic
Re: Memory Leakage?
Post by jeanclic » Friday 03 November 2017 8:20
Yes, there is memory leak in the stable 8153. It is a memory leak related to the event system.
So either you disable all event system, or you move to beta where this issue is fixed...
A third solution (short term) is to reboot domoticz at a frequency or via some script watching memory...
Envoyé de mon BLN-L21 en utilisant Tapatalk
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
DutchHans
Re: Memory Leakage?
Post by DutchHans » Friday 03 November 2017 11:05
I disagree, I am on Beta and yesterday it wasn't fixed in the Beta channel...or is it now?
Grtz, Hans
EddyG
Domoticz version: 4.9732
Re: Memory Leakage?
Post by EddyG » Friday 03 November 2017 11:27
Could not find anything related to this memory problem on github.
Could anyone from the developers comment on this?
Regards,
Eddy
jeanclic
Re: Memory Leakage?
Post by jeanclic » Friday 03 November 2017 12:49
In my 3.8649 version of domoticz, I have no more issues regarding memory leakage...
x4 fibaro / x1 PIR
DutchHans
Re: Memory Leakage?
Post by DutchHans » Friday 03 November 2017 16:04
I've updated to Beta 8692 but the memory leak is still present. It is still climbing...
Regards,Hans
EddyG
Re: Memory Leakage?
Post by EddyG » Friday 03 November 2017 17:27
That's why I asked the developers to comment.
It would be nice that the problem is found and solved.
But I could not find that being addressed on github.
Regards,
Eddy
jeanclic
Re: Memory Leakage?
Post by jeanclic » Friday 03 November 2017 19:53
Are you using particular hardware which could be at the origin of the leak ?
Find enclosed some screenshots of my domoticz setup in beta 3.8649 on a RPI3B with a PiDrive, not on SD card. -> no more leaking observed since I moved to beta. Being satisfied with the 8649 version, I will not update for now till I validate a new one on my test system (I would prefer a stable release, but to be defined...)
-> validated during 12 days of uninterrupted uptime on jessie and so far 6 days and 9 hours on stretch... (no DzVents running, so maybe something for those who are experiencing troubles ?)
EDIT : no blocky script but about 30 lua scripts.
2017-11-03 RPI RAM.png (325.82 KiB) Viewed 1269 times
2017-11-03 Domoticz RAM.png (300.01 KiB) Viewed 1269 times
2017-11-03 Domoticz HW.png (51.35 KiB) Viewed 1269 times
x4 fibaro / x1 PIR
DutchHans
Re: Memory Leakage?
Post by DutchHans » Friday 03 November 2017 21:03
Here's my hardware line-up..nothing strange. LMS and WU are disabled. One python script (presence detection) and about 30 lua scripts. Many http requests for my notifications in the lua scripts.
Maybe this helps clearing the memory leakage.
Hans
jeanclic
Re: Memory Leakage?
Post by jeanclic » Friday 03 November 2017 21:51
hello again,
In an other topic, some guys have «fix» the memory leak by disabling MyDomoticz. Has anyone here tried that ?
x4 fibaro / x1 PIR
DutchHans
Re: Memory Leakage?
Post by DutchHans » Friday 03 November 2017 22:23
Thats a negative..i have not enabled mydomoticz...
So that can't be it..
Cheers, Hans
DutchHans
Re: Memory Leakage?
Post by DutchHans » Saturday 04 November 2017 9:38
Memory was about 20 percent, after a restart of Domoticz it fell back to about 16 percent...after a complete reboot it dropped at around 13 percent..but its rising in all three circumstances.
I hope this can be usefull for the developers.
Regards,Hans
ArieKanarie
Re: Memory Leakage?
Post by ArieKanarie » Saturday 11 November 2017 13:20
I am now on V3.8073 and now the memory is dropping... :)
Users browsing this forum: No registered users and 6 guests
