after update: no notifications from telegram
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Haringstad
Target OS: Raspberry Pi
Re: after update: no notifications from telegram
Post by Haringstad » Friday 25 August 2017 15:05
@JulzJulz, we just have to wait :-) And I bet that this issue will be solved before the weekend is over! :!:
lukbe
Domoticz version: 3.8153
Post by lukbe » Friday 25 August 2017 16:30
Hello guys, I have probably same problem with last beta Version: 3.8364 of the domoticz on my RPI 3.
I use in domoticz script for sending temperature to the thingspeak. Script worked fine, only after last update it does not work and in the log i have error. Error: Error opening url.
Is there any solution ?
My script here:
-- script_time_misc.lua
local sensor_name1 = 'Loznice' -- name of the sensor
local sensor_name2 = 'Venku' -- name of the sensor
local Thingspeak_API= 'xxxxx' -- your thingspeak api key
local set_time= 10 -- time in min
local m = os.date('%M')
if (m % set_time == 0) then
--print('Ubehl nastaveny cas: ' .. set_time .. ' min')
Temp_loznice, Humidity_loznice, sHumFeelsLike_loznice = otherdevices_svalues[sensor_name1]:match("([^;]+);([^;]+);([^;]+)") -- save values from the sensor in to each variable
Temp_loznice = tonumber(Temp_loznice)
Humidity_loznice = tonumber(Humidity_loznice)
Temp_venku, Humidity_venku, sHumFeelsLike_venku = otherdevices_svalues[sensor_name2]:match("([^;]+);([^;]+);([^;]+)") -- save values from the sensor in to each variable
Temp_venku = tonumber(Temp_venku)
Humidity_venku = tonumber(Humidity_venku)
-- print('Teplota - Obyvaci pokoj:' ..Temp_loznice )
--print('Vlhkost - Obyvaci pokoj:' .. Humidity_loznice)
commandArray['OpenURL']=('https://api.thingspeak.com/update?api_key='..
Thingspeak_API.. '&field1=' ..Temp_loznice.. '&field2=' ..Humidity_loznice..
'&field3='..Temp_venku..'&field4='.. Humidity_venku)
--print('Odesilani na Thingspeak')
Odesláno z mého MI 4W pomocí Tapatalk
Freemann
Domoticz version: >=Béta
Post by Freemann » Friday 25 August 2017 17:05
Here also connection issues;
2017-08-25 17:00:16.741 Error: Netatmo: Error connecting to Server...
2017-08-25 17:00:21.799 Error: DarkSky: Error getting http data!.
2017-08-25 17:00:46.773 Error: Netatmo: Error connecting to Server...
2017-08-25 17:00:46.801 Error: Netatmo: Error connecting to Server...
2017-08-25 17:01:01.932 Error: SMTP Mailer: Error sending Email to: !
2017-08-25 17:01:01.932 Error: Failed to send Email notification!
2017-08-25 17:01:01.932 Error: Notification sent (email) => Failed
2017-08-25 17:04:07.462 Error: GCM: Could not send message, HTTP Error
2017-08-25 17:04:07.462 Error: Notification sent (gcm) => Failed
Here issues with;
NetAtmo,
DarkSky,
SMTP,
GCM
Build Hash: 1ba40be6
Build Date: 2017-08-25 07:34:01
Build version: V3.8364
Looks like domoticz can't connect to external sources :!: :?: :| :shock: :o
Created an issue on Github :
Since 3.8360 Totally none (http?) external connection possible #1782
Domotica/graphs "freak" :)
Rpi3
Amazon Alexa (2 Echo Dots)
Aeotec Z-Stick S2(Gen5)
HarmonyElite
ETHRelayBoard
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
vanputten80
Post by vanputten80 » Saturday 26 August 2017 7:19
Issue with email notifications. Errol already mentioned in this topic.
Use the latest stable Windows version. Triest bèta yesterday, same.
lukbe
Post by lukbe » Saturday 26 August 2017 7:51
Today I updated to 3.8365 and still same problem. :-( is here any developer?
roblom
Post by roblom » Saturday 26 August 2017 8:29
3.8365 is a beta version. Beta versions can contain bugs. If you can't want that use the latest stable version.
Freemann
Post by Freemann » Saturday 26 August 2017 10:22
Great post!
Bugs OK, but this is a major show stopper which prevents almost all API's to work with Domoticz.
This "bug" makes my installation totally useless.
Atleast 10 (sub)system/devices are down due to this "bug".
:lol:
Rpi3
HarmonyElite
ETHRelayBoard
IP-Cam
SweetPants
Domoticz version: V4.9999
Post by SweetPants » Saturday 26 August 2017 12:12
Great post!
:lol:
I kinda agree with roblom, this is why I have a second test system to test major functionality of a new Beta before putting it on my production system.
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
Freemann
Post by Freemann » Saturday 26 August 2017 13:25
Great post!
:lol:
You guys are so TOTALLY right!
But;
1. Its a big open door to say that here....
2. It nearly impossible to debug a system without running it full-swing in a production like situation (guess there nobody here with an (D)TAP "street" :?: )
3. if nobody test Domoticz in a production like situation bug will enter "stable"
For now I'm going back to stable and will see if/when and how this will be solved from the sideline :)
Rpi3
HarmonyElite
ETHRelayBoard
IP-Cam
JuanUil
Domoticz version: 2.xx
Post by JuanUil » Sunday 27 August 2017 8:06
Great post!
:lol:
But;
I agree
Varazir
Post by Varazir » Sunday 27 August 2017 19:28
I tested the WEB API I'm using from the shell and it works there with wget
1x Raspberry PI A with a RaZberry board
1x GreenWave 6 port Power node
1x tellstick
1x Qubino ZMNHOD1 ( controlling a Ikea blinder )
1x ZW075 Smart Switch Gen5
Several nexa/proove devices
Live Long and Prosper \\//_
emme
Domoticz version: latest
Post by emme » Monday 28 August 2017 10:47
RPi3 updated to new kernel....
Notification (Telegram BOT) --> Notification sent (http) => Failed
eMail notification (gMail) --> SMTP Mailer: Error sending Email to: !
NetATMO (Home Coach) --> Cannot Connect to server
DarkSky --> Erro getting data
thanks
ciao
M
"We always done this way"
SweetPants
Post by SweetPants » Monday 28 August 2017 11:45
thanks
ciao
M
If you had read the forum first, you would have known that there is an issue with latest Beta(s).
Freemann
Post by Freemann » Monday 28 August 2017 12:19
thanks
ciao
M
Devs don't know where it comes from, so advice for now; move back to stable.
Rpi3
HarmonyElite
ETHRelayBoard
IP-Cam
emme
Post by emme » Monday 28 August 2017 12:35
no rush.... :D
I can wait
mine was just a notification :P
ciao
M
SweetPants
Post by SweetPants » Monday 28 August 2017 13:02
@Dev's, I'm on last Beta but compile from source (Ubuntu 14.04LTS), there everything is working fine, maybe this helps finding the solution
gennapium
Post by gennapium » Monday 28 August 2017 13:08
Same here i am on Ubuntu 16.04.3 and compiled from source, Nest working sending email working and sending pushover messages is working.
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
BUSHA
Domoticz version: 3.8367
Post by BUSHA » Tuesday 29 August 2017 10:46
Version: 3.8369 - still no notifications :(
SweetPants
Post by SweetPants » Tuesday 29 August 2017 19:17
Where did you read that the problem was found?
sysedit
Post by sysedit » Tuesday 29 August 2017 20:04
Is there anything we can do to help finding the issue ?
I'm for instance thinking of extra logging that could be added to the next beta build - as long as reverting to stable is still working I don't mind upgrading, testing, gathering logs.
As the issue is quite wide spread and can easily be reproduced it shouldn't be super hard to find the root cause (that said, as a dev I know it's always easier to say than to do ;) )
Thanks !
Users browsing this forum: Google [Bot] and 5 guests
