crash after update to latest Beta
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
gennapium
Target OS: Raspberry Pi
Post by gennapium » Wednesday 23 August 2017 19:00
Version 3.8342
Platform Ubuntu 16.04 server
Hardware: Hue, Nest, RFXCOM, Zwave
I was trying to update the system to the latest beta but got this error:
2017-08-23 18:31:24.169 WEBH : Host:172.17.17.65 Uri;/json.htm?type=command&param=getSunRiseSet
2017-08-23 18:31:24.169 WEBS GetJSon :getSunRiseSet :/json.htm?type=command&param=getSunRiseSet
2017-08-23 18:31:24.177 Error: Domoticz received fatal signal 6 !...
2017-08-23 18:31:24.179 Error: /home/domoticz/domoticz/domoticz() [0x603288]
2017-08-23 18:31:24.179 Error: /home/domoticz/domoticz/domoticz(_Z14signal_handleri+0x50) [0x603330]
2017-08-23 18:31:24.179 Error: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f91de270390]
2017-08-23 18:31:24.179 Error: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38) [0x7f91dd534428]
2017-08-23 18:31:24.179 Error: /lib/x86_64-linux-gnu/libc.so.6(abort+0x16a) [0x7f91dd53602a]
2017-08-23 18:31:24.179 Error: /lib/x86_64-linux-gnu/libc.so.6(+0x777ea) [0x7f91dd5767ea]
2017-08-23 18:31:24.179 Error: /lib/x86_64-linux-gnu/libc.so.6(+0x8037a) [0x7f91dd57f37a]
2017-08-23 18:31:24.180 Error: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c) [0x7f91dd58353c]
2017-08-23 18:31:24.180 Error: /home/domoticz/domoticz/domoticz(CRYPTO_free+0x1d) [0x9eba6d]
2017-08-23 18:31:24.180 Error: /lib/x86_64-linux-gnu/libssl.so.1.0.0(SSL_CTX_set_alpn_protos+0x1d) [0x7f91dce84b9d]
2017-08-23 18:31:24.180 Error: /usr/lib/x86_64-linux-gnu/libcurl.so.4(+0x5152a) [0x7f91dde2752a]
2017-08-23 18:31:24.180 Error: /usr/lib/x86_64-linux-gnu/libcurl.so.4(+0x53ec0) [0x7f91dde29ec0]
2017-08-23 18:31:24.180 Error: /usr/lib/x86_64-linux-gnu/libcurl.so.4(+0x109dd) [0x7f91ddde69dd]
2017-08-23 18:31:24.180 Error: /usr/lib/x86_64-linux-gnu/libcurl.so.4(+0x21ba1) [0x7f91dddf7ba1]
2017-08-23 18:31:24.180 Error: /usr/lib/x86_64-linux-gnu/libcurl.so.4(+0x362ee) [0x7f91dde0c2ee]
2017-08-23 18:31:24.180 Error: /usr/lib/x86_64-linux-gnu/libcurl.so.4(curl_multi_perform+0x10d) [0x7f91dde0ceed]
2017-08-23 18:31:24.180 Error: /usr/lib/x86_64-linux-gnu/libcurl.so.4(curl_easy_perform+0x13b) [0x7f91dde0394b]
2017-08-23 18:31:24.180 Error: /home/domoticz/domoticz/domoticz(_ZN10HTTPClient10POSTBinaryERKSsS1_RKSt6vectorISsSaISsEERS2_IhSaIhEEb+0xb8) [0x76bda8]
2017-08-23 18:31:24.180 Error: /home/domoticz/domoticz/domoticz(_ZN10HTTPClient4POSTERKSsS1_RKSt6vectorISsSaISsEERSsbb+0x5e) [0x76c3fe]
2017-08-23 18:31:24.180 Error: /home/domoticz/domoticz/domoticz(_ZN5CNest5LoginEv+0x325) [0x842ad5]
2017-08-23 18:31:24.180 Error: /home/domoticz/domoticz/domoticz(_ZN5CNest15GetMeterDetailsEv+0x2b2) [0x844bc2]
2017-08-23 18:31:24.180 Error: /home/domoticz/domoticz/domoticz(_ZN5CNest7Do_WorkEv+0x89) [0x846489]
2017-08-23 18:31:24.180 Error: /home/domoticz/domoticz/domoticz() [0xb3f17a]
2017-08-23 18:31:24.180 Error: /lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba) [0x7f91de2666ba]
2017-08-23 18:31:24.180 Error: /lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7f91dd6063dd]
It seems like the system is running for a few seconds and then crashes.
What is going wrong here ?
I had to revert to the latest stable to get it running again.
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
gennapium
Re: crash after update to latest Beta
Post by gennapium » Wednesday 23 August 2017 21:00
I just did another test. I have a testmachine that i updated to the latest beta. That is working just fine. The restored the database from the production machine.
After a few seconds domoticz crashed.
I then delete the database, do a ./updatebeta and it is working again.
Maybe this helps, the problem is in the database, i think but i don't know where to go from here.
papoo
Post by papoo » Wednesday 23 August 2017 22:37
Raspberry PI3/jessie
Version 3.8342 running for a few seconds and then crashes for me too
jvdz
Domoticz version: Stable
Post by jvdz » Wednesday 23 August 2017 22:44
Latest beta is 3.8355, so maybe update manually and see if that fixes it?
Jos
papoo
Post by papoo » Wednesday 23 August 2017 23:03
Sorry i was wrong with version number
it's the 3.8360 version
it's run only 10 seconds
papoo
Post by papoo » Wednesday 23 August 2017 23:40
the problem is on the database
JdoTMM
Post by JdoTMM » Thursday 24 August 2017 0:29
First post after some lurking :D
Same problem here: after updating to 8360 Domoitcz has a crash. Now back to latest stable.
Regards!
1 Aeotec ZW090
2 FIB FGDW002
1 FIB FGMS001
3 FIB FGSD002
4 Neo CoolCam Power plug
1 Popp 004407
1 FIB FGS222
1 NodOn CRC-3-1-00
gennapium
Post by gennapium » Thursday 24 August 2017 8:04
Toninght i want to start deleting stuff from the database to see what is causing the crash. As soon as i find the answer i will report it here.
But if anyone finds the answer to the problem soner, that would be great :) .
SweetPants
Domoticz version: V4.9701
Post by SweetPants » Thursday 24 August 2017 8:10
Sure it's a database problem? I'm on V3.8360 and have no problems
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
gennapium
Post by gennapium » Thursday 24 August 2017 8:15
Hi Sweetpants,
I think its a database problem, the system is running fine on the latest stable. When i upgrade the system crashes.
After the crash i delete the database restart the system and then it is running fine with a empty database.
Also adding two virtual switches and a dventz script to the new database works fine. The newly added script is working just fine.
Then when i restore the original database the system crashes again, so i think it must be the database.
andi216
Domoticz version: 3.7243
Post by andi216 » Thursday 24 August 2017 8:27
(V.8360) It seems that all external plug-ins cause the problem. I renamed the plugins folder - plugins_old and reinstalled ./updatebeta. It works. I hope to fix the problem. I only have three plugins (BroadLink, Battery zwave, Wemo).
gennapium
Post by gennapium » Thursday 24 August 2017 8:32
Ok,
I use the buienradar plugin, but that isn't installed on the system i test on. It is just in the database of the production i use to debug on my test system.
But i will have a look tonight do rename the plugin folder and see what happens then.
Will let you know the result asap.
papoo
Post by papoo » Thursday 24 August 2017 10:42
same for me
one python plugin crash => Air Quality Monitoring viewtopic.php?f=65&t=18062
mivo
Re: crash after update to latest Beta - 3.8360
Post by mivo » Thursday 24 August 2017 11:06
I can confirm crashing on 1 Python plugin in current Beta - 3.8360 on RPi3.
It is unfortunately (or luckily) my own plugin for WeMo Switch :( Other used Python plugins (UPS PIco and Battery Z-wave) running OK.
Trying to debug, at first impression it looks like plugin system now does not like urllib.request Python module
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
papoo
Post by papoo » Thursday 24 August 2017 11:16
the Air Quality Monitoring plugin use urllib.request to
raymond
Domoticz version: V3.8275
Post by raymond » Thursday 24 August 2017 11:56
I can confirm the crash is due to python plugins. Using Kodi, Denon-marantz and buienradar plugins.
Moved all of them to the example folder, rebooted, and domoticz is starting up again.
Checked which one is causing the problem by moving them back into the plugins folder one-by-one.
Each one moved back is causing domoticz to crash.
log file is 1.5G by the way. I cleared it but it is 1.5G instantly when rebooted.
Snowtiger
Domoticz version: 3.8363
Post by Snowtiger » Thursday 24 August 2017 13:29
Beta Version V3.8363 is out - updated to this version but still the same problem - moving my only Python Plugin - Buienradar - to the Example folder, restart and the system is running again.
Problem seems likely not to be solved.
jvdz
Post by jvdz » Thursday 24 August 2017 13:43
There is indeed a Python plugin issue with the latest versions. 3.8355 was running fine and 3.8360 & 3.8363 both crashed immediately at startup of domoticz on the plugins. renaming the directory made Domoticz start. Rolled back to a previous version for the moment.
Jos
Bluelightcrew
Domoticz version: 3.6708
Post by Bluelightcrew » Thursday 24 August 2017 14:12
For me helped only going back to latest stable with CD domoticz and ./updaterelease
djoele
Post by djoele » Thursday 24 August 2017 16:30
I have the same issue. Last night I updated to the latest beta.
Domoticz does not start but crashed immediatel.
In my Domoticz log there is nothing logged.
For now I installed the latest release instead of the Beta.
Is there any idea what could be the problem?
Users browsing this forum: Google [Bot] and 5 guests
