Unable to edit switches
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
thorbj
Target OS: Raspberry Pi
Post by thorbj » Wednesday 23 August 2017 14:12
Version: 3.8356 (beta)
Platform: Raspberry/Debian
Plugin/Hardware: zWave, Netatmo, Philips Hue, pytradfri
Hi, I have made two dummy AC On/Off switches that I changed to dimmer switches. I use these switches to control IKEA Trådfri bulbs.
Now I want to add a ne bulb, and wanted to see the configuration of the switches by editing them. But I am unable to edit them. When I click the Edit buttin, nothing happens in Domoticz. All other dummy switches work great, except these two.
The Chrome error console gives me this error when I press the edit button:
:8080/app/LightsController.js:1539 Uncaught TypeError: Cannot read property 'split' of undefined
    at EditLightDevice (:8080/app/LightsController.js:1539)
    at HTMLAnchorElement.onclick (:8080/#/LightSwitches:1)
EditLightDevice	@	:8080/app/LightsController.js:1539
onclick	@	:8080/#/LightSwitches:1
Any clues?
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
gizmocuz
Re: Unable to edit switches
Post by gizmocuz » Wednesday 23 August 2017 15:39
Could you tell me your exact steps 'how' you created the switch ?
thorbj
Post by thorbj » Thursday 24 August 2017 11:18
I'm not sure about the exact translation, but:
In the switches pane --> Add switch
Switchtype Dummy - AC, then I gave it a name and ID.
Pressed Add, and then edited the switch to call the IKEA plugin urls.
gizmocuz
Post by gizmocuz » Thursday 24 August 2017 12:52
you mean you added a script to the switch ? and this does not work ?
What is your script line ?
Please post a screenshot
thorbj
Post by thorbj » Thursday 24 August 2017 14:48
The script works, the switch works. But when I want to enter "edit mode" for the switch, to copy the scrip url to another switch, I can't. When pressing edit nothing happens except for the error in chrome error console.
gizmocuz
Post by gizmocuz » Saturday 26 August 2017 7:55
I need your script line to replicate this
thorbj
Post by thorbj » Tuesday 05 September 2017 14:42
Sorry for the late reply. Unfortunately I can't get you the script line as I am unable to edit the switch that uses the script line.
morilm
Target OS: OS X
Post by morilm » Sunday 08 October 2017 11:57
I can confirm the issue on my Domoticz as well.
Seems to be an issue with virtual dimmer switches.
To create it I have used the manual switch as "selector switch". Once you change the settings to "dimmer" you can never edit it again. Swith/dimmer works fine, but can't be edit.
It's not an issue of corrupt switch as it happens all the times.
regards,
Miguel
fantom
Post by fantom » Sunday 15 October 2017 18:07
Hi.
I found this same problem today:
https://github.com/domoticz/domoticz/issues/1872
Fantom
etamminga
Post by etamminga » Sunday 03 December 2017 16:53
Same here. Created a dummy switch from the HW page. Edit it to be of type selector with a different Icon (in my case the Speaker icon).
Click Save and return to the Switches page. Click Edit again of the switch and then the UI is incomplete/incorrect/etc.
From the Chrome Developer Tools:
LightsController.js:1750 Uncaught TypeError: Cannot read property 'join' of undefined
at EditLightDevice (LightsController.js:1750)
at HTMLAnchorElement.onclick (VM810 LightSwitches:1)
Regards,
Erik
syrhus
Domoticz version: 3.8153
Post by syrhus » Wednesday 13 December 2017 15:24
version: 3.8153
Platform: raspberry pi 3
I had the same issue.
There is a bug in the LightsController.js file
I've fixed it with this code:
EditLightDevice = function (idx, name, description, stype, switchtype, addjvalue, addjvalue2, isslave, customimage, devsubtype, strParam1, strParam2, bIsProtected, strUnit) {
if (typeof $scope.mytimer != 'undefined') {
$interval.cancel($scope.mytimer);
$scope.mytimer = undefined;
$.devIdx = idx;
$.isslave = isslave;
$.stype = stype;
$.strUnit = strUnit;
$.bIsSelectorSwitch = (devsubtype === "Selector Switch" && switchtype!==7); //7= dimmer
If you need help on github, let me know, it would be a pleasure to contribute.
fantom
Post by fantom » Wednesday 13 December 2017 15:31
Please create pull request on github
Fantom
Users browsing this forum: devros and 8 guests
