after update: no notifications from telegram
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
heggink
Target OS: Raspberry Pi
Domoticz version: V3.9530
Re: after update: no notifications from telegram
Post by heggink » Tuesday 29 August 2017 21:38
As said, copy and compile/build solves it. Happy to solicit my rpi3 compile. Anyone with some generally available storage?
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
sysedit
Post by sysedit » Tuesday 29 August 2017 21:50
I'd assume that Domoticz dev team would like to understand what's wrong and how to make sure it's not happening again.
I know we're talking about a beta (and that it sounds like releases are now more frequent than they used to be couple of years ago, meaning stable version does not mean 2 years old version anymore), but broken http / notifications for a home automation system is kind of major issue.
Just to clarify: I'm not blaming anyone (that would be completely wrong when you see the time spent by gizmocuz and others on Domoticz) - just trying to see how we can help finding the issue - and building locally won't help as it seems the issue can only be reproduced with binary versions.
heggink
Post by heggink » Tuesday 29 August 2017 21:56
We all want new stuff but we are also quite dependent on a stable system. A decent backup allows a roll back in case of mishap. Obviously anyone would want to understand how to prevent but that's no substitute for an incremental backup.
Pi3, latest beta
Harmony hub, Nest
sysedit
Post by sysedit » Tuesday 29 August 2017 22:01
Sure - I've hourly backups, and reverting to stable was a no brainer, so I can't say I've been really impacted anyhow by this issue. Again, I'm more in a "if there is anything we can do to help please yell we'll be very happy to do it" mood - definitely not ranting because it's not fixed yet.
BTW - https://github.com/domoticz/domoticz/issues/1782 - Sounds like @gizmocuz is reinstalling the build system.
heggink
Post by heggink » Tuesday 29 August 2017 22:03
Yup. Noticed. Couldn't wait
Pi3, latest beta
Harmony hub, Nest
oxedgar1
Post by oxedgar1 » Saturday 09 September 2017 7:52
Hi have the samme problem... ALL notifications cannot work with any params on the last beta version...
remkolodder
Post by remkolodder » Saturday 09 September 2017 11:10
sysedit wrote:
Thursday 24 August 2017 18:26
Same with email, prowl and http notifications:
2017-08-24 18:25:00.124 Error: HTTP:
2017-08-24 18:25:00.124 Error: Notification sent (http) => Failed
2017-08-24 18:25:00.248 Error: SMTP Mailer: Error sending Email to: !
2017-08-24 18:25:00.248 Error: Failed to send Email notification!
2017-08-24 18:25:00.248 Error: Notification sent (email) => Failed
2017-08-24 18:25:00.272 Error: Prowl:
2017-08-24 18:25:00.272 Error: Notification sent (prowl) => Failed
snirf :(
+1;
benbammens
Post by benbammens » Tuesday 19 September 2017 11:52
Problem solved with the most recent beta here...
mgrom
Post by mgrom » Thursday 12 April 2018 9:20
I've got the same problem:
Version: 3.9208
Build Hash: ff40091a
Compile Date: 2018-04-08 17:15:17
2018-04-12 08:38:46.633 Notification: Domoticz test
2018-04-12 08:38:46.829 Error: Pushover:
2018-04-12 08:38:46.830 Notification sent (pushover) => Failed
2018-04-12 08:38:46.840 Active notification Subsystems: (0/14)
SweetPants
Domoticz version: V4.9701
Post by SweetPants » Sunday 15 April 2018 11:40
Please don't hijack an existing topic. This one is about Telegram notifications, yours is about Pushover. You better open a new topic.
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
funnybu
Domoticz version: 3.9272
Post by funnybu » Sunday 13 May 2018 15:54
is any way to get notification from last beta?
SweetPants
Post by SweetPants » Tuesday 15 May 2018 20:12
Notification on latest Beta 3.9440 is just working fine on my side.
EdddieN
Domoticz version: 4.9700
Post by EdddieN » Tuesday 15 May 2018 21:53
Running same version, however I do not seem to get the notifications to work under Blockly. Does it work for you a simple IF somethign ON then send Telegram?
On simple notification, like directly on a device it works ok.
11101101 - www.machinon.com
SweetPants
Post by SweetPants » Wednesday 16 May 2018 7:28
I do not use Blockly but dzVentz as Blockly is limited in features and new development.
EdddieN
Post by EdddieN » Wednesday 16 May 2018 8:24
But does it work for you?
SweetPants
Post by SweetPants » Wednesday 16 May 2018 18:11
Yes, this blocky works with Telegram
funnybu
Post by funnybu » Wednesday 16 May 2018 21:20
i solve my problem. Now i have Telegram notification on Domoticz 3.9272
I use socks5, bkz in Russia Telegram blocked now.
Settings -> Notification
And telegram.sh
#! /bin/bash
# Proxy setup
PROXY_IP="80.*.*.*"
PROXY_PORT="1080"
PROXY_USER="al***"
PROXY_PAS="*****"
# Bot setup
BOT_ID="bot********"
TOKEN="*********"
CHAT_ID="******"
curl -x socks5://$PROXY_USER:$PROXY_PAS@$PROXY_IP:$PROXY_PORT "https://api.telegram.org/$BOT_ID:$TOKEN/sendMessage?chat_id=$CHAT_ID&text=$1"
If u dont't need proxy, just use this
#! /bin/bash
# Bot setup
TOKEN="*********"
CHAT_ID="******"
curl "https://api.telegram.org/$BOT_ID:$TOKEN/sendMessage?chat_id=$CHAT_ID&text=$1"
EdddieN
Post by EdddieN » Wednesday 16 May 2018 22:36
thanks for confirming that, obviously I have something broken then...
